Old 06-16-2014, 09:55 PM   #1
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Brembo bleeders with anti-seize ok?
Hi guys, I've read that the bleeders on brembo calipers are prone to seizing up and getting stuck. Would it be a good idea to apply a tiny amount of anti-seize on the bleeder threads as a preventative measure?
My concerns are mainly with whether the anti-seize will contaminate the fluid and clog lines? I wouldn't imagine it would seeing that it's only going on the threads.....but comments?
Fizz is offline   Reply With Quote
Old 06-17-2014, 03:32 PM   #2
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
I would think a light coating should be fine. Never a bad idea to use anti-seize when it is a steel bolt going into aluminum. My advice is don't overtorque the bleeders.
Old 06-17-2014, 04:22 PM   #3
dradernh
Drives: Used to Drive:Grand-Am GS #54 E36M3
This.
And, don't coat the first 1½ threads or so; otherwise, you're going to have a tough time getting them started and you'll run the risk of cross-threading them.
dradernh is offline   Reply With Quote
DIY - Stainless Steel Lines - Speed Bleeders - Fluid Bleed/Flush F1point4 DIY (Do-It-Yourself) Guides 99 08-24-2017 06:05 PM
Speed Bleeders - long term reliability amram Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 48 05-14-2014 07:32 PM
FS: Eibach Anti Roll Kit (From Pro-Plus Kit) Batman Brakes, Suspension, Chassis 1 03-31-2014 03:02 PM
FS:NY RCE Anti-roll/Sway Bar kit $250 snky_snky Brakes, Suspension, Chassis 2 08-19-2013 09:42 PM
BRZ Anti Theft system Skurj BRZ First-Gen (2012+) — General Topics 15 01-21-2013 03:38 PM
