I love peanut butter
Drives: 2013 SWP BRZ Limited
Solved: Factory BRZ head unit going into protection mode
I completed my audio install last night and my stock head unit keeps going into, what I'm guessing is protection mode, between 5 seconds and 1-2 minutes of play... it stays powered and everything but all audio silences, even my sub, until I power it off and on again. Has anyone else had this happen?
I am using the factory head unit low level output (from the factory amp harness) and feeding the signal into a crossover to get only highs, and feeding the output back into the factory amp. This part is probably not relevant, but the crossover also uses that same signal and outputs lows (in a separate RCA) for my aftermarket amp/sub. Anyone have any ideas? Last edited by B-R-Z; 06-06-2014 at 09:51 AM. |
Drives: 2014 BRZ MT (Sold); 2006 V70R
If your'e sure your crossover is accepting high-level input and outputting low level RCA, then maybe it's a mismatch between your xover output and your amp input? Double check to make sure your amp can accept the voltage coming form your xover.
AFAIK, there's no "protection mode" in these radios. |
#3 | |
The entire HU is going blank? I thought only sound was cutting out? If all your speakers are being powered by your amp/s, then if amp cuts, sound cuts. I don't see how the sound-only will stop while the HU functions normally unless it's something between the HU and the speakers causing it.
#5 | |
New discovery made tonight. It looks like the issue is caused by the low-level line coming from the head unit going to the crossover. If I go to 3/4 of full volume, it then cuts out. If I disconnect the RCA, the audio goes back on. I can then reconnect the RCA and it works again until I hit the volume threshold. So maybe it's the input impedance that doesn't fly with the headunit? Maybe I should post this on a car audio forum now. Here's crossover specs: [IMG]http://www.ft86club.com/forums/data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAAjMAAAJZCAIAAAD TXyOpAAAgAElEQVR4nOy9PXMjz5rdqW/CCNhAwAdIWwDpA6QPkNaEJIB0FSDbVCxAGpo72gCxtoC+u4pZB 2hdrVloU3u3IEdrFbSOxphJa8xa4zTO/2FmVRFkg2Q1+/yioqNZL/lWWXkyn0zk8y9SIYQQL2ETx+soWi2X9+Px/Xh82euddzqnrVbl6OgzHceNxnmnc97p3I1G9+PxYj5fR9E6it6 hhP/FO8QhhBC/FWjB11E0m06hXhQwHh8rNjiYtvvxmGl2zn10+UmZhBCiHGyThP Lw88cmjj86Q69HyiSEEKJcSJmEEEKUCymTEEKIciFlEkIIUS6k TEIIIcqFlEkIIUS5eEaZFvP5zXB40e1edLs3w+G31YqXZtPpw2 SCwz7C87Pp1J7fxPH39fr7er1NkrzotkmCezIX1DOEvXImhBDi 1yRXmZxzZ+12+EOti24XsrGOIp68H4/xlD25Wi5xcrVcnjSbNpCrfj9Te64HA9zg/cx4E8c2MfVabfb4eLAyEEIIUSZylcn+RPm01apXq6EO3Y1GlAo ozXGjgTN3oxHusVrlKZwX42I+51WrTM45T9hwLObzAxeGEEKIE pCrTOHQZzadUodwxjnHraLuRiPecNxocEhEhZtNp8651XJJkbP 3eNpjlel+PMbJ805nE8cMgckQQgjxmXhema76fcwMOee47wVv2 8SxNbLhP3ZXDGwVdT0Y8Ay1isoUjodsFByH8X6O1aiaQgghPg2 5ynTZ61mpOGk2vRUQhGMaz9bnsU2Sh8nky+0tB0A2BByZykSLI s+slsviuIQQQvy6FK2AyNwN96TZ9DYKdM7ZG/L2qbUTTmEgIFQmBm6VjEFJmYQQ4vPxzKrxdRRdDwa0p9FqZ1d+ 07bmrX3w2MSx3fvdCwQUjJmkTEII8ZuQrUz8XRFHNtsksdY2Tv BkLr2jrsCC9zCZWKWhkoW6UqBMJ80mz8iaJ4QQn5hsZeICbi4H Bxw8QRLseu7LXo+Sc9Jser95sgMpKtyeysTlfxxjMaJf2gGJEE KITHLHTHZt3rfV6vt6zcULlIQ/fs9UrTrnnHNcEQ4pslNQD5PJ9/X662LBJXzhD5IylYkyedZuf10svi4Wld3a9DcrFiGEEB9G7jyT N3tkj8teL31qx+NGROH6Om/lHo/TVitcK5GpTKkZNmXaDIUQQnwmilZA3I/H/tqHajW049m1Cc45PkKb3mq5tNKCQDKX8OWpjnOOGxdB1SRLQgj xWXl+r3G6pi/YiXVPNnGct6Z8T34+DUIIIUqOvGAIIYQoF1ImIYQQ5ULKJIQQo lwU7U50MxyetdtX/b79vW3l6AgLxMOr6W6ZOJcnHDcaXB+B9RQvSpxd9YAjTdN6tbr/8ofZdPrqqanzTsdzfhiyTZKb4RDr4L2iKDlYWpmm6TZJmM1K/ia5do3lRbd7QBck6yjaJ7TZdIpFNyfNZsH9553OwX9/7Zy76vfP2u393+9BfgbOd2SZTafwVXbSbL7US9lqudzz2zluNJ 6t/EK8HUX+ma4HA+xORH8T9+Mxlozz6mWvd9Zu2wfZuuF3SFSmerX 60ubstNVCLDg2cUxp3DOEn/k17jqKiiPaJkm9VrseDJAw+PJ4XVzvj3MOJXM/HuMdoR3ME3LsLIUXAXcnh1qNcj0Y5O1oRbClPepVcez1avXgO9 DPptPMHznkgdT+/PLR2XRqF76maXo3GiGD6E8U9CQyOW219vkGvf6lEO9P0S9tuea bHbfjRgNfxXmng6uL+dzuAp6a3iLUC5/WYj7HgGkTx1f9Pty3b+J4HUV0ITibTq2zDATlfR6r5RLhYNB20 e3SPa49s4ljusGFE97LXm+1XF50u1A4pOFmOGQu7sfju9Hootv 9cnuLdOJB59zDZMJgbWLg4IN/YmNA59xiPp9NpzfD4d1oxMcRtU3nRbeLZgUJQ3qYTZyBJ3skhq WE4uU9aGtwD07azTJwFeeZ7HUUwZ/W3Wh00myeNJv34/FsOsWCfpsS+y7YibYtF+7H20x3Gy3iJEoMRY2rzrkvt7e2MNHv wTCooKjRClMb7sfjbZIs5nNKGnKKesvYcT/rKiUQPSpbG1kTbI7wdu5Go3qtVq/V4GCMdQyFjHLDu2Zq0SfzCtB7X3w1zjmUT1ilPc1G18F+EdeDA QJZRxEy8uX2Fs8yYRfdLlJ+0e3i5+qbOMbbv+r3Uez2w0lzxmp CvCfPzDOhQuMzhss+XtrE8Zfb2/CnRceNxv14vI4imN3Qdp+2WmhPYSVA03A3GqF3+WP/iFrNdgDxeZy12/ie0bBy0IYAEQ4uYYCFr+6s3d4myd1ohOShwYJ17r9tNmhlNnF8 2eshtMteD11Rjhtm0ykkEPq6ieP78dgbEuV1z887nXq1ejcaQc Ix1EC775xDBxwBYriJRn8TxxB+lPNqudzEcb1aRXHZUlpH0f14 jEDQb0AzjR9B207xZa/HYkdbwy4CXgQiRUMP2+liPg9bQLym2ePj9/X622p11e+jOwJtZu7SndFvNp1CSy57PQg23xoLEwNxpH+1XGJv e75Br6i3SXLcaNRrtZvhkAlDFeK7WEcRQkOJnbZaiBR5QaZQG2 HxQ63gzegV2feFguVb2CYJ0389GKDW2XfN1KLi2fTjfTGFqHuI EWNW/ECQVRopP2407Nu8H4/tB0hshcHbRFGzmqHy4B3BEoAtVPA5nDSbtI6g2DmMFuKjKFKm1 XJ50myGXU6Afne9WvXsKvjs8e86iuq1Gr5tBLKJ42+r1cNkgu8 