Old 07-01-2014, 07:35 PM   #1
lbroskee
lbroskee's Avatar
Drives: 2023 WRB BRZ (MT)
custom A/V switcher help
so I'm trying to wire up a custom video switcher for my car to do exactly what this does (only need video tho)
here's the diagram that @MmmDieselFumes drew up a while back, but looking at it shouldn't +/- for each input be on the same relay and not 1 is all + and 1 is all -? just doesn't seem like it would work or it would try and activate half of each input this way
lbroskee is offline   Reply With Quote
Old 07-01-2014, 07:52 PM   #2
Flat Black VW
Flat Black VW's Avatar
Drives: 2013 Subaru BRZ
the diagram is correct. You want a separate relay for the negative wires and a separate relay for the positive. When the switch is turned one way it will activate the positive of video input one on one relay and negative for video input one on the other relay. When flipped the other way it will active the positive and negatives for the second video input.
Flat Black VW is offline   Reply With Quote
The Following User Says Thank You to Flat Black VW For This Useful Post:
lbroskee (07-01-2014)
Old 07-01-2014, 07:54 PM   #3
lbroskee
lbroskee's Avatar
ok cool thanks. also would these work for the inputs? can't find anything better or simpler
http://www.ambery.com/spwitorcaadk.html
Old 07-01-2014, 08:12 PM   #4
quark
You dont need to use relays.
You can simply just use a DPDT (Double pole Double throw) switch.
If you can only get a SPST (Single Throw) switch you can connect the grounds (-) together and just switch the signal / (+)
Also, if you do use relays, make sure you use a power diode across the coil, when the power is released from the coil there is large back EMF ~200V that can do damage to the electronics
quark is offline   Reply With Quote
The Following User Says Thank You to quark For This Useful Post:
Old 07-01-2014, 08:40 PM   #5
lbroskee
lbroskee's Avatar
so this is what i need right? also not totally sure what wire would go where in this as i've never used one of these
Old 07-01-2014, 09:01 PM   #6
quark
Yep, this is the most straight forward way to do it
Here is a drawing ive done that shows the back of the DPDT Switch
RCA to HU = out to Head Unit
RCA A = Source 1 , eg camera 1
RCA B = Source 2 , eg camera 2
Old 07-01-2014, 09:07 PM   #7
lbroskee
lbroskee's Avatar
looks easy enough. and i need on/off or on/off/on?
this seems right if I'm not mistaken
http://www.ebay.com/itm/2-Pcs-Black-...item51b7f9ce87
Old 07-01-2014, 09:19 PM   #8
quark
Yep, that would work, you need on/off, but cutting out the rectangle for that size switch may be a hassle
I would use a smaller toggle switch, you only need to drill one hole, and the hole would be easy to cover up later down the track if you dont use the switch anymore
http://www.ebay.com/itm/5-x-AC-125V-...item484f938d32
Old 07-01-2014, 09:29 PM   #9
lbroskee
lbroskee's Avatar
well thats just an idea. i prefer the flat style like that but round. and i put my switches on the tiny removable piece thats connected to center console under inner knee pad (cheap replacement part)
Old 07-01-2014, 09:46 PM   #10
quark
Cool, post some pics once your done
Old 07-01-2014, 09:47 PM   #11
lbroskee
lbroskee's Avatar
will do once i get all the parts. it's honestly already a completed project, i just wanna clean it up a bit
Old 07-07-2014, 04:24 PM   #12
lbroskee
lbroskee's Avatar
so i hit a snag. its all wired, feeds both work (tested it with my backup camera), but for some reason it won't read the input when i plug the SNES into it. tested SNES on laptop capture and the cable is fine. so the switcher reads backup camera fine, but won't read SNES. any ideas?
AT owners only, custom CF paddle shifters, pin stripe custom color BRZPDX Cosmetic Modification (Interior/Exterior/Lighting) 80 02-03-2016 10:35 AM
FS: Custom Acrylic Accents, $13. YOUR custom design! Cupholder and Mission Tray too! Diode Dynamics Interior Parts (Incl. Lighting) 155 11-19-2014 11:42 AM
My custom dash in my FRS joshuagranger Scion FR-S / Toyota 86 GT86 General Forum 92 09-05-2013 01:09 PM
Custom 86 sun visors? enjoi23 Cosmetic Modification (Interior/Exterior/Lighting) 1 04-29-2013 08:32 PM
Got my custom 86 oil cap from Grimmspeed in! Brimford Cosmetic Modification (Interior/Exterior/Lighting) 14 10-27-2012 12:25 PM
