Someone please help me find whats wrong with my car!
2013 FRS
Manual transmission Lowered approx. 2" Approx. 9k miles. So I was driving and noticed a clicking noise coming from the rear end when under acceleration. It was present in all gears from approx ~1k RPM-redline. The problem was not present in neutral. It sounded like a broken CV joint, but today I put the car on a rack and the CV joints were fine. I replicated the problem (clicking) with the car in the air and found the engine, transmission, differential, driveshaft, and exhaust shaking violently when under acceleration. it appeared to be caused by violent shaking. The problem was still present through all rpms, but most voilent from 1-2k. Again, problem was not present with the car in neutral. I was able to replicate the problem with the belt removed, so that rules out a few possibilities. I was also able to replicate the problem with traction control on, traction control off, and VSC sport. No traction control or check engine lights on. U joints have minimal play, seems to be within factory specs. Carrier bearing was fine. I also removed the bracket holding the exhaust at the front pipe in an effort to relieve some of the stress, but this made no difference. Any ideas what could be causing the problem? At this point I figure its either my ring & pinion or an imbalanced differential. I'm hesitant to take it to the dealer because they have denied warranty repairs for my transmission in the past. Update: Was driving the car to the Toyota dealership and finally had a part failure. Car is inoperable and had to be towed. While pushing the car to the side of the road and loading it onto the flatbed, the clicking noise was still present. Update: Toyota has had my car since Tuesday night and hasn't been able to figure out whats wrong. [ame]http://youtu.be/mFkhlxg8_v8[/ame] [ame]http://youtu.be/blcSrObfTB0[/ame] [ame]http://youtu.be/ctEqRdz1OvE[/ame] [ame]http://youtu.be/3a0n6RM0t1g[/ame] Last edited by Amir Ghadiri; 06-05-2014 at 01:06 PM. |
Drives: Slow
That kind of shaking screams driveshaft at me. So you had your clutch changed at 5k miles? Who did it?
Drives: Slow
Do you work at a car shop?
Pissin off regressives
Drives: They have engines.
Have you checked the motor mounts?
4400 miles, just under 5k miles ago. Toyota replaced the clutch and transmission under warranty because this happened.
Drives: 2013 FRS, 2008 R32
Toyota just called, broken rack & pinion. Needs a new differential, total cost $3800. Warranty coverage denied.
#10 |
Drives: Slow
Reason why I asked about you working at a shop is sometimes co-workers like to play "jokes". Some wheel weight stickers on your driveshaft can cause your symptoms.
#11 |
Small penis big dreams
Drives: '13 Scion FR-S
why was it denied?
v3 -> v2 Vortech SC / 2.87 pulley
Fuel pump, FIC 770 injectors, custom header back, perrin resonated CBE 277hp 93 octane 370hp on E-85 |
#12 |
Boosted Member
Drives: 2013 SWP BRZ Limited
did the clicking come from a particular side (drivers/passenger side)? I had this issue after auto-x, pre-FI, and by tightening the axle nut, it stopped clicking. This seems like a very common issue with lowered cars and rear axles giving out.
Sucks to hear it was your rear diff, but before jumping to an expensive conclusion, I would check again if the clicking is audible from one side more than the other. The symptoms sounds just like what I was experiencing, and I was able to replicate it on the rack as well. The noise was clearly coming from my driver side however.
Suzuki Swift GTI '89, Subaru Impreza L '96, Lancer OZ '03, Subaru Impreza WRX '06, Honda CBR600RR Graffiti, Volvo c30 T5 R '11, Subaru BRZ '13, Audi RS4 2007
SUV's: Mercedes Benz R500 '06, Mercedes Benz ML350 '12 |
#13 | |
Details on the denial? Agree that the videos and such looked like a screwed up driveshaft the third video has a shot of the transmission which looks pretty stable, I could understand mods being to blame as that would overstress the drivetrain but other than that... |
#14 | |
![]() I did take a look at the differential but couldn't find anything on there. Also, the problems first occurred approx. 100 miles into a 200 miles drive, so I suppose that rules out the possibility of a co-worker playing a joke on me. |
| WHATS UP DOC ?? | Sith_86 | Member's Car Journals | 7 | 04-09-2014 12:38 PM |
| Whats your MPG? | RojerLockless | Scion FR-S / Toyota 86 GT86 General Forum | 29 | 12-14-2013 04:36 PM |
| For those that have them, whats the MPG? | MXRider | BRZ First-Gen (2012+) — General Topics | 140 | 07-10-2012 12:17 AM |
| Feds find majority of Toyota unintended acceleration cases were people hitting wrong | ichitaka05 | Other Vehicles & General Automotive Discussions | 15 | 03-16-2011 01:19 AM |
