Old 06-22-2014, 01:57 PM   #1
dejxx
dejxx's Avatar
Drives: FT-86
CEL after OFH+OFT
Around 1 and a half months ago i put my OFH on the car... flash it to stg 2 and was all good. Today after some road driving im getting my first CEL ever.
How can i fix this? read the code?
Currently im in Brazil, where this car isnt imported officially, and the nearest car dealer authorize to work in the car is 1200km away. Big problem...
Any help would be appreciated
dejxx is offline   Reply With Quote
Old 06-22-2014, 02:04 PM   #2
cnk
Drives: '13 DGM BRZ Limited
Use your OFT and read the code. No one can help you if we don't know what the code is.
Sent from my SAMSUNG-SM-N900A using Tapatalk
cnk is offline   Reply With Quote
Old 06-22-2014, 02:09 PM   #3
dejxx
dejxx's Avatar
Drives: FT-86
how do i read the code? just connect and hit read?
Old 06-22-2014, 02:15 PM   #4
cnk
Don't remember off the top of my head. Just connect it and go through the menu options. Should be pretty obvious.
Old 06-22-2014, 02:32 PM   #5
dejxx
dejxx's Avatar
Drives: FT-86
When i go to diagnostics, my gt86, ECU fault codes, it throws code P0420, wich seems to be for something related to my cat... Which i dont have... Since i have OFH. So should i just tell it to clear the code? Or reflash stg 2 again?
Old 06-22-2014, 03:01 PM   #6
Malt
Drives: 2015 WRX
You more than likely have an exhaust leak if you are getting that code with a stage 2 flash.
Sent from my SCH-R970C using Tapatalk
Malt is offline   Reply With Quote
The Following User Says Thank You to Malt For This Useful Post:
alexand3r (06-22-2014)
Old 06-22-2014, 03:17 PM   #7
alexand3r
Custom User Title
alexand3r's Avatar
Drives: Spaceship
I agree with @Malt, had one on my car the first time I installed my header.
Did you use new gaskets?
Any which way, it's probably best to check your header bolts after 2-3 heat cycles as they loosen up a bit. Also, don't forget to check that the o2 sensors are tight.
alexand3r is offline   Reply With Quote
Old 06-22-2014, 04:22 PM   #8
dejxx
dejxx's Avatar
Drives: FT-86
Got it. I uses new gaskets provided with the OFH. After install i never reajusted the bolts, so that might be the problem. Ill take it to the mechanic tomorrow morning.
After tightning everything should the code just go away? Or do i need to clear the code with OFT?
Old 06-22-2014, 04:31 PM   #9
Malt
Drives: 2015 WRX
Just clear the code and you should be fine.
Old 06-22-2014, 04:34 PM   #10
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Hi,
You will just need to disable that particular code in Rom Raider. I think a few Stage 2 rom files slipped through the cracks with it still enabled. If you email me (shiv@vishnutuning.com) your CAL ID, I can do it for you.
Old 06-22-2014, 05:45 PM   #11
dejxx
dejxx's Avatar
Drives: FT-86
Shiv, whats the CAL ID, and how can i find it? (noob here). So i shouldnt take it to the mechanic to tight everything up? or should i just in case?
Old 06-22-2014, 06:25 PM   #12
steve99
pressing the info button under my car should show you calid
Old 06-22-2014, 07:02 PM   #13
dejxx
dejxx's Avatar
Drives: FT-86
Vish, just sent you CAL ID, let me know if you got it. Thanks!
Old 06-22-2014, 07:55 PM   #14
Shiv@Openflash
Drives: 2013 FRS
Currently in Hawaii with the wifey. And away from a laptop. But I'll be back home tomorrow and can update the stg2 file for you
