Old 06-26-2014, 12:12 PM   #1
scirocco78
Drives: Scion FRS
Even out rear camber stock class legal?
Is there any way to even out the rear camber and stay SCCA C Street legal?
scirocco78 is offline   Reply With Quote
Old 06-26-2014, 12:15 PM   #2
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
even out to what, side to side, or bring back to zero?
if it's side to side you can try shifting the rear cross member but that's waaaayyy too much work.
Old 06-26-2014, 12:30 PM   #3
scirocco78
Drives: Scion FRS
Side to side.
Old 06-26-2014, 01:26 PM   #4
bimmer635csi
bimmer635csi's Avatar
Drives: 2013 Cayenne turbo
For Street classes, you are allowed to set camber and toe anywhere you like, so long it is in the manufacturer's specified range.
You are not allowed to cut the car apart to do it though and to be honest, I question the legality of crash-bolts on the fronts if they put you out of range.
See Rule 13.8.B on page 75 of the rule book for a reference.
bimmer635csi is offline   Reply With Quote
Old 06-26-2014, 02:10 PM   #5
scirocco78
Drives: Scion FRS
I don't need the rules. I need to understand this car. I'm not new to auto-x or the rules just this car.
Is there a way for me to even out the camber from one side to the other that is within the rules of street. The only solutions I have found are not legal. Example lower control arms.
Old 06-26-2014, 02:12 PM   #6
scirocco78
Drives: Scion FRS
Where can I find info on this?
Old 06-26-2014, 02:15 PM   #7
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
loosen the 4 bolts holding the crossmember to the chassis then try to shift it
but effect will be microscopic..
how much of a variance in camber do you have, and is it done with weight in the trunk and passenger in the car?
Old 06-26-2014, 02:22 PM   #8
scirocco78
Drives: Scion FRS
-0.8 drivers side and -1.6 passenger side with someone in the drivers seat, no spare tire and 1/4 tank of gas.
Old 06-26-2014, 06:14 PM   #9
xwd
Yeah like 7thgear said the best you can do is try and shift the actual crossmember. There are no other adjustments to be made. It's pretty easy to loosen the crossmember, just the four bolts.
*FREE alignment* with Purchase and install of Front Camber / SPL Rear Camber Arms! Corner3garage Southern California 188 04-24-2015 01:10 PM
Scion FR-S legal for the new Pirelli World Challenge TCA class Rampage Scion FR-S / Toyota 86 GT86 General Forum 1 03-06-2014 11:06 AM
*FREE alignment* When you get Front Camber Bolts and Rear Camber Arms Installed! Corner3garage Mechanical Maintenance and Tools 6 10-31-2013 03:40 PM
