Old 07-05-2014, 08:02 PM   #1
glamcem
glamcem's Avatar
Drives: 2022 BRZ Limited
Thumbs up Schroth Racing Rallye 3 ASM Harnesses .. what a difference
I have to say I am really impressed with the quality and simplicity of the harnesses, even with OEM seats they keep me in place and installation was pretty straightforward ... I can definitely recommend these harnesses for those who look for a simple and cost effective upgrade..
and a video with the harnesses
[ame="http://youtu.be/2JDtUJGLag0"]http://youtu.be/2JDtUJGLag0[/ame]
glamcem is offline   Reply With Quote
The Following User Says Thank You to glamcem For This Useful Post:
Kostamojen (07-06-2014)
Old 07-06-2014, 06:13 AM   #2
AFRichZC6
AFRichZC6's Avatar
Nice! I used to have the Schroth Quick-Fit harnesses in my GTI. I ended up selling them and replaced them with a CG Lock. It's too bad it doesn't fit on the FRS/BRZ seat belts so it looks like I'll have to give Schroth more of my money.
Btw, I think the shoulder straps are supposed to go between the headrest posts.
AFRichZC6 is offline   Reply With Quote
The Following User Says Thank You to AFRichZC6 For This Useful Post:
glamcem (07-06-2014)
Old 07-06-2014, 09:04 AM   #3
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
I think either way will work with this harness because the shoulder belts come to a single point. If it were a harness with separate shoulder belts, I can see needing something to keep them from pulling off the shoulders. But with the Schroth design, as they tighten they'll pull together.
The Following User Says Thank You to Draco-REX For This Useful Post:
Old 07-06-2014, 01:22 PM   #4
glamcem
glamcem's Avatar
yes, and I think in the installation manual this is covered
Old 07-06-2014, 01:26 PM   #5
jebuwh
Village Idiot
jebuwh's Avatar
Drives: '13 FR-S Ultramarine Manual
I think I need this.
jebuwh is offline   Reply With Quote
Old 07-06-2014, 06:37 PM   #6
DaDr00
DaDr00's Avatar
Drives: '13 Whiteout FR-S
Just skimmed the NASA CCR and for HPDE, these belts are not certified for NASA HPDE/TT nor SCCA PDX. It makes me sad, because I was eyeing these exact belts for track days.
Originally Posted by NASA CCR
11.3 Required Safety Equipment - Driver
The only four-point belt systems that are allowed for use in HPDE / TT are 1) those that carry an “FIA B-xxx.T/98 certification, or 2) those that carry a label from the belt manufacturer stating that the belts meet Federal Motor Vehicle Safety Standard FMVSS) 209 *(which the Rallye 3 and 4 point have)* AND that the belts were designated for the specific vehicle (e.g. “For use only in BMW E36 models”).
The major argument that our local Race Director says is that you need at least a 5 point on track to prevent "submarining", or sliding under the lap belt.
Resources:
https://www.schrothracing.com/sdocs/...structions.pdf
http://www.nasaproracing.com/rules/ccr.pdf
http://scca.cdn.racersites.com/prod/...Level1-PDX.pdf
- '13 Whiteout FR-S
- '95 Toyota T100
NASA Mid South - Chief of T&S
DaDr00 is offline   Reply With Quote
Old 07-06-2014, 08:51 PM   #7
Sleepless
Sleepless's Avatar
Drives: 2014 BRZ
If they are not designed for the FT86 then I'd stick with stock, which in find to work just as well as the Rallye harness (had them in an M3 years ago). Just scoot the seat back a couple clicks, tighten belts, jerk the belt quickly to lock it, lean forward on belts to keep locked, scoot seat forward. Takes a little practice, but the stock belts can really hold you in quite well.
Sleepless is offline   Reply With Quote
Old 07-06-2014, 09:40 PM   #8
glamcem
glamcem's Avatar
Resources:
Did you know that the ASM stands for "Anti SubMarine"?
