Drives: Scion FRS
K&N drop in filter problem!?!?
I just installed a K&N drop in filter last night. I disconnected the battery to reset the ECU. After the reset, I let my car idle for a few mins. Today when I drove the car, I noticed the throttle response was horrible. Was just wondering if it was because I reset the ECU, car heas to relearn everything and throttle response will go back to normal if not a little better than before due to the increased air flow. Was just wondering if anyone else had the same problem with the K&N drop in filter or if I did something wrong.
Its cause you reset the ECU
| The Following User Says Thank You to Luis_GT For This Useful Post: | acro (06-15-2014) |
Drives: Scion FRS
Yea i figured for such a small mod I did not need to reset. Any apporximate on how long my throttle response will atleast go back to OEM Spec if nto better?
Drives: 2013 BRZ (gone) 2016 Ford Fusion SE
http://www.ft86club.com/forums/showt...ottle+response
That thread should have all the answers you need. Specifically, reply #3. |
Drives: Scion FR-S 10 #0931 ManT
Yea, I had installed k&n on a Volvo, passat, camry and frs and now a cold air intake and I never reset anything. Once you turn the car on and drive it the ecu will readjust on its own..
Sent from my DROID RAZR using Tapatalk
I told everybody, don't worry I drive rear wheel drive in the snow all the time at work, and the car fits 2 kids in the back and my groceries in the trunk are no problem.
Drives: SWP FR-S
Totally normal when resetting the ECU. throttle needs to relearn everything. i would give it a week till everything is back to 100%
Drives: Scion FRS
I followed this
"Could try Jeff Perrin's suggestion of turning car on without starting the engine, fully press and release gas pedal 20 times, turn car off, turn on without starting again, press and release 20 times again, then start engine. No more ECU reset dead pedal" and worked instantly! Thanks everyone! |
| The Best Drop in Air Filter? | FT-86- | Engine, Exhaust, Transmission | 46 | 06-05-2014 08:54 AM |
| K&N Drop in Air filter | SkAsphalt | Canada Classifieds | 1 | 04-29-2014 04:29 PM |
| K&N Drop in Filter | Khazzy | Engine, Exhaust, Bolt-Ons | 3 | 06-03-2013 02:43 PM |
| DIY drop-in filter? | aceangel | Engine, Exhaust, Transmission | 18 | 04-25-2013 11:42 AM |
| Drop In filter test! Stock, Apexi, No filter | RallySport Direct | Engine, Exhaust, Transmission | 14 | 06-25-2012 03:40 PM |