w3TUc4ccAbaDrJo7D7sfj1XJZr9WwV+zNcIimjX1qeDi0CbZXq W3IAptphI8mGKqGVjUMluRZPDi8sI/zfrQjX25v+expq3XR7X5dLOixnlMUdLqIZ68HAyS+Xq1e9fsoA UR3PRh4rSEyi241GlDkF91ktI/8T2p6DzhpXysNs+edzmmrhd9QI3c3wyGTgY4IxyUMBAKJzootJ RQpTiI0+069vGAwCrdhiIINN8vZvlzOayLjUAKoDmojtSHdtcW Z7wsCtk0S1CIvhZWsTbZYCCR8X4gRBmHMtLFKX/X7SEYlywlnWN9OWy1Gx++Ihj52KHkJ2UTI7IGlZqhkJV+ID6HI c6DtstnWCv1NnD/vdLwvE40pd9KrHB3BvJOm6d1ohGZ3MZ9zIQOGMvg+bThshS14C o0OFYvfuXcz02+v2hly2PFtE4CE8Tb0pvOKyLPyXw8GGIWwdbO Ps4FL0xSdbgoY2tzjRoNDKCtadqzJENA6swTQnQ+nrJFx9NbxX tAMsQ2y42AWgichyJotBw41YDqzyeA4koOzdGcEtm8BpWRfDey 0XkeERQerJrgbjdCm27fGAS4fxG3proIdNxrrKDprtzmOtCtc7 kYjjBuYTVZ427J7KWQuworhfRTe+9rE8WI+P2u3rwcDjpy8Kh2 a1LxROyzh3pwQRNE+y3LgZ2jVyGo5TeXeWE2I9ydbmWBbx0au3 9drGIv40XLdju18EdurTdO0stvvNTWdO/TB0cgiLm+GCTffDIdIAPxxcPZrMZ+j245FU6vlEl1OnOHaLX6x XoN11e8j8fVabTGf24k0fsZ41hobz9ptb7UVrB/fVivn3OzxEUVhW2SOwGDKZ3vK0oD62oFdmqbcAsqWEvxaWeMV8 riYzzmoCtd6YMyKF3fe6SC/qdEDWhRtWxbKPI1dfKeL+dy+fSqTfa1o8tjE27d21m4jLxy4cG CNsrIqS1timqbbJEGDbi2cOJPuhib25bLoKCSsjZe9nr2Zrxvp 5xQpq4StYzfDIWpd2HGxlk8cme+L204iOqy4s1U6fAsIGTNJUF ncwEE2KgwseGFXDP2D9GmfDysebQ0PR8xCvD8ZyuSe+qjFyMCu 6oFRCKbqcKIFdm3W7IpZPoteP+zyGEul+UutvDTcjUbs06VmQT kb6/AMNuvzFkph7od29vRpQ4wxiu0Lc2fb68HAW50Fi1BltxkgP3vb iOPxerXKxxkghApzA7iHs9k4Y+fwYDhlAjCswT1YSJLZecd5Nt C29KwcXvZ6dhkYRxX2XdhOdMUsk0MyuPSDyeCIxI7A8I5QAWxp cEhd2W0Z7BU1I7JX8X5h48I8EETdvtx0Nz2DR2xt3MQxQjhttV iNw/fFYWtYGTDS8sqcW+OzYoTvK919ZbacUZdQOGmWSTDdjXG9cmAV YoWxb9D2z/gt8yrrMOMNR8xCvD/7/tL22SXUr+YtfoDyzrxRyQgPlTNQOYhPz0fuAYEe/Yt+KSKEEOLT88G7E/1CmyYIIYR4H7RvnhBCiHIhZRJCCFEupExCCCHKhZRJCCFEuZAy CSGEKBdSJiGEEOVCyiSEEKJcSJmEEEKUCymTEEKIciFlEkIIUS 6kTEIIIcqFlEkIIUS5kDIJIYQoF9nK9F/+8pf/489/1qFDx57H//n3f//hadCh4xc6/umf/unFyjT/j//xb//9v9ehQ8eex2w6/fA06NDxCx3/8D//54uVSQghhPgopExCCCHKhZRJCCFEuZAyCSGEKBdSJiGEEOVCyi SEEKJcSJmEEEKUCymTEEKIciFlEkIIUS6kTEIIIcqFlEkIIUS5 kDIJIYQoF0XKtInj7+t1eLxb4vJYR9H39do594FpcM6VpDSEEO KTUaRMp61W5ejIO44bjQNGP5tOL7rd2XS6/yPOOaTkgMl4BesoqhwdnXc6H5sMIYT4fBQpEwTgtNU673R43I/HB4z+vNOpHB29SJkgCaet1gGT8Qrux+PK0dFhS0MIIURaoEwQg MrR0TZJvEvbJPm+Xm+TZJskD5PJOorSnXXrYTL5tlpZOxtMgs6 5TRw/TCazx0dcxf2IYvb4GMaCiL6tVgiTJyEJ14MBYveedc59XSweJp OHyWQTx2Ey1lH0MJl8XSyYSFxidphCWxRhvqCpq+WyqHSFEEK8 nFxlmk2nlaOjerUaXroeDCpHR5e9HnRlMZ+vo6heq9HiV6/VIFdpmh43GpWjo4tul1cvut10JzA8wsGHd8NZuw1hQLxn7baND pc2cWyTUTk6uhuNipOR7jTmZjjkpZNmE5c2cexFRLWrV6uQ7W2 S4CqzLIQQ4mfIVSYIQL1Wu+h2eaBdRiuPWZb78fj/+stfoAez6XSbJHejERt3ttqXvd46inAJU0SbOIbCnbZa6yjyhi mL+Ry6uFout0mCGS+oFyThtNVaLZe4japgbYObOEb6i5ORGqPl OoqgxwwQOZ1Np845XLL5wpQb0/CxKzKEEOLTkKtMlB97bJOECxA4OQSBuR4M8KddobBaLtGCo9Wm hdA+mDlVA/lZzOf4cx1F9+PxYj6nxsCCx7g8Y+AmjmePj5yOYjIYGv9kkpBC hu+cg+SctdtclMjE49Jlr4dH1lGkAZMQQhyKbGViix/Oo3itfBrMuLBxT9MUoxOa1NCgcz0bRkJhm87Yw1EIYufyB6sxz rmHyeSk2fxheatWqZeZycAljISgMV6AnjmRBwPU8gchhHgLspU JAhCORVKzAIFnoAEUGLT7aNwhWhz62EFSgfzAEFcx68L5AybET o3Bn9AVqMX1YADbIOLCwC4zGbjkjdtsgLBnZq5xQIAaJwkhxFu QrUxooDN/uhSu88aZq34/TdNtkmDOCTLgyZsdJHlmNA872fOs1CExEEgICZdCIISCZMBoSY 2xucNwCvlyzmEpBDTMzpZhBi5zbaEQQohXkK1MaKBp47KgUbYL sqkxPDCi+rEGYbe6z/uFLAdGmYMPz5JWr1YRoxe71RioFJZsQKUoHnnJCMdtdvznnGM4 ld0qCaw7p0WRKzVeVOhCCCEKyFam2XR6Px5nzgDdj8fh/Mo2Se7H48tezz61iWMsW7D38M80TVfL5WWvR9OcB1Y9XA8GWBq XGbv9E8vnECDiwqWCZNjbwgAZ5vVgYEOwAXJpRmYWhBBCvALt6 CqEEKJcSJmEEEKUCymTEEKIciFlEkIIUS6kTEIIIcqFlEkIIUS 5kDIJIYQoF1ImIYQQ5ULKJIQQolxImYQQQpSLXGXC1nl2qx7uj 2fd9D2737a25f5AFvM53ILIYYcQ4hfi9cp0Nxqddzp2a9eCcKR M7w8dZcEzyEcnRwgh9uX1yhRCL0phOOso2iYJPMMWJwi3hYK3i WM87vmbYLDeI3nnPZxzmcEyED5ecCfT5uU973y6K6tndT18JNN pCNLmXcL7op/GvJuRyDBTeS+iGJZSZjrz6gDPy2O9ECI9lDVvE8d/OJOt1azLV9wGFxU4bobDvOhuhkN7G7cYv+h2rTcKhoCIwvNwTs HjotvNbPI8XxtIMBt0+GdCy76Yz+HwCcdVv8+0wW8TD+w7HqbZ blXOsqocHZ2121AFFBF3XrdluI4i+8iX21tbaLPp1DqjyszaOo rCmzdxbBNv34v3vug3BMFS7Tzx80qJWcaf8MToxeWcu+r3/3B3UquhE1PJcqmlPd2F+E14Rpkyj1CZ0HCctlpwbGEbetxWr1Y X8zmby7Anzttm0+lsOoVjJISANvq808EIhiHQuxL+T6eCPA/ntkhP2KjBby9iXMzn9MyE1hYt7HmnczcaMdK70WgxnyOzkBA6a 6ffpnqtlu6k0Z6v7DxCIeTLXm8xnyNtF90u03PWbiN5cGm4TRI 8Uq9W4W7DttE/Cq1WO240PMvqNkmQttNWC+XAF8qbEcXdaLRaLhEsCpxOp+y7eF aZfmT/6VOQFsZr64DV49NWi5dQgCgZFDKEql6takQlxG/CAZSJDT***tvMeT5wra+/MDreZpvpTRyjH50an7k23ofJZBPH2yTBbexxe+czY6RiLebz80 5nMZ9TSJgYSCNHM9YZPBrTs3b722oFEYIMQBVOmk2cRxacc2j0 4XUQWF+FbM0RBW7zHMyjZCAGyMJ5p5PZZHsDGu9mXIWPx5Stv1 EFZp8D0LRQmbweAO5E+HicfuttHfBqzvVgANVEpCfNJhPApAoh Pj0HsObhPBoREFrzPHfmecpkz9txxsNkctHtQpNsU26tefVajQ bAu9GIPX173oIbMmeAGLVNmx11hWM1HCfNJq153vmHySTdtde2 VG3gdB4PYYM2WMOaPTLfUZgRT5l4s2fus8F6vQdbIAXKhKe8A5 dstUmDmhPOhNkXtIljaJ4WcQjx+3AwZbKtvH32RcrEbrX1iY6G 6bLXw9AnDGEdRZQi6yHXng89x8OWRQsYJuExwMpUJo4h0l1Ty3 HYNkkW8zklxIbpnbcjiTDjHCmilUf4HLGhqHkUFKZ9X54y8Wba Ib1gqakvVSaWkg0NRZGnTBio2T4NlmOgIqHc8O9xo5GZRyHEp+ QwKyDQyt8Mh+somj0+VoJ5pj2VCTMu6a4FhJzYSDlPg1bvottl CtHUXg8GOO+thgg75mjyeBvHLqEyIWSmDX+irbwfjy+6XWYHir JaLnGeQusFXq/V0GTTMEiR41CPFj+kn7HbXP+MMiHqk2YTMrBNkotuF5KJkrnq9 3EnJw4ZZr1Ws+KBKLynFvM5SyBPmZhf3MaXi9Jg4RSMC4UQn5K Drc37w3pWraIte4Uy1avVeq3GdWg2orN2+2Ey4aXVcumcQ6Q3w +GX21s0amjjoBBX/T7Ph03bNknw+EmziWBPWy1vwQJwziHAeq3GxWx2lFOv1b7c3mI NGybqM8/bOX+ITdjs8qodoiH2k2YTj9SrVQjbzygT46rXakwJMsWJOpSMX QHBsexJs3nWbuMSouDrwCWb5QJlQkHh/eJN2QElejxWuYUQvwO5yoQf0trJlU0cn3c6XAPm/dJ2mySr5XIxn2+TBE0eV9bZ2/J+n0uj1vVggMVjbMiwvu601UJ67sdjJgxxnXc6x43GZa9njYE8 7+XCsk0Shnw3GmEcwGzaO51zSPlpq3XZ69n0YznicaNx2mpdDw ZsQ/POp2k6m06ZNqYZYHk3FiLa2JFrZPPZwrTvyy5DD2/OSwlmdxCdXQGBfOER/IDXRoFiP221vCzbahOmBIHw/drkYehsF4wIIX4HDrNv3vVgQNMNl8+96Eeaxd1/8YGEg8j3iXT2+Iixl37GJMTvxmGUyftla+Xla3ylTKXlQ5SJSw c1YBLiN+Rge41vk+R+PMbx0i1t0jSFmU7TCSWEb/adI51Np56pUwjxmyAvGEIIIcqFlEkIIUS5kDIJIYQoF1ImIYQQ 5ULKJIQQolxImYQQQpSL312ZsIXoR6dCHAw41dXPD4T4pfkpZe JvMHmcNJtX/X55fjB72evZ3cc9sEFcnheGl2J/LOy5Kg+dX2Ribyv2cPF2rKPISrXd/DsNdsB7Z7BLbPGv5bB9HzfAFfuwieOb4RD7INuX65ybPT5edLt X/f7XxYLnw+278k4+y2I+v+r3L7rd2eOjdUlz2etddLs8uA+Ic+7 L7S1OvlGSRBk4sDLxeMWPbQ+OdZeeCXaePdTPOa0yed4ifiFl8 rZ78Pbm+EBlopf6Z2PHto3l6R6VHOzpfj0Y0CG13Tsf7obhpNh uzH8QGYCTGjiVPm406NA5TVNUfh5hku7H43q1yn6nlOmTcRhl4 hlu4P2xbgsuez3uSp5XNbFtdr1aPVSkBcq0J3sK2JtSrEwfwmq 55G7o+yQG+5fLB+6eXPZ6tqywG2+apqvl0nq4R6niz4PIACwWf Jv2z3UUZX6YSANNtfheDpgkUR4OrEzpri2zW1xjg1fY+maPjzi PM4v5/Ien2lqNYxf4CsINV/2+1zjej8d85MvtbWbC7Ogtr2qilsMFFB1GMLVn7bZNhufGyfMM 6/n7OH/qqH4dRZmDIeaCZVIwZppNp9Ba5Np6TMcW3fVaLcypV/gcyMIkwvMwlXhebk//5b/0xsGpGTPZEqvsfAczfI5vKkdHjOjV8uYlzPOGhZpGZ05wNPz+G/39usBtGP+kMmF7e56HctD9SoEMhO6SMztbqEL2DF8utsBHpPaG +/HY7qNoxewgSRLl4cDKtFou6dkv3dnTTlut1XKJ/7PLU9k5c7objeCGh75N8edpq4WKaNsjtIPnnQ4+m8pTJ7aZyct TJisDzAicO1j3fZ7DpH2UaTGf4//HjQY2AwxvQ8rpctdqQ6hMdAZxPx7D3oJ5FPrxY8rD7B83GvBOY r3LI/DLXu9+PEZpo3niB3w/Hv+HP/2JV68HA6TEU6Z6rYY84jakig4AbfiZyoQ5Le8oWLzghUOvYKvl EvWETq1wXga9/cHKkat+/7jRyHwFsJ7h/+edzlm77b24s3abckKnxjAD7mPbt+Ohu9GI/rrQucE9cG1jn7If5p5JwgdehukGUcCbzDOxgYA5mO5obcti/89LdNxHM4J9Cv1iOt6mqzo7cRomL0+Z0MQjqeunDuPRQPM7tO6 m9lGmtHCe***RRbBNOyzsmcpEqyOzST/xTLZ1M0jQFThpNr+tVqnZM9cOFlPj3BZ/el2NvHkmr8ToADANnAjTD2GoE5mVp6AzG4bD7o73ounuKy8o4Q FvXlg8En5QKGcuQ/CsApmvIN05xNnHiQl6tHbS6LTVgkqhavGjCJXJ6/AVJwm1XV2W8nMYZcIsJUc/Z+02K/diPseyH/aArDIxKF4KnaOzcWTz5x17OnX1sG0u7qShABEV6MrPK5NNM4si M6I8+f/Dd3vOVNk2STheqRwdcc1kaNmw7+JFysSo7eg5nC3Le03sxtpj/zET4KjatqcftX7kV8c5d97p2JWNsGnXq1Ur8/tM6jjnztpta9LI/Gadc1f9fvHLuhuN0HO67PUKlOnZJO2vlOLDObA1j0McvH4Y305 brdl06jlrz1Mm3GZX6aB5pTLBfGSPvLZsH2XC9+bd6f1ZoEzI4 DsoU71W83JtJ3sK3tFquWSPoXJ0tIljps0L0EuMLaU8ZfJKzOb CmhYLlOlnrHmpcVNZeepgUGOm/fG+IHxl+D/mL+numewjA5e9HsflwPY/6D8a86PFvz9DjUpzpr72mWdKd0qpdTG/Cm+1AsJOS9Cku48y0fiDdQHs4PNSvVbjdzKbTh8mk+Lk5TXcVl T2VybYAFm/0WH/eWsehmsF1ryKWZKEXNPyWTCRRkfDDBBOjyq7OaE0TZ1zD5MJ7Y GZysRA9lEmGEzqtRoaoJvhME+ZModuL7LmIXn4t16rsYjwXmS0 2QdP1DElme7a/cwRxrMycDcanbZaeWZ24Jw7aTYzpcLrVVwPBvhA8LFYewy/i2eTFI63RJk5vDKh7Ub7gq76Vb//MJlgzP6sMqVPzU31apVjpnQnJyfN5sNkgoVzr14BgWqND2N/ZaL33otuF77AM5WJhkf8MjSUnHq1etXvs9XeZwWEzTU+1OIMIg 31Wu1hMnmYTDC24NoqpO1hMsEiOm/MRDsM7jxpNqFk+yhTupuZ4xvMUyZv0Hb/9JcrIV44mPzADByKiEPtSmDfE3lgAefXxeL7ev11seB8D2xo3o gWjxTLAL6R2eMjn8pcboDbvPDxymySZo+PFCpMLV/1+9/X62+rVb1W47CsOEkI8NtqVZwkUR5+Spkwa+pVCKxM41pe6ArW4 GFpDSqZ9yD+tMuOaanzDEqz6RQ94nq1WjyRgOTlSRe6hLBfe3d 6fyJHEA/nHBfUXQ8GWN5K06XNAmxoWAVkQ+DYBf/BzwbDiBAaLzHXiJfGkIIMpmnKRWuV3QpJnEcu8GpgHbWvD49As xFFZbfwhK8ps8TsC10tl/fj8Ww65Zjv59sCW0kwI3Le6bBioFO8Wi4xaJOb9v3hEkpbGVAD vYOXwlrHk+GDmVUUn4B38OViKSB6P3b8xAppP4RDJUmUh9Ltm8 c5WK7NQ2f/LXZCQxP8znushfNMnwx0Jq76ffz5w7h3uF80PwvGT5nrFYUQvw SlU6Z0ZwuCBQm2pjfq4MCe8M4ruD69MqU7yT9rt7km8z11AkNV mfKE+HUpozKlO7vWeadz2eu96SpPWJzeLvwQ/q7oPSN9Z5xztNVcDwbvKcP4XbNW5QnxS1NSZZc1tM4AACAASUR BVBJCCPHbImUSQghRLqRMQgghyoWUSQghRLmQMgkhhCgXUiYhh BDlQsokhBCiXPzs7kQX3a49sEVeGX7kuI6ih8nky+3t7PExLz3 YoOhQ+zzejUbYJS+8tJjPL7rdZ3+YZW9DaGXbsR/bc7z/nmPOudnj45fb24fJxPt1FNysfLm9ffZXU6etlt0OWFgW83lm8Q LnnHWNkabpJo4fJpOb4dB+X2gQvGdx8qV1BtsW80CqMsM/bLyiJLyJ58AP//6572pxerDZxKFa/z33Gi+gwN3Gu+HttJvnBeM9k7RNEvputxvgpsY5E47ivUI+ZMu PXwK4eb0bjaw7TQuqAf/kfr7YQ5L+2NaBA3WefGmdQfg88MYzwz9svKIkHEaZ6HaFkvCB3/8ffjSm03UUeV4nLMUucV9KgTLtyZ4C9qYUK9OHQM8j6yiiE1vn HCobvIOzKhZsroG9Zem9VwC4vbBbo1rvaKnZTZhnTlstbvK9TZ J6tWp9Q3vhv0IhsNdieF7K9Pvwtv6Z0jSdTafs8J6129ZdELwH 4epZu81xN5z61Gu1eq325fbWs5LNplO4nzhrtzOHO55H2jxXEf Y8Bv53oxFcpVWOjq76/W2SfLm9rewcSeApz8hm7W9sxOE+AA8i5ZlmOvizsLmwyuRFtFo ueT8Tw2SjGMM8sniRI2vZuB+PUYz04cQk4eS/+pu/4a532AEvNdY8W2KIAiXGN3jV7+MNYqOpn7GreJKD/gT7HCwi9vdRVtxS9nowCN/R61LyKbns9QrGmtskwS71lac+a2wZ0vXRswqBmmCPzEhRZ8LzN nzUMaT8UPGK8nB4n7Zoy9AQ0IMOfLGzt5vumpvjRuO808EO/OzM0oPReadTr1YRoB2L8FLmCGMdRXbnNDziuddMn8oA/cYiZNoAkTz8SecdNtJMZ7V0MIHQMv0zVY6OTlst/t/mLrTmYXCA0BCy/SCpPd7HzE2+Wfi0aqIRt7nDeJd/nnc6/+pv/oaFjKSmgX8mlhhu4wdPlwq8lKkHe/q0tS53rU8NSlT4ounRETWQXuxQDtqG3HLcaGBSB03218XCXj1t tfi6cSYci9DV7LMKYR1x1avVPA+zcHqJin3SbMKJqA0fDmr5Wl 8Ub54FRZSKwygTeyKVnd8U3AC3KKFHVP4fl2h/S3ftKfvI/PMPn7Y7y0Po4jaE1sWwWcQkk7VCVHY+hDwRtb4Q91GmdA+ftlR KNJ34M0+Z0ATTdQ3+tCas68FgmyReOdCZHs5zJ1kUKdPmubitF FrzPGViqugpkf8/bjRsq5H5Ciov9GmL9oiJ94K1Zc5qY/0l8h755rGgklz2enCpZd2e3Y/H1rUmToYy4ClT5uG9fbqpzeS808FADb3Myq6ni/A9WTpgvKI8HEaZMEvJ6WgaUtI03cTx18Xiy+0tPcAW+7SFlnhO