Old 06-30-2014, 09:10 PM   #1
Kurtz
Kurtz's Avatar
Drives: Subaru BRZ
Is thermal insulation recommended for aftermarket catback exhaust?
My BRZ is the first car to which I’ve considered adding an aftermarket exhaust system (just a cat-back for now). Based on the photos in a number of installation threads, I am a little concerned about the heat effects of reducing the air gap between the exhaust pipe and the walls of the transmission tunnel and components adjacent to the exhaust.
Would adding some thermal insulation, at least for the first few feet downstream from the catalytic converter be recommended?
Is there a particular type of insulation that would be recommended for this application? An example of what I was considering is something like this: http://www.heatshieldproducts.com/au...rs/lava-shield
Kurtz is offline   Reply With Quote
Old 06-30-2014, 09:37 PM   #2
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
Not a single bit necessary IMO.
Old 06-30-2014, 11:33 PM   #3
car_roll
Drives: Nuisance BRZ
^ This. You shouldn't have a problem at all
#teamnuisance
I do like, YouTube or something, IDK.
Shameless Plug
car_roll is offline   Reply With Quote
Old 07-01-2014, 08:18 AM   #4
industrial
Add lightness!
industrial's Avatar
Drives: 17' WRX
Anywhere the factory exhaust has a heat shield, you should also make provisions to manage heat. On this car the header and overripe are probably the most important areas. I like themotec turbo heat wrap and dei titanium heat wrap for products.
industrial is offline   Reply With Quote
Old 07-01-2014, 04:19 PM   #5
grodenglaive
Drives: asphalt FR-S
heat shields if you must, but don't wrap the pipes.
http://www.centuryperformance.com/ex...o-not-use.html
grodenglaive is offline   Reply With Quote
Old 07-01-2014, 07:10 PM   #6
Kurtz
Kurtz's Avatar
Drives: Subaru BRZ
Thanks all for the feedback. For the time being I am leaving the factory heat shrouded components alone. If I ever swap things in the under hood exhaust I've seen a few threads discussing heat issues there that I can refer to.
Old 07-01-2014, 07:33 PM   #7
kodyo
Drives: Scion FR-S
Anyone tried reusing the OEM heat shielding? I haven't replaced the header yet (Ft86SF header on order and you know the wait times on those), but thinking of trying to reuse if it's at all possible.
kodyo is offline   Reply With Quote
Old 07-01-2014, 07:35 PM   #8
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
overpipe and header is the only thing that needs heat management products.
Any Stock Catback Exhaust Soundclips? w/ aftermarket header + op + catless fp fooddude Engine, Exhaust, Transmission 11 08-11-2016 07:18 PM
Recommended aftermarket mufflers/resonators on stock exhaust BlueDubbinTDI Engine, Exhaust, Transmission 10 09-14-2013 10:39 PM
Recommended Tire Pressure for Aftermarket Wheels and Tires Chri5 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 05-15-2013 02:28 PM
Are there any good/recommended aftermarket stereos? redwing634 Electronics | Audio | NAV | Infotainment 23 09-30-2012 03:29 AM
