Old 06-17-2014, 08:13 PM   #1
Brahsbrah
Drives: 2013 BRZ Sport Tech White Pearl
Nameless header install
Damn rust in Atlantic Canada.
Trying to unbolt the intake manifold from the downpipe... First of all can't get my ratchet in there because of the cat and tried to take the cat heatshiekf off but that's rusted a bunch.
On the way to my buddies to get a 14mm wrench while the bolt loosner soaks in a bit too.
Going to try warming the car up to heat up the bolts when I get back.
Any other ideas?
Brahsbrah is offline   Reply With Quote
Old 06-17-2014, 08:23 PM   #2
BadBRZ
Drives: Subaru
I have no idea how your intake manifold became bolted to the downpipe but you might want to check on that first...
as far as rusted bolts, PB Blaster is above and beyond the best...
BadBRZ is offline   Reply With Quote
Old 06-17-2014, 08:31 PM   #3
Brahsbrah
Err sorry exhaust manifold.
Old 06-18-2014, 04:09 AM   #4
Hawaiian
That guy
Hawaiian's Avatar
Drives: Ultramarine mt FR-S
A ratcheting box wrench made very short work of getting the bolts loose for me.
Ultramarine mt FR-S
P&L stage 1 turbo
Prime Motoring Flex fuel
Jr Tuned 506whp @17psi (e73)
Old 06-18-2014, 04:19 AM   #5
Fastbrew
Drives: 2014 Pearl White BRZ
Swearing helps!
Fastbrew is offline   Reply With Quote
Old 06-18-2014, 04:41 PM   #6
Brahsbrah
Got it off with some PB Blaster type stuff .
Now to try and fix this awful exhaust leak. I'm running the stock overpipe.
Old 06-19-2014, 09:55 AM   #7
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
http://www.grimmspeed.com/grimmspeed...25-2-5-gasket/
^Those should do the trick.
http://www.grimmspeed.com/grimmspeed...st-gasket-set/
^If you want the set
Old 06-19-2014, 04:26 PM   #8
Brahsbrah
Thanks man.
I'm going to try to use a combo of the stock gasket and ones nameless supplied tomorrow night and if that doesn't work order the grimspeed.
Openflash+Nameless Header Brahsbrah Software Tuning 86 04-18-2015 06:26 PM
FS Nameless header in Queens NY Imsteak Engine, Exhaust, Bolt-Ons 1 06-17-2014 02:04 PM
RevWorks UEL Header + Nameless Catted Front Pipe VS Stock Gutted Header + FP NickFRS Engine, Exhaust, Transmission 44 04-19-2014 05:42 PM
Nameless EL Header LPC_FRS Mid-Atlantic 16 03-20-2014 04:42 PM
Header - Nameless vs JDL Kodename47 Engine, Exhaust, Transmission 36 05-06-2013 10:12 AM
