Old 06-30-2014, 05:37 AM   #1
FT86_AU
BRZedit
Hi guys,
Anyone ever seen the vvti stop working after a reflash? Have tried the warm up at idle after flash etc. but still nothing. I can see the vvt target in the logger but no actual cam values.
Thanks
FT86_AU is offline   Reply With Quote
Old 06-30-2014, 06:01 AM   #2
Kodename47
Kodename47's Avatar
Drives: UK GT86
Exhaust and intake?
Exhaust cam only seems to become active once the oil hits 30C from what I've seen.
.: Stealth 86 :.
Kodename 47 DJ:
Old 06-30-2014, 06:15 AM   #3
FT86_AU
Yes both in and ex although the inlet cam never shows any targets. Just sits on zero
Old 06-30-2014, 07:00 AM   #4
steve99
Originally Posted by FT86_AU View Post
Hi guys,
Thanks
After you flash always turn ignition off then on for 20 sec then start and let idle do not rev or touch accelerator for a minute or so till normal idle achieved. This allows ecu to run through its initial diagnostics and calibrations, if you drive straight off ir will disable vvt.
It should sort itself out if you turn off and then on then let idle, unless you flashed a weird cam table or something.
Does the car run ok , as if vvt disable it would be down on power.
maybe logger setup does not match rom type ?
Old 06-30-2014, 07:51 AM   #5
FT86_AU
Just flashed the stock cal in. Been trying the 20sec and let it come back to a normal idle before doing anything. Still no success..
Old 06-30-2014, 08:51 AM   #6
4wheelinls1
Tuner
4wheelinls1's Avatar
Drives: GT 86
I have had some issues picking up the exhaust cam after a flash, as steve99 said just let it idle, I give the throttle a little blip after 20-30 seconds and it starts to become active.
4wheelinls1 is offline   Reply With Quote
Old 07-03-2014, 06:20 AM   #7
FT86_AU
Tried the 20-30 seconds.. Nothing. Very strange. The extra strange parts is no matter what I do to it on the dyne no cams. Take it of and drive it 200m down the road and stop, the cams start working.... Frustrating
Old 07-03-2014, 09:53 AM   #8
banane63
banane63's Avatar
Drives: BRZ Club blanc perle
No cam movement below 75° oil temp...
Collecteur et frontpipe Supersprint full décat - Catback Remus
Admission directe Greddy - Kit Flexfuel et map Ecutek Visconti Tuning - Tein Street Advance EDFC Pro - NED modine - OZ Alleggerita 18 Michelin PS4 - Wilwood 6 pistons
banane63 is offline   Reply With Quote
Old 07-05-2014, 06:15 PM   #9
MFB
Avo Turboworld Phil Rep
Drives: Forester 2009 XT on e85
After a reflash , I just wait til Afr sensor ohms settle to normal at around 46 ohms. That's usually done while idling.
MFB is offline   Reply With Quote
Old 07-06-2014, 03:28 AM   #10
FT86_AU
Thanks for all the replies. Still no luck getting it working though.
Can someone who is using brzedit give me a step by step through flashing in case if have something wrong?
Old 07-06-2014, 07:25 AM   #11
brn12345
brn12345's Avatar
I've been using BRZedit for a long time now and probably flashed my ecu over 30 times. Never had an issue as you described. Cams come in about 15-20sec after starting.
2013 Lightning Red - 6MT
Perrin Inlet Hose ~ TRD Panel Air Filter ~ OEM Modified Snorkel ~ Revolution 4-2-1 EL Header ~ HKS Resonated Front Pipe ~ BRZedit self tune ~ KW Clubsport Coilovers ~ AP Racing Big Brake 4 Piston ~ Whiteline Front Endlinks ~ Perrin Rear Endlinks ~ WedsSport TC105N 17x8 42+ ~Dunlop Direzza II Star Spec 225/45/17 ~ STI Trunk Lid Spoiler
brn12345 is offline   Reply With Quote
Old 07-07-2014, 08:47 AM   #12
FT86_AU
Flashing and then driving seems to work. Anyone with brzedit tuning on a dyno?
Old 07-07-2014, 09:02 AM   #13
steve99
2 wheel dyno ??
only thing I can think of is front wheels not turning while back wheels are upsets ecu for some reason (traction/stability ?) soon as you drive off all ok.
dont think it would be a problem unique to brz edit as flash process is same for other tuning platforms, although I believe brz edit can do a partial write.
Old 07-07-2014, 11:23 AM   #14
MAPerformance
Drives: Asphalt FRS
We tuned our turbo kit with BRZedit on our dyno, but did not recall ever having this issue. We will be tuning another on here this week. I will see if we have that issue.
MAPerformance is offline   Reply With Quote
BRZedit E85 How-To mad_sb Engine, Exhaust, Transmission 9 04-24-2020 09:30 PM
BRZEdit (ECUEdit) illmatic Software Tuning 246 06-02-2016 01:15 PM
BRZedit and boost. (also wondering BRZedit vs ECUtek with boost) NickFRS Software Tuning 43 03-10-2014 04:10 AM
BRZedit - My thoughts so far brn12345 Software Tuning 33 02-13-2014 07:36 PM
BRZedit Help Sojhinn Software Tuning 2 10-29-2013 11:40 AM
