Drives: Many types of cars in R&D.
A little bit about Winmax Brake pads, and other Japanese made brands for the FRS/BRZ
As a Winmax USA technical representative and testing engineer as well, I'll pitch in some honest advice (which is what I do regardless as I don't tarnish my own Club4AG history on account of any product)
I'm a technical rep and less a sales figure for any consulting work I do for respective manufacturer, so I will be honest in my product explanation. My smile comes from happy satisfied people who spent money with proper knowledge and got what they wanted and sought when they contemplated. So I will post cons as well as pro's on matters, so that every product purchased does meet the needs of buyers. Honestly here is what Winmax USA's W-Series line of brake pads provides for FRS/BRZ owners and respective application. W1 - It is the closest application to stock braking feel, it has least amount of dust, and are silent. The braking performance is on par with stock pads, which are already very good in terms of general feel and braking power as far as OEM grade pads are concerned. What the OEM pad lacks is integrity after abuse however. The OEM pads fall apart after cooking them hard on a raceway, and while the performance was there initially, the materials that hold the brake pad friction materials tend to cook, and surface that mates the disk rotors tend to disintegrate, and feels like it is fading from heat, when it really is the integrity of the pads that are at fault. (If you haven't had this happen, you aren't braking long and hard enough in your use cycles and that's fine by parameters of OEM pad design.) What the W1 will do for you is prevent this type of fade and while slight fading can be expected for street application brakes from high temps, the fade rate is much more consistent, predictable, and will not fall apart like the OEM brake pads. The W1 is therefore, made for those who like to abuse the car a bit further than an average consumer of generic cars, and is intended to make the car feel not too much different in day to day use. Compatible with autocrossing on stock or summer radial tires. ___ THe W2 is a step up from the W1. It still provides a very consistent feel of the stock pads, use parameters are the same, where it is mainly designed for street use, but with a lot more overhead and the most sporting of the pads that are still non-metallic. Because it is non-metallic like the W1, it has no significant dust issue or noise levels to be concerned. W2 increases driver control feel, a bit more bite, and higher temperature ranges and predictable fall off for when it does fade eventually. You get a slightly better sporting use characters, and endurance, but still without the concerns associated with racing brakes. Perhaps the best I can recommend if you are a typical casual Sunday low speed track folk, or auto-crosser, and still predominantly daily driven car, on summer radials. It is also a good economical upgrade. It's minimal requirement too, if you are a down-hill canyon enthusiast. ___ W3 is the most economical grade of so called, "metallic pads" which introduce a ton more braking control, very different bite characters that are more intended for track conditions, and use of race compound tires. If you are an avid track driver, or semi-professional autocrosser, this is where you'd start to see very positive and racing use braking forces. Of course, as with any metallic compound mix brake pads, you will encounter increased rotor wear, noises, and black dusting, and daily driven role becomes more a secondary use. It's still perfectly safe for street, as long as you can deal with dust and slight noises. Some can, others abhor it... That's just a choice for what people place as priority. W3 is VERY capable on the Sunday race scene, totally fir for those who use the brakes to 100% capacity, and driving skills to take it there. Autocrossers and canyon runners will feel a new level of control and bite, that extended consistently into very high temperature ranges. It does strike an exceleent balance for those that need a daily driven brake pad, and are not willing to forgo any performance, at cost of a bit of noise, dust, and slightly higher wear rate. ___ W4 is similar to the W3, but adds yet a bit more braking bite, and prove a bit more endurance in longer sessions. The W4 will lap consistently, longer than W3 with similar feel. This is also a brake pad that starts to need a bit of caution for daily drivers, as very cold braking does feel slightly looser than at proper temps that is 50~100'c that it needs to be at before it is working as designed. Not an issue once accustomed to it however, even for daily driving. It does however, wear both rotors and pads at slightly higher rate, in exchange for all