Old 07-04-2014, 08:38 PM   #1
Chronogps
Chronogps's Avatar
Drives: MX5 ND 30AE & A110
I made a mistake when unpluging the harness !
Here is the situation, the cables came out when I unpluged the passager side harness :
Problem : I don't know the exact order now...
I plugged the cables in this order but I'am not sure it is the right order :
Second problem :
Of course I did not plug the harness to the command pannel but now it is impossible to command the passager window from the driver side : Is it normal or did I broke a fuse when all the cables came out (the battery was not disconnected but the contact was off). If yes, which fuse I have to check ?
Thank you for your help !
Chronogps is offline   Reply With Quote
Old 07-05-2014, 08:00 AM   #2
Chronogps
Chronogps's Avatar
I found the solution on this forum :
http://www.ft86club.com/forums/showthread.php?p=1166113
http://www.mediafire.com/view/i1d82z...wer_Window.pdf
Here is the right cables locations :
In fact no need to unplug the cable : It is easier to remove the command panel :
The Following User Says Thank You to Chronogps For This Useful Post:
Pacific (07-05-2014)
**CIPHERAUTO HARNESS BAR AND SFI APPROVED HARNESS BELTS!** genometuning Interior Parts (Incl. Lighting) 59 01-09-2015 02:55 PM
Made a mistake, went to Wheel Works SeanBlader Northern California 8 03-13-2014 03:15 AM
Dealer made a mistake........what would you do? Dustin Scion FR-S / Toyota 86 GT86 General Forum 44 03-02-2013 12:23 AM
My First Mistake slizoth BRZ First-Gen (2012+) — General Topics 117 01-24-2013 05:19 PM
I made a terrible mistake in buying an FR-S for my wife. Storm_Trooper Scion FR-S / Toyota 86 GT86 General Forum 20 01-18-2013 02:20 AM
