Old 07-01-2014, 05:17 PM   #1
ExxelDistributions
ExxelDistributions's Avatar
Drives: 2014 FR-S 6MT Monogram Series
Need options
Hey guys so I couldnt find what im looking for with search.
I recently got my kw v3's installed. I am now looking into buying front and rear sway bar links and dont really know which one to go with and which one to stay away from. Also I will be looking into purchasing lower control arms for the rear and ive been looking into either the cusco arms or the stance lower control arms.
If you guys have any of these items installed or know about them please let me know about it and what brands to stay away from and what is a good product. Any input would help before I make a purchase.
Thanks in advance!
ExxelDistributions is offline   Reply With Quote
Old 07-01-2014, 08:48 PM   #2
ExxelDistributions
bump? anyone? help please?
Old 07-01-2014, 08:49 PM   #3
tahdizzle
So elite I'm 1338
Drives: WRB Subaru BRZ
Whiteline, cusco, or SPL in my opinion. Anything less is uncivilized.
Old 07-02-2014, 01:43 AM   #4
Cjymiller
Original 2013 Owner
Cjymiller's Avatar
Drives: 13 BRZ, Galaxy Blue Silica
well, You're in the right sub forum, but you just need to do a little reading and searching. Do your own research for what your needs are and you will find the product that is right for you.
Perrin Headerback, OFH, OFT, Ohlins R&T MI20, 17x9 Weds TC105N, Hankook RS4 (235/40), TOM's JDM Tails, PCV AOS, Perrin Crank Pulley, Perrin Rear Trans. Mount, Whiteline Shift Bushing, SS brake Lines, Hawk DTC60, Bayson R Lip Kit, LED Lighting , Smoked JDM Sidemarkers, Rear Fog Enable, Carsmo Armrest, Grimmspeed Plate Relocater
φφκα
Cjymiller is offline   Reply With Quote
Old 07-02-2014, 01:50 AM   #5
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
seems like you want to buy sways for the sake of buying them
bad place to start
tell us what is it about the behavior of your car that you don't like and then maybe we can help you
Old 07-02-2014, 03:07 AM   #6
ExxelDistributions
bad place to start
not into buying for just buying it. the reason is after lowering the car with the kw's the links are really close to the LCA's in the front and when you go over bumps it hits the LCA
Old 07-02-2014, 10:36 AM   #7
Jive Turkey
the tuna, no crust.
Jive Turkey's Avatar
Drives: 2014 Hachiroku of the year
did you slam the car? i had v3's and was relatively low and never had an issue.
as for rear LCA, i have cusco, and i hate them. adjusting them is incredibly annoying. go with SPC and call it a day, they are cheap and they work. you might need toe arms too.
as for sways...well we dont know how you drive and what you like the car to do (over/understeer)
Jive Turkey is offline   Reply With Quote
Old 07-02-2014, 10:45 AM   #8
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
any of the adjustable endlinks will generally work.
you can even make your own using industrial grade rod bearings.
but I'm always surprised to hear people say that the swaybar hits the control arms because the control arms move with the strut and the swaybar is attached to the strut... and in the rear the swaybar is attached to the control arm so it should move with the control arm..
where is the point of contact?
Old 07-03-2014, 04:04 AM   #9
ExxelDistributions
it isnt completely slammed. i just dropped it to the point where i dont have wheel gap. it is possible that it is not hitting at all. but the last time i had the car up on a hoist when doing my oil change and i noticed the sway bar link really close to the front LCA. the rear cant hit because it is mounted on the LCA.
Old 07-03-2014, 09:54 AM   #10
MyEvilMonkeys
Drives: 2013 Scion FRS
Originally Posted by Jive Turkey View Post
I have cusco, and i hate them. adjusting them is incredibly annoying. go with SPC and call it a day, they are cheap and they work. you might need toe arms too. (over/understeer)
I second this... Cusco seems to have the quality, but adjusting them requires dropping one end... twistie twistie... reinstall... nope not perfect. drop it again... adjust some more. The alignment shop hates me for it and charged an extra 50.00 on top of the standard alignment fee. But once they are dialed in you will have no worries if you don't have a need for constantly adjusting for track days etc.
I didn't have much luck with SPC Rear LCAs due to camber setting slipping.
...and yes you will need rear toe correction beyond what the stock adjustment can offer with anything around 1.75" or more. For this I did go with SPC rear toe arms and very happy with them and they have easy precise adjustments.
FA500 Coils/Swift/Radial Upgd, Cusco R.LCA, SPC R.Toe Arms, TqSol. R.SubFrame Bushings, MTEC Shift Springs, Perrin Shift Bushing/Trans Mount, Greddy SP Exhaust & Intake, RPF1 18x9.5 +38, 255/35-18 SDrives, Raceseng Ashiko Knob/Lockout
MyEvilMonkeys is offline   Reply With Quote
The Following User Says Thank You to MyEvilMonkeys For This Useful Post:
Jive Turkey (07-03-2014)
Scion FR-S options:what options did you have dealer installed? Scionshaun Scion FR-S / Toyota 86 GT86 General Forum 42 01-06-2014 02:35 AM
Bushing upgrades, geometry options and other component options? der_rainman Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 06-26-2013 01:53 PM
Canadian FR-S options VS U.S.A's options? Tino Scion FR-S / Toyota 86 GT86 General Forum 15 11-06-2012 11:07 PM
FR-S Options? GED68 Scion FR-S / Toyota 86 GT86 General Forum 18 03-23-2012 01:32 AM
Gearing Options and Diff options airboy808 Engine, Exhaust, Transmission 26 12-25-2011 02:11 PM
