Old 06-10-2014, 03:54 AM   #1
gmsii
gmsii's Avatar
Supercharger Belt Slip Study
In reading through the various supercharger threads for systems utilizing serpentine drive belts, it seems that the incidents of belt failure rises significantly when smaller pulleys are being used under hard driving conditions.
I wanted to do a simple engineering exercise and try to quantify the actual limits and recommend service intervals for each of the various configurations.
Was hoping SC kit owners could chime in and give me some data
1) Which blower do you run?
2) What size diameter SC pulley are you running?
3) Approximately how many degrees of belt wrap the SC pulley has?
4) Which brand/model of belt do you use?
5) Have you ever had issues with the belt breaking or slipping?
6) How often do you change your belt?
7) Does the boost curve taper off at high rpms (either dyno graph or datalog)?
Feel free to post in this thread or PM me this information
Thanks in advance
gmsii is offline   Reply With Quote
Old 06-10-2014, 10:50 AM   #2
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Not sure if srs or trolling.
Old 06-10-2014, 05:57 PM   #3
Calum
That Guy
Drives: 2013 asphalt FRS MT
I'm pretty sure he is serious. But with how utterly flawed the data would be if collected from polling end users, I highly doubt this thread will get any traction.
I'll see myself out.
Old 06-10-2014, 07:02 PM   #4
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Perhaps srsly trolling?
Old 06-10-2014, 09:34 PM   #5
gmsii
gmsii's Avatar
not trolling at all (thats why i asked people to pm me)....i just see a lot of guessing as to why things happen in these supercharger threads, but nothing quantifiable...i dont need exact data at this point just enough sample data of different set-ups to see correlations (which i am already starting to see)...trolling would be putting up some broscience graph showing belt slip vs car color
these calculations are not hard, i am just not familiar with the other set-ups. if there are local people with different sc set-ups we can just probe their sc pulley layout and tell you for sure...all the other necessary data is needed (ie engineering data from the belt manufacturers and sc manufacturers)
anyways...if people arent interested in this study, thats fine...we can just move on
Old 06-10-2014, 09:57 PM   #6
Why not just delete the identifying data and post what you got? Otherwise, this thread is going nowhere.
Old 06-10-2014, 10:42 PM   #7
DJCarbine
Thupercharged
DJCarbine's Avatar
1) Vortech V-3 H67B
2) 3.12"
3) ~200* (will try to get more accurate number)
4) Right now a Dayco belt, have a gatorback I might replace it with because of good reviews with supercharger users in other forums
5) Only issue with a thrown belt rib was due to running incorrect belt size, an error on my part.
6) 10K miles on kit, first 5K with stock pulley/gates belt, 4K after that with smaller pulley and failed gates belt (wrong size, belt threw a rib), last thousand miles with dayco of correct size
7) Datalogs show steady/consistent climb in boost. No squealing of belt or perceived slipping
Belt that failed was K060962, correct belt size was K060966
Not sure if I will swap on the gatorback belt soon, or just wait for 40K-50K miles
2013 FRS
Vortech V3 11psi
Old 06-11-2014, 10:51 AM   #8
King Tut
NASA SpecE30 Racer
King Tut's Avatar
I am sure that owners of Vortech, Innovate, and Jackson Racing kits are interested. My question is why would an employee at Kraftwerks who doesn't use a serpantine belt setup be the one to post this thread? Compiling data for a new Kraftwerks ad campaign?
Old 06-11-2014, 11:11 AM   #9
s2d4
s2d4's Avatar
People loves broscience.
Old 06-11-2014, 11:15 AM   #10
ZionsWrath
Thanks
ZionsWrath's Avatar
Would be interested to see the toothed belt data vs serpentine
I like the innovate kit in the beginning but then I started reading about snapped belts and kind of got iffy. Then I saw @CSG Mike running the other kit and saw how much different it was and now I like that kit lol
But for me I won't be getting anything until I learn to drive, so I can just fap to threads like these while I learn
Old 06-11-2014, 04:39 PM   #11
sw20kosh
Drives: 2013 Black FR-S
An employee from the only supercharger kit company not using a serpentine belt posts about gathering data on why/how serpentine belts are breaking. Classic.
Old 06-11-2014, 04:39 PM   #12
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Not trolling bro, srs.
Old 06-11-2014, 05:54 PM   #13
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
I haven't owned any of the "standard" belt driven SC systems in place not am I FI at moment. However I am a forum whore and pay attention, only (odd) case I've seen of belts being an issue were with Vortech and it seems with proper alignment and things Vortech have made small changes to I am not even sure that is even a concern anymore? I haven't read I a single belt issue or any issue as of yet with Jackson's kit. If something is engineered properly and well tested before public sale it's to be expected there really should be zee concern to begin with???
Old 06-11-2014, 08:06 PM   #14
DJCarbine
Thupercharged
DJCarbine's Avatar
It will probably show no belt slip/breakage due to it using a toothed pulley/belt for the headunit, so they have more options for belts as far as strength etc.
I knew that this was a pretty one sided study but decided to bite
2013 FRS
Vortech V3 11psi
Scion FR-S Convertible Still Under Study vh_supra26 Scion FR-S / Toyota 86 GT86 General Forum 10 01-26-2014 08:12 PM
Supercharger Belt Swap | Video and Discussion Dezoris Forced Induction 11 07-30-2013 03:20 PM
Maritz Research Study? Marcoscrdo Mid-Atlantic 18 03-14-2013 01:40 PM
Anybody else get the New Vehicle Experience Study jduffy BRZ First-Gen (2012+) — General Topics 6 11-05-2012 11:26 PM
Toyota FT-86 II Concept Height Estimate Study Sea1monkey2 Scion FR-S / Toyota 86 GT86 General Forum 49 06-20-2012 01:36 AM
