Drives: Scion FR-S 2014 Firestorm
OEM Audio Plus Reference 400CF Problem need help!!!
I installed my oem audio plus refence 400cf system in my FRS last week and while I was testing it I remark that my front speaker (passenger door panel speaker) wasen't working.
I re-open the door to check the connection but everything was fine. Since my driver side speaker was working I swith both speaker of place and still my passenger side wasn't working. I have double check the connection of the by past connector of the factory amp under the trunk mat but everything was fine. When I pulled it completly the driver side wasn't working either. So i have decide to reconnect all the factory harness in place to by pass the sub amp (factory harness behind the radio and factory amp fully connected under the trunk mat). In that position both door speaker were working and of course my sub wasn't. Do some one have any idea what is going wrong with my set up? @oemaudioplus
«You could drift this car while reading a book. So I did!»
-Jeremy Clarkson |
#2 | |
Drives: http://bit.ly/Vantage86
Sounds like your Reference Adapter is not installed properly. Please see Page 9 of your O+ Installation Manual for detailed steps or better yet, the below image (for your consideration): ![]() Sorry for any confusion. Please be sure to update this thread with your feedback once everything's dialed-in. For additional questions or requests please call 855-636-6346 X4 |
I have rechecked all the connection and everything is in place, even the reference adapter, and my driver door speaker is working but not the one on the passenger side...
-Jeremy Clarkson |
Thanks for verifying @maxfun. Are you available for a call to allow us to better assist in troubleshooting your kit?
@oemaudioplus I was going to call you today so I removed my trunk mat before calling you and I checked the reference adapter one last time. I saw that one of the pin was slighty off set from the others so i pull it back in place and TADAM everything is working now!
If someone who want to buy the system end up on my tread I want you to know that i give a 100% positive feedback! The system is great and worked the first time that I plug it in. It seems to be on the high end for price but let me tell you that it worth every penny! If you are in montreal region Canada I will be glad to let you ear it before buying it! and if @oemaudioplus want to test fit any product on a canadian model i'm all yours ![]() Thanks for the help!
-Jeremy Clarkson |
Drives: FRS
Off original topic completely, does that just bypass the factory amp completely and power the doors off the head unit?
@maxfun, Thank you for the update and for your kind words!! We really put our ALL into every sound solution we create. It means the world to is that you're enjoying your O+ Reference 400CF.
Enjoy! OEM Audio Plus |
#8 | |
-Jeremy Clarkson |
| Tags |
| oem audio plus reference |
| OEM Audio Plus Reference 400CF (BRZ) | Area86 | Audio/Visual, Electronics, Infotainment, NAV | 18 | 12-29-2014 11:47 PM |
| ca-fi Dashlinq 4/OEM Audio+ Reference 400CF | Fastbrew | Electronics | Audio | NAV | Infotainment | 13 | 10-04-2014 03:27 PM |
| OEM Audio + Reference System 400CF review! | czechm8 | Electronics | Audio | NAV | Infotainment | 9 | 06-10-2014 03:12 PM |
| OEM Audio + Reference System 400CF | czechm8 | Electronics | Audio | NAV | Infotainment | 7 | 05-08-2014 11:43 AM |
| FS: OEMAudio Reference 400CF | 6spd | Audio/Visual, Electronics, Infotainment, NAV | 5 | 04-05-2014 10:49 PM |