Bb1+OoXQDqc86Oe7Xq3meYzmswgZzvHSnZ4V6MrPK5N14seiyI woL9f4br1itGACgF2HL7e3EHt6yPX6E/ZFZJZSmqVMXk1Is2bL8pTpRT5tV8slMn7Z69lhd6Yy8U8vJZ6l V6Rpamt+uqv8aZpiVBoOSvB/O7Tdf8zEKNhxSXeGaxyZnYbrwQBTXwgKLYkd+O4Z72w6lXuUX4 UDW/PYV0XL+8OIVK1e9nqcuy5WJlY+XoLgUbRgPgr9YFrYuT5ttfKm N0Jlypuaegtlsh/MXsoU5Hoxn+dNoZFtksym08teDxJVr9XgJKKyM7WdB+5KX6RMX onZXNgmJk+Z9ocVybZHrBi2kBkvlcn2k6RMIViVxz/xKjdxfNnrXXS7WLSNTh5Wb8NW8TprHv6Eo2fegNE8jsxOJF4lg 4IvaVRmG0VxvKvl0otXlJm3XQHhNUn7KBMte6hD1hYE2bNrqzZ x/H29DhOGNoud60zQ2Nl5pv2ViV8y5zPSFyoTQ0BbCQtDpjKxQOy vRr6v1865YmVaLZcPk4n1TY4AIfDW1I6ytS+Cl16hTD/mt3ZWVq9HYqnsZ83j5KLXrMAe670La/apV6uQ5Mw1JgJw/QLgYgcrGChqjmg9O8RpqxUa/YhViG2S1Gu1Z71ned1NTNx64WNRg42iIN5NHGMxzl4lIkrA4ZX JzsqgXXiYTL6v1w+TyT7KxBAqR0cwNNmJbjSU6MqhHxe2y2wKi 1fj4Da7lGAfZfqxpqNWYwIylenH8K5We5hMOEzxVkDgh43W5Wv e4AztAlblYbmg/VDzlAlJPWu3sbIA88mbOHbOYYXCzXCIeW/bWHOcgSQhGWft9pfb23Q/ZUrNz4xows1Upn2seVxTY82PWGvHAfrNcIhcoFicc8gs1ulVdo PFVCsgssC7Q6sNY0O4QMBr+rH6FEWKamZtD5nPrqMIgd8Mh3bB S2bf8bzTOWu3Ef46iuq1WrgqHT22fVarI96LbvfZeEV5OLwy2S VS+KlEZTcXZXu1BcqUpik8omJW1rb4zjnqFsIMaxjXL3iHdxva NWu/3keZsIi2sltYGC6OYDp5G2dx7W0weVeeLhjJUyYv18eNhh1QFt imvKLg8GITx/Y3qtaYw0cQLGwgLMA9lck5BwvPZa9XsAJiH/Imt7lqkcljsSALnOhG0aFrglzLpONhi/F6MAi/Ka/ptxXSjp+KFSLzVeZNEv+xRNasyPDCvx+P0ecojpd23WfjFeXhz ffNQ73Z37k4GjW7xRE6+DYEGLJ+vn1ByK/oPW3ieJ+a7ZwLA6eAIRf7x/66XOOpzIgKXo0Xy4t8w2+T5GEy4Upfu8TjLWAG90lY5elsv7C8 4kN4UcV4BRrZ/LaUcUdXdGxPms2HyQRmmfDXSAcBnal3tu38Dj/2hOTD6Io3WIaF2rA7aZJJiPJTRmVyzuGHUFiQ9nbKAaPBO//sDln73AYl5xx+OIIVgCWZeb4eDDLNv0KIslFGZRJCCPE7I2USQ ghRLqRMQgghyoWUSQghRLmQMgkhhCgXUiYhhBDlQsokhBCiXDy jTPDrip3KsAXc+yTrw1lH0cNkUpIf4ghRHrDL8NuFj03086L+m Z+oO+e+r9dfF4uCXxNiBxOmBFut8/i2Wr069gLgSME7Cf9BxVv82QexdY49MssKG4YdMPFvRJEy0e2e PX6TxtrbLFwIAX5yC8Rnnz3vdPL26fiZLTyw3TgdSeeF421nbr 3PYG+am+HwdQnIwzl30e16Tc31YEAf1ifNZp6U0v9IuvOz5aXW a67hguR16Sx4L29BrjLRSyk0dh1F3MPxdxg5SZmEyOQXVabjRo O7vWA358yxiKdMXguADa4OtYHLOoq+3N5i+y4bETbYZSyXvV7e 9myeMnmFc9nrWZ9BaZpeDwav3iesLMpEF0f2JPZDo8sGDHvvx2 PrKAUuCb7c3tr3Z62CdK7qnb8ZDq3mbeIYl26Gw6+LBU7C5xA7 Aj82D91tX8RH6Jco3dnlIK5X/X445sN5pIERhco0m05xm7VqMvDFfH7R7V71+wyBCUaB2D1qhSg Vs+mUFntbSzNrr1UXfr83w6H3vcPBylW/TwcZ8BpzMxzyG8RX4z2OFhBJuur3uTVw+rTxdc4hCvss4g3FL5 Qiu8cxW62HyYTuqdIsZVrv3CqGZWjTYx1Qwfi5Wi5DRzzYB/1+PMZYh+evBwPb8EIO+ediPkdD9HWxKFYmODSwKbTjCuhi2Fan pq2bPT4651CqcENDUycL7arfR35xm23DV8ul3Yee0rBPS5itTN wfusDHFx0ocCdp/p8eFpAsuAur7JyyV3b+cuh6xzufmhGb58Gdfo9YgpWdFwnaHhm U58TPek+wZVfZeYyl16I0UCYko16t4h4vcPR6cMnuXuoViPXCK URJuBuNTlutxXy+Wi5PWy26k74fj+FEeDadHjcaPF956o7vbjR azOcwqKCBw/d+2evB9yDagXUUwc3Y9WCAZuFuNIIHjdVyednr8aM+73RgdsPj 9WqVBrSK8QvDKBCsdRCV6XzyvNOBjkLt2Dii3WAu0CIxJVYwnH M3wyG9q1iQZaQZesBGAIHDr3feK/Ai2sSxbSjwgvh/uAVhavOUaZskZ+22PQPXQl6uWfiU89NW67TVmk2ni/n8uNG46vfhYQ7yiQCh9HejEZ2M4PHjRsPGeNxo4F2jTBCmrWMF ZCsTPakUtKT0nrJaLtc7X7QchFrHpmj9bY0/73Tor4XjTZyHFlpXpPR0Zy8hFrT4q+USNaNerdLbGEOmdxaUo5 cjzy8qqgg8cVCZoH+nrZZ10uoFbnONckMavKfeefdYIZ7ltNVi/d8mCeq851LdOYcvPTXK5O2GTKMTds7l+fvx2HpBsy0gO9ToCjP Y40bDDmj4fVWML03b0F8PBuGIxHI/Hp80m/VaDeaserXK5sj6f0p3DQL+z+6sPTIHTNeDgfWugjSjqUGftXiU EA7OvKBgFsJLsaMF+2CY1LN228ZLnQhzTbsfFMsrfGTEWvPux2 Nb/rwEl5I4yXEquhG2LtmU5PGMMhVYVCtPF0RYF7FMbsV4SUdrbjs s2ySBzPC81RU7DsXgA4FTS1CbcRsKFI4zcFAhIB6ZPZ3UOMCF2 1auvbHKZN0DpmZA6QkYoFjiEsa/9EVbeTM3RUK8DnxcsJmz34bepF3oddJs4hOghFR2bpFxXPX7qN 7HjUamf4DMeaZNHM8eH/Eslckb9Jy2Wowa/0FfnlHDTljQ+tt+fbpr4ukW2fZWvXmm01YLfeh1FIXDC+KNFWw hZI7hPDKVCeZB+7i1NDJfVpmuBwObWoxOUCx27YPVGxsyWss8j QzfyzZJvq1WaNnoWJWqQfVCdF5detaxUe48kyc8gOPxNPBCa/2xMidUeIzlae+q12ocZNjzuB85sSM+6ycXhXjSbEKNkBjcYBfS 4NjE8bNrGRbzue0cIV77FK7aomDecVuox3grlaerZQp6RkJ8IP g80am66Hadc+ixeVUX9Rw1H20Qlrp51TuUH8ZiL8FYhPYO33Ke MvEMW5jMqAu60fhOwzBDZ7jFKyDSpyspSCg/Ns37LPrwItrE8Vm7fdpq2Ux5E05pmsLld14a7BjLrn3Iy/U6igraKPteNnF80mxitD2bTtl1SM0QnGNi+r8O61IBucoEETpp NtkTgVm58tRdOgsdgmGVEHoDm+n39RoSDXMBWvPM85e9HgrUdo KQGGYeI62zdpvl7hkMkdrv63X63Co73IaI6FmckoOnPIsfk8fA bbzINUOwlXgdRUiSEOXBrgXAGALTQt4ohJMfdsxkLUvOOTSj3g BiHUUYPVhl8qyFab6RME1TTFGkpvH11As/VCrIYzjaQGMa2segkfh/ZjN92mqFyuSdhFmF7eRLlQlzE2Es4UuBszf8P1QmJsNb+4C3bD WPuabplSFwUYMtc2sB9i4t5vOTZhP2sLxkexNpmeQqkzW13QyH N8MhZIlmMU+ZOBs0e3z8vl5jfI1So2xg1QNG7rPplLNB9jxrHm wF39fr2eMjxkPMDKSiYjxnM/aHyeT7eo1RMGIvViaMbLBchNLrmek4Z/Zttfq+XkMR8WI4z2RzXa9WsaAFBWgvaZ5JlA22++luZQFa6uNG g0sP8GlwsofLf/Dx4p7LXo8GDP4Exzl31m7jvFUjb5EbLIpUJqsW+GUP2jW2D2j+ 7LpqtEt5a/MwT2Z/Qmujo8kLqc1TJucc2qJwXRhGM4zXS/NLlcmbqLOEL6VgBcTNcIhm0659YIzMNQZAeEd4L7QPYU6Oj1CN 7DTVOorqtZo32XHV79u2ziZ7myQnzWbB2jpQ9EvbTRxzaVxl99 smu3jUK/RNHFu7nB2KUksqu+VzCIer17zz8DbL85x9BVy5Z3U7jB1BFSuT c87LI96K9xR+YRCWA247bjT+MFSaHyJwEOblTojywDnai27Xfj ibOLbGCbvYDF+9cw4du7N2GyvTvI8XD/J8upuFxWdF4yF6bFyVcN7pXPZ69WoVaxawfo9RswVEk4KojxsN fHR5a/NSs6wXK2kpxtskQUpw/tkVEHmTRmjKmGY2jK9QJq9Fsg0Rpot+RLSbvGBE3sFmM1xxwLY d78g2TVzhhYx4vYfKU1sR3jum37zW3rbYbJz5uosLJN1n37xNH HP1nT2PebawqcXkW/gysFxttVx65uC88zbqzFj2jB3hF/84bhPHsGDYH1p5TznnwnRSwHjVS1LmU0KUCtRSrAjwLqH2emsE