that super precise braking control and constant bite at all temperatures. While application for other cars with tiny calipers like S2000 or heavier cars like Impreza the W4 is made to feel like the W3. For the FRS however, it does tend to feel a bit leaning towards being track dedicated in use, and cost-performance. ___ And your question must now be, what is W5~W7? Well they are strictly designed for track dedicated use. These are very highly specialized high-metal content pads that are made for race tire operation, and rally and endurance conditions where grueling braking forces are applied for hours on end. W5~W7 exists in 3 grades for users to balance a preferred character, and also to tailor it exactly to the needs of a particular track, and stage. AS with any brakes, it can be used for the street, but the design intention being very far from this, it will not be a very good candidate for street spec with high levels of wear, and noise, as well as inconsistent performance when they are very cold. These are all about ultimate racing environment, and there in the right elements, they are one of the best, most economical and competitive choices for serious racing teams. ______ Overall though, the Winmax brake pads are typical in feel to other Japanese made pads. Japanese brake pads have a character of its own, and use very exotic materials that are different in some ways than pads made in other regions. Each region/nation has brake pads made from whatever makes business sense due to local availabiltity and costs on the ingredients for friction materials. In the case of Japan, most brake manufacturers including Winmax (parent firm MK Kashiyama) as welll as Project Mu, and Endless are all based in the locale of Nagano Prefecture. They have always been a center for manufacturing of exotic materials, compounds, and ceramic/ metallurgy experts from centuries ago, from pottery, to founding, blending, casting, and forging of various military tools. This reflects on very careful approach is the character of the people who keep up the research on how to blend things for a specific use. They have a deep knowledge of what goes into a brake pad at at higher price point, and different, from other large firms elsewhere, and do have the craft of making certain pads work across a wider range of uses than would be possible with more a generic singular approach to making brake pads. The Japanese craftsmen, as well as Japan's larger consumer base, is very particular and fussy about how thing are made and how they work. And this usually has an effect on design and approach, and character of the final product to be very well thought out, and without sparing expenses where reasonable... AS such, the Winmax Brake pads compare closely to those of more established names like Endless or Project Mu, and do feel a bit different than Hawk, Carbotech, Ferodo and similar brands from more mass-marketed European and American pads. While at the peak performance specs, all competing and competent brake pads from various firms can show highest rated-use specs numerically, it is the range of uses below those figures, and how it feels on your feet as driver in controlling that. So while specs may seem very similar just by looking at the catalogs, what should be carefully viewed is the intrinsic of how drivers interact with the brakes is rather non-numerical. And with Winmax W-Series, I think they hit the right balance of product choices, and price-point while giving enthusiasts a chance at getting the feel of sophisticated blends that Japanese brake pads are known for. Bottom line, basically is that while cheaper or more expensive pads will perform to expectations on what is stated on catalogs, but how they feel getting there, is something that is an art of the manufacturers and their craftsmen. For the Japanese made pads like Winmax, there is that character that is unique, and this is really the element where people might pay a premium over less costly ones, or forgo more expensive ones in the same breath. Any good brake pads from any reputable makers is a good choice, as long as you bought what you needed for the intended role, and the choice suffices or exceeds the expectations. Winmax is just one of them among many.
Moto Miwa
R&D Driving Engineer, Product Designs Consulting for Cusco, OEM+, RS-R, Toyota Japan, and Unplugged Performance. |
Drives: AE86, 2x GT86, TE27
I have not used winmax, but I find Endless pads exceptional.
Yes, and more so because you bought the right compounds and blends for what you need it for, and how you want the brakes to feel. More than the choice of brands, as one brand can offer many very different pads for the consumers in various and very specific needs.
Moto Miwa
AutoX-10/10ths every run
Disclosure: I am sponsored by Winmax.