This is not your typical 3/4 point harness and they are DOT approved so if you can use your OEM 3 point in that specific event you should have no problem with using these harnesses also since they act like OEM 3 point in case of an accident by releasing the stitches and give you more room to eliminate submarine..
chroth Street Legal Harness Belt Questions
1. Are the Schroth Rallye line of harness belts really street legal AND how can I prove it?
Located on the plastic ASM mechanism on the inboard shoulder belt of each harness, you will see the letters/numbers "FMVSS 209". The DOT created this Federal Motor Vehicle Safety Standard (FMVSS) 209 and Schroth has certified that the Schroth Rallye belts meet or exceed that standard, and therefore are street legal.
http://www.soloracer.com/harnschrothfaq.html
on a side note, I wouldn't run any other harnesses such as 5 or 6 point versions without the rest of the required items such as proper roll bar( not a cheap harness bar), proper race seats and a HANS device since your body act like a stress member in case of a rollover ..so I say either 3 point harness that has the DOT cert. like these ASM harnesses or 5/6 point with all the required stuff otherwise you're in danger..
Old 07-06-2014, 09:40 PM   #9
glamcem
glamcem's Avatar
please see above post
Old 07-06-2014, 11:11 PM   #10
AFRichZC6
AFRichZC6's Avatar
I'm not sure of the distance between the headrest posts on the BRZ/FRS, but this is the only part of the manual that explains shoulder belt routing on the seat.
Old 07-06-2014, 11:16 PM   #11
DaDr00
DaDr00's Avatar
Alright, as long as your local sanctioning body allows it. I just don't want to see a fellow racer end up in a tragic situation like this:
http://www.ft86club.com/forums/showthread.php?t=34456
- '13 Whiteout FR-S
- '95 Toyota T100
Old 07-07-2014, 02:36 AM   #12
glamcem
glamcem's Avatar
accidents always happen and will happen unfortunately, what I am saying is this 3 point harness (unlike other harnesses 3,4,5,6 point doesn't matter) work like the OEM 3 point harness in case of an accident, is that the ideal/safest method even for an HPDE ? of course not but it's not less safe than the OEM seat belts, that's all I am saying, and your local clubs should allow you to use it since it's DOT approved ..
in an ideal world I would never drive without proper seats, full roll cage with flame suits, fire suppression system, HANS device, 6 point harnesses..maybe it would be a little overkill for an HPDE but I don't care safety first
Old 07-07-2014, 09:13 AM   #13
DaDr00
DaDr00's Avatar
As someone who just sold his 944 Spec car, I understand the value of safety!
I'll still probably get one for AutoCross. The only thing I can see on the ASM belts is that there's an extra piece of fabric on the shoulder belt ... how does that keep the lower half of your body from moving?!
- '13 Whiteout FR-S
- '95 Toyota T100
Old 07-07-2014, 11:33 AM   #14
xwd
I use the Rallye 3 for autocross.
There are a number of organizations however who won't let you use it for HPDE/PDX including the large ones like NASA/SCCA and I believe PCA. Heck the PCA even bans people from using them in autocross sometimes... They only allow 4-point (the Rallye 3 is still considered a 4-point) harnesses if they are specifically made for the car and have a label stating such. They don't really care about the Schroth ASM technology or believe in it.
They require you to have a 5-point harness and then using a 5-point isn't really that smart without a roll bar. Even though they let you run the car with a 5-point and no harness bar...
Schroth Rallye 3 Harnesses Draco-REX Cosmetic Modification (Interior/Exterior/Lighting) 66 09-01-2015 08:41 AM
Schroth ASM dp1 Tracking / Autocross / HPDE / Drifting 22 06-16-2014 05:01 PM
CG Lock, "Mighty Tight", Baby Seatbelt Clip, or Schroth Rallye 4? Kostamojen Tracking / Autocross / HPDE / Drifting 43 10-10-2013 08:10 PM
WRC Rallye Deutschland rumors Other Vehicles & General Automotive Discussions 1 08-27-2013 06:03 PM