PMtM5veed36bJPa3howU96c7U0/mB+W1QmEUeCrPUoR1wl52bDY3cYwQGD4XFBQEa7MWtleZzZTHJ o5tydtIcWQ2RNsk8QrTHowUFqDMePOapsyMMGqmmYWPguXNaDz 3jy4T7ej6U2irCCGEODhSpp9CyiSEEAdHyiSEEKJcSJmEEEKUC ymTEEKIciFlEkIIUS6kTEIIIcqFlEkIIUS5kDIJIYQoF1ImIYQ Q5ULKJIQQolxImYQQQpQLKZMQQohyka1M/+9//+//z1//+jsfvzn/92/Of/2vLz3++te/vuKpz3P89nz0J/vBvKKN/ed//ucXK9P/8u/+3eBf/+vf+Rj+m3/zOx/Xv/dxMxi89Lj9t//2FU99muPDX9mHHx/+zX7s8Yo29v/7H//jxcokhBBCfBRSJiGEEOVCyiSEEKJcSJmEEEKUCymTEEKIciFlE kIIUS6kTEIIIcqFlEkIIUS5KFKmTRx/X6/tsU2Sd0uZZZsk39frTRx/SOwEBfJRhSCEEL8JRcp02mpVjo6846Lbdc69W/rA3WhUOTq6G43eOV6P40ajcnS0Wi4/NhlCCPG5KVImSNFlr3c/Ht+Px+edDs7MptN3Sx+ARi7m83eO1+KcQ/bfX5iFEOK3IleZ1lGEhtja0KAQHLs4574uFg+TybfVymuvN3H8 MJl4l5xzsIY552aPj5lKs46i2ePj7PHRGs2QknUUrZZLhJkZ19 fFwotrE8dM5DqKbCzf1+s0TRfzeV6As8dHm3cUyHGjkVdiQggh DkKuMs2m08rRUb1atSehTBgzraOoXqvRynfSbLIdvx4MrAHwpN mEzCDMy14PD96PxzbwbZKctdv2QUgXNdJe5bNeXPVazcZ10e3a RMIQhwBPms3MAGE55HHV7+P8/XiMxPOe01br51+AEEIIj1xluuz1IAZY+/AwmaAdP221nHPbJEGLP5tOt0liW+3Vcsnb0jSFDRBihjBx9X48 toOYdCd714PBNkkQCExn0BiIxzqKcNt5p5Om6SaOMY6BGiF8aA wUq16tzqbTdRRhigiXGCAu2QBx6bTVWi2X2ySxVkQbODJ1PRi8 1WsRQojfmFxlQlPuHZe9HvQGg4arfp/L9nCDDWGbJN9Wq5NmE4Y4hpm5kGExn3tDNExubZMEGgPZS5+OX Qhsd9BOCAlEhSMh6AoEEgFSVxAg/qxXq5Wjo6+LBTJ1MxwywbiEjKyjaB1FWqQnhBBvQbYycbYfo4p 1FNHGBZMdV0N4R5qm6yi66HbxJ+UNw6yCFQRWHjy85Q92ELaJ4 6t+/4cdr1plCpl+igeuIvFIFUdsDBAjsEw9ZuJ/qrCFEELsQbYyWWMaT9oGHWrhmePSNEULXq9WV8vlJo5pbUuNlS 8zRigfhzhcv5Dulj9wEotjF1oUF/O5VaN0N5PEEZjVFXubFyCeykxhceKFEEIckGxlwgjGW4dW2S2Q S3fGsS+3t2maOudoRsODmLPhbXbVQN7cDBcsOOeccxh1LebzAo 3BpbN2G5dgo4N4eMmAruBPT2O8wZBVQUbtnLOJvx+PL7rdD/9xlRBCfFaylQkGLm8uxyrTJo5pPcOBVtuuoztpNnGPXTWQ95sk 55w3s4UAoVjUGExH4c9tkiB8GxeesqsV0p1QQUs8s6ENkFftgQ TbxHszWEIIIQ5LtjLNptNw7RxO0qrmnLsfj/E7XLstAialLns9jHgYDlc05CUFy/CuB4O70YgCZkPgn4xuE8eZcWH0xrjwJ1KO/+cFyDPXg4ENwSb+2YwIIYT4GbSjqxBCiHIhZRJCCFEupExCCCH KhZRJCCFEuZAyCSGEKBdSJiGEEOVCyiSEEKJcSJmEEEKUCymTE EKIciFlEkIIUS5ylQk7xdnd4bgnHrb2wQ3hduOZ4Tx7m3gLFvM 5/GNplz+xD5e9HveQTNN0myT0MnPV79PzwHmnY28rOLknmziu12q 2lVgtl6i6J82m3WxzE8d0snMzHL5dksTH8npluhuNzjsdbqNXH I6U6f3hNurXg4HKXzyLt7txmqbHjQb8O6+Wy9NW66LbxfmDy4D nVQcOAbC/JfZ0xs6Wzrl6rXbe6ayjaLVc1qvVq37/jZIkPpbXK1PIOoq+r9eeY0Aq0zZJ4Ci2OEG4LRS8TRzjcW8rVQ brPZJ33gOOoMJgGYjdwTbvTqbNy3ve+XRXVs/qevhIpt9FpM27hPcVfpnezUhkmKm8F1EMSykznXl1gOczn9oH6 2I4r6rYq16+9kn2S4vi12KbJMeNxvVg4PmOYa7ha42OQw8oA9h A2TYsl72edXRwPRjgT2gn3xH+xFuWMn0yDmPN28Qxht6Vo6N6r WbdAOI21DyOwfOig3dzb6hOd01hCPS0651HleUBt09hpJ7PCyS YDbp1wLGYz+Gl0LNs0DeV5zUjTDMtEras4MIDnxaKiG6fbBmuo 8g+ArdYqfHGi7TZHoOXtXUUhTdv4tgm3r4X731Vdi6sPMdXnvh 5pcQsV3augcO4nHO0F6HyQGMqT10Se36NbR7vRiPk4n48Doudf Wq+Yu91pztTEl+H7b97yTtrt1+tnSUHFf5+PPY8wth7KsYpTIE MhK5kCozJmzg+bjTgz5MVuLJzWg1QrxCyZ2y0zdGhkiTKwDPKl HmEyoSPGQN/NkBWmerVKv0KVkxHzIuuXq3OptPZdGodO6GNPu90MIJhCPROi//ThRLPr6PIOYf0hH6h0CVEjIv53PNsi6bqvNO5G40YKdxzILOQE KjXZa/nnOOD6U4a7fnKzqMuQobnDqQNRhKkh44Q4a1qmyR4pF6t3o/HjN16jarXaseNhmdZ3SYJ0nbaaqEc+EJ5M6K4G41gq2GBI/Heu3hWmeho0T4FaWG8tg5YPT5ttXgJBYiSQSHTUbKnCry/Xq2edzoMAcVO912ooogUEbGKIkCUg30jlaceMi97PVZsWrQ+E7 PpFIMST5m8tv601eJHfdJsPkwm9jhpNkNtWMznEJ7MeNGx4wuy ymS7WahaaTANhjtfmqT78fi01fqsPYxPwwGUiQ03X7Zt5thVt5 dCe6B3m22mN3FMWw09rNt4HyaTTRxvkwS3scftnc+MkYq1mM/RulFImBhII0czjDfdNY5n7fa31QoiBBmAKpw0mziPLDjn0Ohbr +229WRrjiisf17Gbv3zIgvnnU7mZ+YNaLybcZUeFH+0/kYVmH0OQNNCZfJ6ANZDIx6nEyxbB7yaA2vSJo4R6UmzyQSE3pA 9kSuoKulTv5f2T2TBum+GUHHoRn/K9gWFpf3rwlFL+pwynXc6/KjRG7AHzoQhs8MEc7S1mt6NRqzY+yhTODCy7cw+ScLs1Oc2zH4 ODmDNw3k0IiC05rGe5S2ICM/bc***ZHLR7aKhsU25tebVazUaAO9GI/b07XkLbsicAWLUNm121FUJxmo4uI4oPP8wmaS7xtSWqg0cAwiM OagN1rBmj8x3FGbEUybPz29msF7vwRZIgTLhKe/AJU8VvJqTNxOAF7SJY2heWGe8xKSFVcV7p54y2UC85IXHJ1tOA lMH/u8pE0fw4LjR4Ef97KQOxvrhV2NL3g6n9lEmOw3GO/GZ7JOkcAWgKC0HUybbyttnX6RM/EJokUuNRQXd2DAEeNFFM8QumHfe8xyf7rrG7D1hlhsDrExlsoZ vr6u+TZLFfE4JsWF65z1f717GOVJEK4/wOWJDUfMoKEz7vjxl4s20Q3rBUlNfqkwsJRsaiiJPmTAosX0aL E9ARUK54V87piGhMlnjm1dVipXJpoHCTPNsWESZBf4rUqC+r55 nAjT95ZHZN0IIsF3zztl0igrgieX+80xpmjrnvAXooswcZgUEW vmb4XAdRbPHx0owz7SnMtGIzwmD9Gm7xnkatHoX3S5TiKb2ejD AeW81RFhr0eTxNo5dQmVCyEwb/uSnctHtMjto1FbLJc5TaL3A67UammwaBilyHOrR4of0M3ab659 RJkR90myind0myUW3C8lEyXDtAKdeGGa9VrPigSi8pxbzOUsgT 5mYX7smmKXBwqnkjAtDZcqrKmm+MqVPa+/DZMJLzjmO2xDgzXCYt5rmF4UmaBzXgwEnJlH+Xgdlz4VwXE1XA HqBPNCtQVFf9np2Pu+800HNRNeNHwsqAF7Hs0k6bbVst1WUnIO tzfvDelatoi17hTLVq9V6rcZ1aDais3YbU5qV3aQFG46b4fDL7 S2aIbRxUIirfp/nw6aNM+QnzSaCxbxoqEzOOQRYr9W4mM2Ocuq12pfbW6xhw0R95 nk75w+xCZtdXrVDNMR+0mziERrKf0aZGFe9VmNKkClO1KFk7Ao IjmVPms2zdhuXEAVfBy7ZLBcoEwoK7xdvyg4ooRmVnKmdvDETb Ke2qqSFysT1L0gz55lS06+nhfBzt27e3NJ5p1Ov1b4uFl8Xi3q tRrEplgF03b7c3nIlwj4jlbDbdNXvf1+v8fnQDnHaamFad/b4iGXA+yTpbjSq12p2cYQGTyUnV5nwQ1rv19d406gl3i9tt0my Wi4X8/k2SdDkcWWdvS3v97k0al0PBlg8xmqK9XWnrdb5bv0VE4a4zjud 40YDNhw+wvNeLizbJGHId6MROl/Mpr3TOYeUn7Zal72eTT9WbeE3ideDAdvQvPNpms6mU6aNaQbrK ELs9n7nHHKNbD5bmPZ92WXo4c15KcHsDqKzKyCQLzyCH/DaKFDsp62Wl2VbbcKUIBC+X5s8CINdMGLBohUrFUgAssM10JkG KC9JrL2hMZP5NPA9LQAAIABJREFULahIn4bFfO6VJ8rwfLf2Ad