I've been running the W3 pads all around since fall of last year. I autox 1-3 times a month, and daily drive my car. I've put at least 200 autox runs and 10000 miles on these pads and I love them. Yes they will make a bit of noise on occasion, and they do generate a bit of dust, but they work so well on my car. I ran Hawks up front before switching to the W3s, and I can say that the W3 does not have the same initial bite that the Hawks exhibited, but they are way more modulate able throughout the pedal stroke. I've used them with MPSS tires on the street, Z2s/Federal 595 RSRs/BFG R1S tires on the autox course. In every case they were very predictable and controllable. Now, I've also modded other parts of my braking system. These mods include Stop Tech Slotted front rotors and SS lines all around, a Grimmspeed MCB, and Motul 660 brake fluid. I've had passengers on practice days and during X runs repeatedly comment on how good the brakes are in this configuration. See the end of this video (1:28) for an example: [ame="https://www.youtube.com/watch?v=RPO8dovBpFk"]DCCSD Champ 1st X run - 2.16.2014 - 63.462 - YouTube[/ame] If you are in the market for a brake pad upgrade, please consider the Winmax pads, I really like mine. Hope this helps.
Drives: Toyota 86 TRD Version AT
@Moto-P, I have been using the Acre 900C for some time now and it has been great. How does the winmax compare to them?
Boosted Member
Drives: 2013 SWP BRZ Limited
Looks like I made the right choice getting W2's. So far they feel good!
Suzuki Swift GTI '89, Subaru Impreza L '96, Lancer OZ '03, Subaru Impreza WRX '06, Honda CBR600RR Graffiti, Volvo c30 T5 R '11, Subaru BRZ '13, Audi RS4 2007
SUV's: Mercedes Benz R500 '06, Mercedes Benz ML350 '12 |
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
The stock pads are okay, but I keep finding myself wishing there was a little more stopping going on. I'm on tires that are in between stock and sticky street tires designed for track use (like RS-3's), they are slightly more towards the track based tires than stock side, but in 205/45-17 size. What street pads should I be looking at if I want a little more initial bite and overall bite than stock but less initial bite than Hawk HP+ give; Winmax W3, Project Mu B-Force, or maybe stretch to Project Mu HC+800 [would this be too much like Hawk HP+]?
What's the coefficient of friction range (cold-hot) for the stock pads?
Had a '13 FR-S Asphalt 6spd manual (bought new 5/25/12, sold 6/10/20) but needed to let her go... she will be missed.
Drives: '13 SSM BRZ Limited 6MT
Nice post. I've been looking into better stopping power but have been undecided on getting new tires (Michelin PSS) first or new brake pads (would I need front AND rear?). I don't autocross or track but would like to in the future. The other day I got cut in front of and was disappointed in how the car braked when I slammed my foot down.
#9 | |
#10 |
Drives: 2013 FRS Whiteout
Interesting as I love the lack of dust and noise on the oem pads but do wish they had a little firmer pedal feel and a bit more bite without the increased(realistically) dust. I think W2's are in order(correct me please, or would W3 be better). I've used stoptech sport but they dust too much for my taste on a street setup.
GTX2867R, moto-tuned , tomei op , motiv fp , Invidia Q300 ti , Rota titan 17x9 +42 , nt555 255/40 , ST coilovers w/cascam , Hotchkis sways
#11 | |
#12 |
I do understand it'll have to dust more than OEM that's why I wrote "without the increased dust, realistically", maybe I didn't express my self correctly but by that I meant taking into consideration that obvious increase in dust. So W2's wouldn't fit my intended street usage, the previous post didn't answer my question or offer correction.
#13 | |
#14 |
Drives: 2013 Raven FR-S
Which Winmax pad would be best for Autocross and the occasional track day? I'm kind of torn between the W2 and W3 right now.
| Winmax USA Brake Pads - Street, Autocross, Track, Endurance! | CSG David | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 65 | 07-04-2016 09:59 AM |
| CounterSpace Garage - Winmax USA Brake Pads Group Buy - EXTENDED!! | CounterSpace Garage | Groupbuys | 21 | 01-28-2015 06:48 PM |
| Winmax W2 brake pad review? | BRZPDX | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 8 | 06-10-2014 09:40 PM |
| **CUSCO WINMAX PERFORMANCE BRAKE PADS GROUPBUY!** | genometuning | Groupbuys | 6 | 05-28-2014 12:51 PM |
| FS: Winmax brake pads new | BeltedBiscuit | Brakes, Suspension, Chassis | 0 | 03-06-2014 02:24 AM |
