Old 07-09-2014, 11:01 PM   #1
mikes603
mikes603's Avatar
Drives: 2012 FRS
Tire Temperature System
Made this system (I'm an EE) for my FRS and Lotus, and other HPDE guys I know. It's to know when your tires are up to operating temp. I thought I'd try and get some feedback here to see what people thought.
Here are the features of the kit:
  • Four IR sensors
  • Narrow 10deg sensor field of view for sampling tire sections
  • Large 1 1/12 by 2 1/2 inch display
  • Weather resistant; sensors can get wet without being ruined.
  • Removable lens cap if they need cleaning or replacement
  • Extra protective lenses
  • Does both fahrenheit and celsius
  • You can adjust the emissivity of each sensor (different materials reflect light at differing rates)
  • Quality harnesses
  • DC supply is designed for difficult automotive environments with large current dumps and voltage spikes
The installation is straight forward. You drill a small hole in the wheel arch for the sensor to poke through. Top center is best to account for changes in tire angle.
I'm aware 3 sensors per tire would be needed per corner to monitor camber load. But that's another kit--one with no display and CAN support for data-logging--and not this one, which is aimed at being sub $1k.
If anyone is interested just send me a PM or email me at mikes at ntisys.com
mikes603 is offline   Reply With Quote
The Following 2 Users Say Thank You to mikes603 For This Useful Post:
DAEMANO (07-10-2014), plucas (07-13-2014)
Old 07-09-2014, 11:04 PM   #2
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
can you just re-route to a windows based software?
I'd be interested in this but I wouldn't really need it real time, just something to look at after a few runs as a logging fashion.
Old 07-10-2014, 09:15 AM   #3
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Very cool!
Old 07-10-2014, 09:22 AM   #4
stugray
Drives: 2013 GBS BRZ Limited
Cool! ( I mean HOT!)
Two things to consider:
1 - Any lens caps will throw off the measurements because the sensor will average the temps between the lens and the tire
2 - Different tire compounds can give very different IR signatures, so make a calibration mode where you measure the tire temp with a thermocouple probe, and set the "baseline temp" that way.
I have always wanted to make an IR line scanner over each wheel.
Then as the tire rotates, you get a complete temperature map in near real-time.
You would see flat spots, or incorrect suspension setups that way.
What temp sensor is that?
Arduino based?
Old 07-13-2014, 11:33 AM   #5
mikes603
mikes603's Avatar
Drives: 2012 FRS
Arduino based?
1) The lens is made of a special plastic made for just this application, it has a passband of the IR freq range used.
2) "You can adjust the emissivity of each sensor (different materials reflect light at differing rates)"
Old 07-13-2014, 02:37 PM   #6
stugray
Arduino based?
Guess it's a secret.....
Old 07-13-2014, 10:48 PM   #7
renfield90
The Stig's German cousin
He's not selling it for free so yeah. As an embedded engineer, if that were mine I wouldn't be saying either.
Old 07-13-2014, 11:02 PM   #8
plucas
plucas's Avatar
Drives: Subaru
So awesome dude!
plucas is offline   Reply With Quote
Old 07-14-2014, 01:26 AM   #9
robot
There are now 2 carseats!
Drives: 2013 DGM BRZ
Any plan to do inner middle and outer temps? Then you could see how your alignment is holding up. I've considered building something like this in the past but never got down to doing it.
robot is offline   Reply With Quote
What temperature do you put A/C on? FRiSson New England 23 06-13-2016 08:55 AM
Tire Temperature System mikes603 Tracking / Autocross / HPDE / Drifting 21 10-05-2014 03:21 PM
Running Temperature? 350matt Engine, Exhaust, Transmission 13 10-29-2013 03:55 PM
Question: TPMS Tire-pressure monitoring system installed on aftermarket wheels Figo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 08-05-2013 12:54 PM
Engine temperature Skye Issues | Warranty | Recalls / TSB 5 08-09-2012 10:33 PM