iVC+FJvF977CPnXuVEDTzvdGBwtkli+PZ1vEWSxAdymH3zrgcD mm64JupFC2CKu//iAwkHke8T6ezxEWOvt9YD2I5oX7UWRSHEh3AYZfJ+2VrJWuNbj JSptHyIMtGMljdgOiBh7f30YyMhSs7B9hrfJsn9eIzjFT8XgJl OHdUSwjf7zpHOplPP1Pmm0SGPs+lUlVCID0deMIQQQpQLKZMQQ ohyIWUSQghRLqRMQgghyoWUSQghRLmQMgkhhCgXUiYhhPhdgGO gj07F8xQpE3wK0N0nNp76TNtZFhDuySaESAMXFfsDl/bPNiDeTkhe1D/zu7rVcnnV7190uwXtGD1upIGPuotu96rff4tmfTadersl0Z/LVb9fUNp2n0ObVGyGGXr/wTbHr3NP9c6SVqRM9Lhz3Ghwb81MX+mfDymTEJm8WpnQ6D/77BspE/btvR+P4cHZcz3lJZIpwc7rOBCCdZhyENZRVK/VbFMD/cBGoHCCY/d3tnjKhK0sccCvtLcXD5xivy6dBe/lLchVph+urI3/R27i8m6/zP9ApExCZPIrKpPnxhBb5mcOHTxl8loAbI1/qE3U7LZYNiL6owJ3o1GejnrK5BVO6GHrtNV69c5bZVEmDJK8pN gNyCs7b3hwN5DuHNiwrL/c3nIsuZjPaRW0/rsW8zm9FXgeMO/HYz5y0e1aN3rcjR8VBW/ROUefFyfN5uzxkeEgI9bTLnHOXfX7dsCO+uopE7wiMZ1e4HejE a9a/z22QOS1TJQTW7dPmk27x7+tvWzHbdM8m05/uA+u1eC1GdjvHTYl6yeQblPsN/Xl9hbPYiNw+0HRiGS/39VyiabDPgtdCRtQOFnPKwH4yPjRbkynzypTplGL6YH/Duurd7VcIjveI/RQhY32eZ7+qFiYfNYW2kW3iwY5LBxwPx7bERJ8FSFhtrX03t0m junrB+2h517SKzQ2evCeY8ct14MBMoLowjpWQLYy0UNPQRCVnV udylOvppBWWAKRLHhbqVeri/mcvnBgtcw8n+4UCG4x6XSH3swqO3dh9PeaGn+mjB3vCZ8EPTB5 42L6WYC7v8rOvalVJu6efj0Y3I/HSKcNnElFvOzgsBDux2Mo/e8w3BS/Fpe93mWvt00SOJio12o4T0chmzi+HgzoLpLNAuxFcB+M7xd9L7 Sk2IEQpjO4REGjb90DIt5059KJPgDxUaPhPm21aEDjd4e2Ej53 oDo4D88vYReQ/lDwIZ+122zZrgcDLxdWmc7a7e/rNQ44/cp0n0FFzEzzWbvt+fLwyHQuZa9az1gwMLI8rTLdDIdI6rfV6sv t7XGjkakTNtfOObxHFCAGl/C/Ch9DeO/IFKyF6c40iv+vo+i40UCZ4x7GiCgQ3WmrZcN8dsoqW5n22V6a3 R/UJzzCQaj1B0o3et9WqzRNoQGUYu88/GlWnvqLOzf+ztHEoyDw/22SQLHYQfihebVaasQjc/AOPTtrtzlUuh+P2cWj27GK2T2dyWbgx40GeyLMNX3s2qcObqQW 4ic5bbXYx0cblO56k3b+nL26ivFHbPt5NDp5XX7MeaSBNc9unl vgNx2tAd0/0h+pVQiYXgryCAMMOqBw3YvGEYF7pppKzgqIcHhBvDTb0UNlj0 mBPGXCsJVTKngptk2HFzr830sqWhvrso5rH8LBDcon3fU2bAK4 0ba15mHWjbehX57uxso4yXEqorPJ5v0FvGzMtE2S7+s1sld5Ou dEoxlvpjNA+oTlMOvrYpEaX7HeeU/kGDiqOw16Vo2srcAe6ygqnjGy3ngrR0dce2OfsroIKHXWK7zN9 Ww6pXda7yh+H0K8M+sowieARWuo/xj3XHS7PNCVTnfKhDb9rN3mDTCf4IZMw3U4z7RaLrECzfoRDuc zeIYtTL1aDaMu6IbjO7U3HDca6Ad7Alw8z4RiCXNXCSxpbHwr+ esXbAbDBmodRSfN5nGj4c30e+kpsOahqeQLZcfd5tGeweA4r6n 03ssmjh8mk6t+H+YoDrkoCteDAXoPCNyrS8+qde48k7VZEQgJ4 vOkK0+ZeANEglLEt+udn02n4fDCKtMP22CtRuNAurMGoLbZA94 NirstzrnFfI7hLUL2xkx5ysTAM5UJ1QKv0x7F70OIDwGf4XGjg cEEGkEu9MLBLimVCV+rPdLdzEpmFLZBgO/jxXzOp/KUybbyVCboij0K1qOHawEQy0uVKX1qWyO0hmWmeZ9FH5kSCPuN d9LeBp/U+H/YXNsRoV37kJfr/ZUJkxp4+3ADzUu0GVJT+d7DulTAM2vzKkdHnO1H61/ZmcU8ZYJgYDYo3Q0e0XxjApAtOyeHcJ5Z4mCI1jymHrrFELiEn T0Cxm7Tj3F3sTLBGy8ics6x72afwv+v+n088sM4Wa2mZhLLyzW teRfdLp7CDxSe7T0J8c54ftHQwIWGI84P8atHR5A30MLjWfPuR iP01q0yeY2jZ83jV5MGljHEeNnr2SjQfy/IY2icPG408DFyeoylUaBMzrnMqSa4RfbS7CluAV5EGMWGbTdyY UODQ3r8P1QmFrhd+5A+VSyAfnmaprPp1LaithpY+fFevbXOrZZ LmA1p9AqTze5IAUW/ZwrNrDbznjLx/pNm88vtLYZ4eIXbJKlXq1hCw5/uYvYSwxR7HtXlx5r1Wu3L7S2G6pzLSY1G2pUnXCgB+wBjL1YmX D1rtx8mE6wesZLDRUQ0d9wMh2E6GS9yzbggqDCS2DGvEOUB8/zfVqvv6/XXxYI9Qnv+YTKpV6toofjV/1jp8PiIKfd6rcbJhsrR0cNkggBh3kh3DeLDZIJVFfZZfOPoBKM Zuer3eYmfeeXpCghEgXus4SjzK8NvmJCdq36fLTWmWL4uFshmx ZjczzsdfNc8LrpdloMF8WIBAtJjBeOlynTe6SD7PKhSSBJygfb KRoSmhsdJs4mis2sfAJa62Fz/sQKiWrWFz/CZqnQ3N4m0YW2z/VXvcaNx0mzat3A9GDDZti4V8MzuRNbOdt7p2EE6l+7wDNb2YNj hzXGtlkvqnNVbrKUJz6dpOptOEfVxo3E9GNj+zjZJELtn8OUSO Du4hik2c0WN9xTyiBx5T22T5LLXgz7ZcqCA3Y1G9Wq1Xq1izMc CuR4MELiXOyFKAuo2v0E7Z87P2X7p9v+YvfC+OHueQxOANXL4r DDZXtmtjD1ttdApvBuNME0bflD2k8cjXtR5a/OQHWQTYdqGiy0ATF5si7Em2x5YZJhZjOsoQlPmtVdeI5nJ3Whk GyiMhOzBq2hSUG6XvZ7dPMJ7BEMc51zevg9ernl+E8csKJsRZB CFgyERCx/NoF3bct7p2IKydclbMZiH9s37KZ6dxBJCCPFSpEw/hZRJCCEOjpTpp8BaCW3uIIQQB0TKJIQQolxImYQQQpQLKZMQQo hyIWUSQghRLqRMQgghyoWUSQghRLmQMgkhhCgXUiYhhBDlQsok hBCiXEiZhBBClItsZfrz16//69/93e98/Ic//el3Pv7ub//2dz7+9PLjf5vNXvHUpzk+/JV9+PHh3+zHHq9oY//hH/7hxcr0l//8nxfz+e98fF0sfufjz1+//s7H//7nP7/0+Pv/9J9e8dSnOT78lX348eHf7Mcer2hj//Ef//HFyiSEEEJ8FFImIYQQ5ULKJIQQolxImYQQQpQLKZMQQohyIWUS QghRLqRMQgghyoWUSQghRLmQMgkhhCgXRcq0TZKb4bBydITjot tdR9E+gZ53Ohfd7jZJDpTIfZlNpxfd7kW3u5jP3yjwtwj5RVwP Bhfd7iaOPzYZQgjxduQq0zZJ6rUaNOm808F/6rXas3qziWPcfOCUPsdiPq8cHdWr1fNO5y0abhTCark8eMj745 xD2b6/6gshxLuRq0yz6bRydHTcaDjn0jR1zh03GpWjo/vxuDhEKMR5p3PglD4HlOPtxjRlkIR1FOGlfGAahBDirclVpvvx uHJ0dNZu88xqubwfjzFouB+PrWkLlq7ZdJqm6d1oVDk6Om21Lr pdDLNw2yaOL7rdu9GI4ds/70YjhrCOorN2G0pw0mzaYcpqubSXYF1EyDh51m5DO20g1vzFpF 71+5WjIybAZpyDxZvhEMKMgWC9WuXVk2aTYdpU1Wu1L7e3OL+Y z1FKKBOkhAEi+zZAyt4mjsNs8qVc9nrMSJh+IYT41clVptVyyZ bxy+3tt9XKXj1ttSpHR2wxMV6BrtD0d9nr4TYMNdDfP2k20zR1 zqE5xtBqmyRo951zuA2PX/Z6+D80AKMxGzKsi5s4vh4McOl+PF5HURgI7ZBIHrXHs84hnHq1 ej0YIIqLbtdGfdxoXA8G9Wq1cnR0PRjYxN+Px7PpFJcQ7I/QarXTVosphE5jSIoAmU1qKgvHSzz+xG3IiJRJCPH5KFoBsZjP0 c5SojhKwBl0//knhMq2v+lOw+7HY7TgmH9C3/+40YAyodVGgwubIUTOXqKYeSHjTs+EiEAonAgEdyINp61WaJeD ntWrVVxyzp13OgiTA0FkGX9i7LKJYw4l0514IC6kEALmJRhJYo LDEmA2EReesvm6H4/vx2MthRBCfD6eXzW+jqK70QgShRGPN9thlzzg/3YixLa5vA0DhfNO56zdtgOm8HFo2PVggDFcXshovjGAYHqwTu+ i2z1pNnEnL2VOFyEQConFm8SyY8Q0TRfz+c1weNHt0gQHwfDiQ hlCV6Ax1DMGWJB4Sjs7BEII8SnJVibM+tjVBDTupTtLFEYM6W6 