Old 06-27-2014, 09:52 PM   #1
dvsidboy
Drives: 2013 Subaru BRZ
DIY - RacerX Fabrication Lower Control Arm
RacerX Fabrication sent us a sent of their Lower Control Arms for the NWMotiv Project BRZ, will help us continue to dial in the suspension and just in time for the SCCA Pro Tour in Packwood, WA.
The quality of these parts is amazing and the service has been top notch, for anyone in the market for Lower Control Arms, these should be on your list. The price is not bad either for the set. Head over to http://www.racerxfabrication.com to check them out.
Tools Needed:
14mm Wrench and Socket
17mm Wrench and Socket
19mm Wrench and Socket
22mm Wrench
Crescent Wrench (larger one)
Our install photos will show the rear bumper removed. This is not needed, just made it easier for photos
STEP ONE:
Jack the car and secure on jack stands. The remove the rear wheels.
STEP TWO:
Start to remove the stock Lower Control Arm. All bolts were 17mm, however if you have stock End-Links, this bolt may be 14mm.
We went from the outer bolt and work our way in.
STEP THREE:
Take the stock Lower Control Arm and Line Up the wholes on the new Lower Control Arm, this will make install a bit easier.
Getting the new LCA ready to install, the RacerX Fabrication LCA will come with 2 new 19mm Bolts for the hub and shock, it will also come with a new 17mm for the end link. For the bushing on bushing on the end we just used the stock bolt.
STEP FOUR:
Start to install the new LCA, we started from the inside and worked out way out.
Once all Bolts are in start to tighten them down.
STEP FIVE:
Repeat on the other side of the car.
Once installed you can make adjustments in to the camber using a 22mm wrench, however most people should have this done at an alignment shop. Use your crescent wrench to tighten the ends of the LCA to insure they dont move on their own.
STEP SIX:
Put wheels back on the car and lower back to the ground. Then head to your local alignment shop and get the car aligned, you will want to do this before doing lots of driving as your camber/toe will be not to spec.
Final Photos
I will leave some feedback after the first alignment and after the Pro Tour next weekend.
Thanks for looking and hopefully this will help you with your LCA install, its a pretty easy and quick install.
dvsidboy is offline   Reply With Quote
Old 06-27-2014, 10:17 PM   #2
cnk
Drives: '13 DGM BRZ Limited
Nice write up. I like to load the suspension before torquing everything down to spec. The only bolt/nut that you may want to torque to spec while up in the air is the LCA to hub connection as there isn't much room once you put the wheels back on. I usually torque the outer nuts, put the wheels on, lower onto some ramps, bounce the car a few times, and then torque everything down.
cnk is offline   Reply With Quote
Old 06-27-2014, 10:22 PM   #3
dvsidboy
Good call. With the rear bumper off, I have lots more room to still get this done (no ramps) or might do the tightening at the alignment shop, very little drive to get there (basically 3 minutes and straight driving).
Old 11-13-2014, 12:56 AM   #4
bjun
bjun's Avatar
Drives: white premium brz M/T
Do you know the torque specs for the bolts by any chance?
bjun is offline   Reply With Quote
Old 01-26-2015, 11:36 AM   #5
Turkish
Serial Cone Killer
Turkish's Avatar
Drives: '14 BRZ - WRB Premium 6MT
This DIY for the lowering springs, towards the end it has the torque spec for the strut to LCA bolt. I know this is not exact, but my working assumption is the other bolts would be the same. Not sure for the bushing to bushing bolt though...
For those who hear him call...
... his name is...
C'THULHU
Turkish is offline   Reply With Quote
Old 08-29-2015, 10:16 PM   #6
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
this will be handy when i install coilover +LCA at same time
Old 09-07-2015, 12:25 PM   #7
Brzzee
Brzzee's Avatar
Drives: 2015 Subaru BRZ WRBP Limited 6MT.
When u planned the swap did u consider adding whiteline's replacement bushing for the spindle side of the LCA? Your thoughts on doing the bushing swap in conjunction with the LCA install please.
Brzzee is offline   Reply With Quote
Old 05-19-2017, 08:55 PM   #8
SuperTom
SuperTom's Avatar
Drives: C5, GT-86, '24 Colorado TrailBoss
Thank you for the write up
Will be attempting this install tomorrow along with MeisterR Coilovers. I'm thinking I might be able to semi-preload the suspension by jacking up that side and then bolting everything down witht the tires off.
SuperTom is offline   Reply With Quote
RacerX Upper Control Arms Review DAMotorsports Suspension | Chassis | Brakes -- Sponsored by 949 Racing 33 05-27-2024 05:13 PM
FS: RacerX Front Lower Control Arms hybridcmk Brakes, Suspension, Chassis 7 07-08-2014 02:10 AM
New Racer X Fabrication rear lower control arms! Jeff@Racer X Fab Suspension | Chassis | Brakes -- Sponsored by 949 Racing 36 04-28-2014 05:56 AM
Racer X Fabrication: Upper rear control arms, in stock/ready to ship!! Jeff@Racer X Fab Brakes, Suspension, Chassis 25 01-24-2014 11:42 AM
WTB: Front Lower Control Arm and Rear Upper Control Arm YDNA Brakes, Suspension, Chassis 0 11-10-2013 04:40 AM
