Old 06-04-2014, 11:31 PM   #1
Frs x3
Likes it in the rear
Frs x3's Avatar
Drives: RS 1.0
Can someone tell me where this leads?
I opened my door and a Damn baby wasp flew in and have no idea where it'll turn up. Thanks.
Frs x3 is offline   Reply With Quote
Old 06-04-2014, 11:34 PM   #2
Pseud0logik
Pseud0logik's Avatar
Drives: '13 Firestorm FRS MT
That's a defrost vent. Turn on your defrost and crank up the fan, maybe it'll blow out. More likely it'll just die in there and your car will forever be a little heavier.
Pseud0logik is offline   Reply With Quote
The Following 8 Users Say Thank You to Pseud0logik For This Useful Post:
8R6 (06-05-2014), Frs x3 (06-04-2014), kodyo (06-06-2014), Mister (06-06-2014), mrlewistan (06-05-2014), TM (06-05-2014), WhiteRose (06-05-2014), Zelica (06-07-2014)
Old 06-04-2014, 11:34 PM   #3
Apoc
Apoc's Avatar
Drives: Raven FR-S 6M
Narnia
“The World is Flat”
[||•]=(86)=[•||]
Apoc is offline   Reply With Quote
The Following 5 Users Say Thank You to Apoc For This Useful Post:
brianhj (06-12-2014), EAGLE5 (06-07-2014), FiRStsc10n (06-06-2014), Jrryjms07 (06-05-2014), kosoku (06-05-2014)
Old 06-04-2014, 11:37 PM   #4
Frs x3
Frs x3's Avatar
Drives: RS 1.0
Thanks for the very helpful replies
Old 06-05-2014, 02:57 AM   #5
synchromesh
synchromesh's Avatar
Drives: Ultramarine Blue
First thing that came to mind was the Mazda 6's problems with spiders doing there thing under the hood.
Had a similar thing happen 2 weeks ago. Some SUV parked like less than 2 feet beside me. I drove out, pulled to the side to check for a ding and then as I got back in a huge wasp flew inside but then just disappeared without a trace. Back to the paranoia front, a really bad day for my beloved 86 as there's was a bad keying not on the bumper but on fender. Looks like 4-500 bucks to fix
synchromesh is offline   Reply With Quote
Old 06-05-2014, 06:33 AM   #6
Frs x3
Frs x3's Avatar
Drives: RS 1.0
Damn now that sucks. I'm sorry to hear.. Did you try buffing out the scratch?
Old 06-05-2014, 12:32 PM   #7
Turbo95eg6
Turbo95eg6's Avatar
Drives: 2014 BRZ SWP LTD
Only reasonable thing to do is transfer the title to the bee and sell the car… He owns it now.
The Following 2 Users Say Thank You to Turbo95eg6 For This Useful Post:
8R6 (06-05-2014), Shedd22 (06-05-2014)
Old 06-05-2014, 12:42 PM   #8
DuMa
DuMa's Avatar
Drives: LR BRZ Limited
DuMa is offline   Reply With Quote
Old 06-05-2014, 03:11 PM   #9
FRSupra
FRSupra's Avatar
The correct name for that vent is: Duct, Side Defroster nozzle, No.2 (number 1 is on the passenger side) Both of these "side defrosters" follow their own tubing and both of them connect to the Center Nozzle Assembly, Defroster. (the main window defroster strip at the base of the windshield.)
So, to give you a basic understanding. The bee flew into the vent, crawled down a long tube until it reached the main defroster. At that point it could crawl out anywhere along the channel at the base of the window, crawl down into the system, or crawl they entire length of it and end up crawling down another long tube and come out the same vent but on the passengers side.
The circular vent below the defroster, called Duct, Heater to Register, No.2, also follows it's own tubing inside the dash directly below the tubing I just explained. This tubing runs to the center dash vent, above the CD head unit. Then of course the other center vent there (two of them above CD) follows it's own duct and comes out at the circular vent on the passengers side (Duct, Heater to Register, No 1.) From where each of these tubes leave the center vents, there is an intersection where it starts to bend and head toward the circular vents, at the farthermost point back into the dash it where is drops downward and into the system.
I'm not sure if these two sets of ducting meet somewhere down in but it would make sense if they did.
Hope this helps.
FRSupra is offline   Reply With Quote
The Following User Says Thank You to FRSupra For This Useful Post:
Pseud0logik (06-05-2014)
Old 06-06-2014, 01:56 PM   #10
synchromesh
Looks pretty deep like the one I claimed last year to the tune of the same amount. Was thinking touch up paint. Any product you recommend? I don't have my dream porsche yet so I'm prolly not going to buy that swirly machine thing just yet. Probably should confer to the other topic forum lol.
Old 06-06-2014, 06:44 PM   #11
Frs x3
Frs x3's Avatar
Drives: RS 1.0
Meguiars wax should hopefully get most of it. So sad how people can vandalize other peoples property with no remorse. I hope you get that scratch taken care of even if you can't get all of it out.
Old 06-06-2014, 07:20 PM   #12
tahdizzle
So elite I'm 1338
Drives: WRB Subaru BRZ
I had that same problem with crickets. I just turn up the radio now.
The Following User Says Thank You to tahdizzle For This Useful Post:
Jar (06-07-2014)
Old 06-06-2014, 10:43 PM   #13
Frs x3
Frs x3's Avatar
Drives: RS 1.0
You're handsome tahdizzle
The Following User Says Thank You to Frs x3 For This Useful Post:
tahdizzle (06-07-2014)
Old 06-06-2014, 11:04 PM   #14
Tromatic
OP said wasp, not bee. Bee will wander out later, if still alive, seeking an exit. The wasp will only be interested in revenge.
Tromatic is offline   Reply With Quote
The Following User Says Thank You to Tromatic For This Useful Post:
Apoc (06-07-2014)