8ctpqpVnLHzBQQFBomnHPOopoj7KGLO9x2q8gUWHIaNztwjkKJ 57isY4im9QQBJK5xCNPY5xzUKPzTgfWPKhsakZgeMTqN5fYMXw GWJB4vIK8xAshxKchW5kwHMEUC7Btrp3tcM6hU4+hBmSG6ya8M Qqa/pNmE80rJ1EwYEp3rTlGZt7jEBUvZD5oY0EgvHObJA+TycNkkha Oiphrztwwm4yLAVJXoBaeSEM+UWKUUnsJKaTG2AC9xDvnkHjnH IePiPdhMvnYJexCCPFGZCsTJeGk2YSdqmKm6KkoV/0+ZKnydPlDvVq96vdvhkPMDLGt5+IIDKHQ1FqzGNemX/X7X25v7ePbJMHAwobMVX+eoY+BPEwmtIalgRXOAzKDxXX4iTEm liAqlB87dsGlk2bz22r1dbFAqhCXNTamT+2NVmO8ANPdWPCi22 Xi8ZRN/J4r+IUQ4lekaG0emj8cWHuGS5s4xiWctOv0cJJLJ2CVYphokTn 44DoIG+8mjilgp62WtSiuo4hJOu90uMDBUw4vEJvyilmpkcn9e MxFH9eDAQZhdg1CGgy8uOjuvNPhco/0qbExfTpT5QmkF+CziecYa88tOYQQ4tfi+RUQmzjWAjAhhBDvh nZ0FUIIUS6kTEIIIcqFlEkIIUS5kDIJIYQoF1ImIYQQ5ULKJIQ QolxImYQQQpQLKZMQQohyIWUSQghRLnKVaTGfP0wm2v/mF2U2nT5MJm/ne158SrAfvz2ziWPsKWw3glnM52HVyjy5P7Pp1PNNgybo62Lhu X1BkmaPj/b+t0iS+EBylanAJYQoOXYrv49Oi/hlgHNOW2ewsyUdQ1v/ZGHVyjy5J9iYn/1gOJeB/+jjRuOs3aY4waM0vVrbfSkPmyTxsUiZPiEVORgUL+e806Gb6XT nnIX7DkM8UKkOKwObOLZONdM0vRuNjhsNxAX/A9YpqPVVXa/VCmKXMv26vFKZ1lF01e/D6erXxYInrQXJswfej8cPk4k3YMcj6yi6H48vut2rft/6HNomCXxweJecc19ubzPPP0wm9AbLhIXMplPcczMceil0ziFS5 oIRWdvmJo6ZtpvhkLaOvPNeoc0eH3ESnpZYaPAmxT9XyyUesUG x0FbLpefgEY9DmXBP5s1M5M1waAvcFuBqueQr81LFsuKfi/kc6fxye8t0ogLA9oIwbQj2JbJieJXEq1FeEW3i+Krfp5OUzKrC NPCqfYksXhSRra42eXxZn5jZdArvl2zKIUX2HqpCsQygJO1RMC mA4RHckvG20EcBPJbdj8fWNYEVqgMmSZSB1ygTvE7AWITODtpx +Bmi3z9cgnMKulT3gvrhF6NWq1erdP2Abto2SeDu6LLXo3kK9Q m2hfNOB30rDupx/rTV4vnM9CMidA8rgXN0OqNKd2YxmzYEiLTVq9XrwYDeqtDFQ67 tebSzeYVGD09IG5oDtLbwjoHY69VqvVZDNlFo9Oxu82g9aJx3O ov5PLwZMTJYa6WBhcTmt2I87dovn0XEUmJ5Msv486zdrler9C2 CN8iXe9pqIVJYbDKdN3rKROeKCOG80/Gqis0UnVXaNCB5KGqEcNxoWN9aDBCXKkdHN8Nh5mfyOYBfG3in 5Fv2ZCBNU/pkeVYG6IsZdbjAxeXdaITXbZXJewRvHDd78doXvWeSUKnkdbPk vEaZ8IWjNaevP9QPNvT0PYjhNlqB0JksXTShWf/RaNZqaZqulktoT5gehIy6tU0StLap8ebunbd4Dtet53i6RFotl 845OiRE2jId7DLZ9+PxNknok9ee38QxLPj89rxCs+WJZnoTx9B yxm593dLjIiL1hqHpU9mw7hm3SfLfNhtoKqL70WOo1eggkTGy4 S5WJu+SfdF4Zbxk+wpQINYHKpDXualkmSURIx5HQXlVxfpsRBr wflns6Pqg2PF/XrK+MVl5cOkT97JPWy12eqwyeW09BlWpcQHqHd79GA/xvYSsowjOOdNAmWxpU5lC+fFe9D5JqtdqmqQoPy9WJs9TePrUW ys+6dl0Sl/jaGczO7/prt20dRetAGXv+3r9MJnAw2xYC8/abWuOQyzheYvnBtBSMf52M9OGeFfLJR3s1ms1a4xyzrFjbs+j0 GwPFMmwzfTdaOSc420owLN2m/YHNtNImH0FmRmxueDN1E4GC7e56FR6b3wfZcJTyKx9U2lQhaxg 4C2HmpoaGYBKhb0ZKpNVLFtV7OiHr8y+QSi6LSVmxHZ9WEQYcX 7W5ux+PGYh769Mp60WKgaP01bLu/96MLBnzjsdWtrZXaPt9+eVaZ8knbZaYY0SJeSVypS5gCfdjUjO O53LXu+40cDN7H2Hc/Jha4h411G0iWNaVO5GI6gO7nTOwSzOnhH0Ax3/y16P8hD217ymysKGuDhtNDbejUYY4lSejuHC83mFho+EaoHSsx 7ZYVizxyaOQ8nMzIiNiDdbU5491lHkuYdPA2XCiM2Lwpry7JEG VShs+jMTz5JByOGbojLxTEFVYXWyb3BPZfJy9CnXH8MS8OX2Fh p80e2i1wKTA9cXAFb+fZYbwBhoP3na01D+mD2yHa+b4ZCmF1va 6KOkWWLJGrJPkq4HAw7RRMl5sTLR/sMznmZUdkY8NLuYIKk89YZOrKqlu7E2etMINjTReLPxkD2k534 85mQ15TAzRgaLSm+teWzF7CXAFUR2ttw5x7LyziMLMDp52mwLL d0NFDB8QS8SsVsxWEfR9/U6zZJMj1CZeDOadfv6NnH8fb3mUIw9SuvT3WvH7Z+hTKJXkRYq k9c/wMul5COF9VrNm+ewWbBv1pudCq15oTKlgTUPhZ85pNsmCYoor8 B/XaAQPDCvhq8MnRjmGu9ln+UGaZqulktajPOwcz+se/iuMVXMOzm9NJtObdXFN8LKVpyk2XRar1Y/5Uv8lDyjTCfNJgfgF92uNdld9fuwn6AP7rW57PV4f3pwFuRhMv m2Wl31+xxbMJZ1FH1brayJ5keb8vgIJeAjP2YRHh/XUTR7fKxk/aCHhjjEiGDtJJldnYUAv9zefl+vbdooG9/X63UUwdqzmM85+vm2Wq2jCIsp0PYhO2ft9rfVKiw0GPcqxuLH2 B8mE5YzYv8ZZeKbta8PkVJvUDJcNIECQaFd9fu0biEKGjBnj48 sJasKmcrEdR9fFwu8qXq1SiXgaDhzXJinTJlVpUCZWPfO2m0sk fAu4WV9XSwwM/c7NGp2UII3y6UfWFqC/xfLAIawL11iUHlqrqjXavgTodleCxaF8jdP+yRpH6UUpeIZZfI OvGaOBnCctlre78MrZgWU96cH+0q0v522WriTv3JAswX7GHr0W ErEBBw3GkhA3nkPVFPexubPUyYEaO1y551OqCVeIHnnvULz0sZ BlW2L82L/SWXiIC9MyWI+Z8l46yE5BkUibRTrKLLFnrloJUwJhQHv13Zciu tMtjUvp6oUKFO6W2WD6RMvefY9/j6Nmmcus/WhXq3aYiyQgbDpCG8O8T49+7F4Scqsum+RJPGBvH7fPCxF+8kv 1jYHYWjOOZjOMruruBQmgPOfxVFv4hh2qmcTiZyGd+J8eInJDh/BpRcV2kHKef9gbQo9qc4rB7B/eXpxhe/XWz/5M0EVgJ86McHhNBvD3D8Zn49XFOyhQI0Kqyi/u3dOj3hPPnhH12e7/+IDCQeRbw3HQ5Uc8+8BwagIk/Bfbm8rTy2KQogP5IOVaTGff9ZVT58ArgZ8txjxS2GuTn5r7kYj Wqsue73fxGQnRPmRFwwhhBDlQsokhBCiXEiZhBBClAspkxBCiH IhZRJCCFEupExCCCHKhZRJCCFEuchVJvxC3h7fVqu3Tg12a7XH 7PHxA3/8uE2S2eOjdd4qxKcEG/tiy+BnWcznmZ7PXvHDRLgv+b5e7/+ZY4Ndb4/dAyZJlIGX7ZtHz61vhN0CwB5v97tL+Ix5NjFvFLsQH45z7qrfp 4/ji26X37jd29DuNbePy4l9WEdRvVajX2OrInktAB2/wQ3xnvvmiV+OZ5SJm13y1/Jv+uN8igH3xueWpm8UY0Hg9LuqHbrEJ8Y6UsIO93ZP3kwfmweR Abi8YfjYLBEjJ+wpHj6C8xSwy16P7o+lTJ+MF/hnorch/Omcmz0+wjvGl9tbb7vxq34f522zzvN5DmfDbaRDB6aw+F31+19 ub72d9pGkq37/Zjj8uljYS6vl8mY4tFEjnMrO74M36r8fj+Gw52Y4xL6fuMc59+ X2lp/ubDq9GQ4zo/tye3vR7X5dLKzTJm8XUe9PxAL/sCxPRr2Ooqt+/6rfpw8qLy4GhWBZOM45mEa90r4fj3FyNp1y4LiYz1FQV/0+M8UsIA03w6EteYTPauDFheQh2b+DI4lfjnPjqD59ut04nH9m PlIgA6gt9ij42G2V4CaNcEcbPjKbTq3LLoSwj3+mPZMkysO+yr RNErTU9NyKP+HPGO07qgg2yoST04px9mrPY/i1j7tSPMU6h+G/HebTfwydv/FgaxtGTV9Kebvie8aE9c7HPFwTwSEF3RR5KbEb9Vd2/gAL3AXxa7RZo4cb+nzKNG7QVwWf2sQxvR/hHniTCj/1SuDSIiwo62DXyy+03CsHZiEzeWfttsSpbGzi2M7xWBfp+Ei9b kq6hwzQ5oEalTnZg13M7Z/8Fu7H48teD92dm+GQvbRX+7S1ScrzlSxKxcvmma76fbQsnp+C0 FUo6jr832DADhc+bIUzd+3MnGeq12r8chAImsttkuBPVDIa35x zzjmYAW3UbOhtJ7HAmufJRmXnEmY2ndLlOUaQjM462UPU1j6ZF iqTVz6UFoaAS8gmv7eK8R6EVuCy16NnYZzHI2HrUNn53bkbjeD moGKGp9AzpIGu3xEgRs90M4qagGKnW53UKCICxKVM65AoCfiub SXEd4qqddXv47bzTqdeq1mfohfdbr1WC7XhstejlaUA59xFt8v xEM0ztOfn+dK1X9Y+SUJHap8kiY/lxfNMnms7+EUNvYjWazXYuDxHpeF5SzjPxKe2SeL5/E6N48H0qSKmu2bRusfNjPqlysRn8cF8ub2FcQDua+Fw3RugWNn OUyZ4DqzXarQ2oEhhQKs8HTVWnjq3tc4J6c/GOiBHyYSDFW/4xUC+r9dfFwvruBYRMQ2chWYW2AO1o16kAWbGh8nkZjisyGNbW YGZ2vZgtkliuxEQLZrO4JTdHhhq2zChK3Y9Bau3/QbXUXTSbHoeLO3sAAwz6XPKtE+SLns91cBfghfMM6GtR6OziWP al1BdeLNz7nowsE5Oafa5G43C85bQmpfuBhNs9Ou1Gi/ZFtN70Lbgzjm7mAKKgtteqky8Go7tEJ0nJOlTH1R5ypS3KLFYm aC4mWtSOOLBfy57vfAeOxQD1uk7B81poEw2DV6ObEFlDrtpYxT lAZ/zaatVPPvCb3af5Qbwh2sVCDd4rlVQ5e5GowIzL6ofbg6Vaf8ke UopysxrlAnaY9s7+gNFjxvVbpskOH/SbHrnUR2txoBiZfLMTemuWiORuM0uLmAK11GEH2o45+g1HIG8W plwNfTog9GPbX+hiFaZOMKgpYJjpjAZz46ZaJrYxPFFt8uXggL B0CfTqu4pE0I+bjRQhjbLBcrk2XlYvN7bEaVlE8f1Wi18Tavl0 vYd8fXtKQMI81l/V7DEhLfdj8dW0u7H43q1mu7WJfE86mGeoc87uVouM+MS5eQZZa Ip5qrfh30Jdir01mEs4vjJigdqgDX72PN5c/JsDRHpl9tb2pRY/ypHR1hf9221QpIQJmfpv6/Xq+XSrtew80zQAGoMh1BhlS1WJmTtotv9vl6vowjptDNGSOTs8 bFijGYoNySSl2zWsJoRWcNa3gJlop59W63WUUSLIu7kj1HwVYd 4ysRhlp0WelaZWJ5n7fZVv8+xUWpmy5A8WPMkVGUjbypoNp1ad YE8QDCKZQBrkZ79iStqTqZV/7jR8FY2IYV4hN2sy16Pdbs4SVBKrcf7hXjZCggOwzl+woG+P4T KW5nGfop3vvLUjgSyV0BUq9b2bRNmL6WmMbVikBk1n6KJL7NaF yhTamxfOPh5o3fGFFqbmy03XkIUmzi29kaWW4EypTubiX1Bdnk 9TtqpQYv3FvBbFu+dPqtMSAMexE9hbEEVJE+UhMzPHJe4rOCs3 a5Xq5SEYhnwPsPMjysNfsZra+MmjusHHNdDAAAgAElEQVTV6km zyVUMrDacvHxRksLWTLNNJSdXmTZxjEkOHt6oYpsk2PwDaxPsD c651XKJmSHbEmEEEJ73bvCO8M51FC3m89VyGXa4sGY6vMSoV8u lF2Bm7lgC/AUibgvvgdHDiw6FM5tOt0li55lsuTnnUG42Pesomk2nNpF2XUP 4JwJEGsIsVMw4NSQsXr44iuJ699uvvDRgqxhmP1wAguRhQWNmM sTHEn5x9k1t4ng2nXr1ZBPHmd8LTj7bdPD+go8ddQxRhw9638i hkiTKg3Z0fXM8ZXofzjsd2DPfum/IZSlfF4vv6zWsmjLZCSF+BinTm/MhyoTR0mWv9w59Q2uyq1erkiUhxE8iZRKHIdOcIoQQr0DKJIQQ olxImYQQQpQLKZMQQohyIWUSQghRLqRMQgghyoWUSQghRLko2g Pi+3ptj8wdrg4LNn71jreOtDglv0SwQpQTVHj8P2xStFWVyONl ++ZddLtvWpmy982r1Z7dHfLVnHc6dH2bmZLDRvdGwQrxpizmc2 8zEThVYrNQsAMWa3tmk/J2n7b4pdnXcyDdZr/pL/zZcNNdIfcYfaMY8wKXMgmBEQ88Clplcs7RcYZzDlthZYbgKZNt PeABOdPzixAv8M+EM3bD/E0cw13F18XC210x8/w2STLPk7Dh5hlv21MEkrmj6+zx8etiEe4/O3t8fJhMZo+P3KT1+3qNwOk7qiAl2yT5tlrNHh9pnbBOp/iUtdTBC8a31YqJlzKJXwhrw/C8AtIzerpzTmE3/P22Wj1MJthHNU+ZGL62DhEh+yoTvKRUjINaek6izQ064XvB2Ll 4yTtvyXODxL2rt0nixUuH0M456x+oYhzXhl4wVsulZzkMjRU2J Yv5HL6gcNwMh9gp3Kom/sQX65yDtyQvs1ImUVpgqMi7ZD8QbPZv/6zsPC3BE9Jpq3XZ6x03GvgKcFuoTHCIfvCMiE/Ay+aZ6C8VbT1dF1sZw+aeqKbYzBT+gaz7PuhN6K8sb56JYw6O2 +BbAXFhn3zEddpqYQM3uBdCdPb/8JB01m4jwH2seZAcOIPZJgncz0ARbcjIFDJLn0z0ogtzh5RJlJ b9lcnD+kY6bjTYSjjn8IHwNrhcwgEHSxowiUyeUabjRgPVjkLl uaHDyJ0+bdOdAl10u9bwle4a8ZNm82EyyVucxoabkdJleDhGSX e++6zy0b4HBbJ+wzKj3keZoHk3wyEWFMEXLbTNSiwyiC8Ngso1 SPR4K2USpeUVygQbxmmrxQFT5ambWnRh8X980YiFs8j4tA+fGf GL84J5JvpjTdPUOQfn2RhMoFHGzZs4tuOtk2aTfiqfuKPNWnEX Ntx0tAofYniQV62vVe9BzyO49bNpo95HmUIfnf5wqlazprzMkV/l6Ggxn0uZRNnI815t78lUJrhjh2EAZ+ysUngmtOY55yrGIP//t/f2zKkD4ZfnR3EVMSpysHOwc7BzgXOwc+ybA55sajDhbBXcbLam xJ1/bdVsAHdz8QVENBtNfwJtcK7PPrf1An6Xfc+vFIBeWq1Wd5/up1v9CEGeoUysVfdJgs7KIAzRPsJfezKsbeyscD+8pmb3e7ewO yl77DPxUNZamNtnsremzKA4Hd9nKmpOInoIFjFBecudrSRlElW D/l5vhsOb4TDX5WtWmW6GQ1jO7U474ARQDPE7q0xpmp6321mrvhA HlMmasGCSQrcAR1kR05qHSpkjQ8iXGI6yeoD92cFPVty46c/VipMa0MuBDKCRxftimAfz2m9Ho9RM0MBVEC2UIsYEd8TvxeNjy dw8/D5rtewUDxYnGPSo2diJeOLu+yRBPOGzXMokqsnx1jwM8eZa4U6 bzet+n39RUfC3Fz6sf+oziSzPmwFx2myiBmd1jLk3mImAbAeFa AQBJ6ehgka/KrvfUmQH4+DWLo7pPhUbFYLDrVmLBOfmXfV6mGLHAPm9VPncPH 7OhY1TP9Ing17NTCDMjSceVsokKsvxynQzHKIg2w2HOMPox90d hqBqxTMgsuVOCFCoTKvlkmOVs8kEwzzeCej+Y/hkNplQafAXTSTvc5/c/WSfJPams8kE0+HsOc45fPmLo14Ii/n8fjy+H4892dvF8WwyGYThbDKxD7JPksV8biPvxYR71lGE+y7m c6+1iLTy0sfGk4eywQpREWDHKzpkC4hXOXhZGpl8EIar5RK/c6/KVilCEK3oKoQQolpImYQQQlQLKZMQQohqIWUSQghRLaRMQgghq oWUSQghRLWQMgkhhKgWUiYhhBDVQsokhBCiWkiZhBBCVAspkxB CiGohZRJCCFEtpExCCCGqhZRJCCFEtchXpv/jv/7X/zSbadOm7cjtv/zn//zpcdCm7Qtt/+//+l/PVqb/+3/+z//zv/03bdq0HblF//2/f3octGn7Qpv73//72cokhBBCfBZSJiGEENVCyiSEEKJaSJmEEEJUCymTEEKIaiFlE kIIUS2kTEIIIaqFlEkIIUS1kDIJIYSoFlImIYQQ1ULKJIQQolp ImYQQQlQLKZMQQohqIWUSQghRLaRMQgghqkWZMs0mk0YQ1E5Oa icnjSB4mE6xf7vZYOd7ROiy262dnMwmk9yjzrnf2+3v7fY9bp3 Luz5sCfsk+b3d7uIYf8uTRYjXs91s7sfj7H7n3FWvx6zIk6/7/ate73Y02idJUZjMtLPJBOUI20Wnc93vbzebN38K8T0oVKb78Rh 56LLbPW+38RsZ9xOV6eN14rOUCSX5stvFXymTeFeccxedDvOb5 WY4rJ2cWBVZRxFqg3UUXXa7jSBwzuUG6ynTdrPBto6iQRjWTk5 KVE38yxQqU6Ner52crKMIfxfz+cdU0FVTps/CUyYh3oldHF/1emyG2kNQHRyyynTebrN35Zxr1OuL+Tw3cE+Zio4K4VGoTMiOt OA559DYwQ8rD7s4Pmu1sGe1XPIQTrvsdtmRP2u1aBNYRxGvqp2 c/Li7w/4SZfIMAjhnnyTX/T5NjovHx6InKo+Pc+52NDpourQWzrNWi8XVu3y1XBbFfzaZoD+ K+N+Px9ZkiguRCNy2m42XLDb1spYWIY6HRftmOPSUCfvRKrXK5 P21F66jCDp31mqhNihRpka9nltShChUJlaOjSC47vd/rlbssNvK2jmHivWy270ZDtHTssrUCILTZvN+PMahq14vTdN9kt ROTpAv11EEa6GtlHOVCYWHsgSZxN3P223evby/lRsf3heHTpvN2snJzXDoPSxK2mmzuY4ilDTaMfAIaEt63U2CS6 gos8kEAZ632+sooqjvk2S1XDI+s8lknyQ2WXjmzXAIk0gjCGQV Ea9kNpnk9tFRBChF+GsbQ7wQhxbz+T5JtpsNCoVVJgwSY7vu98/b7Q95MvH1KFQm5xxlgBt6ErayRnvKtpg8ZaIp2R7aJwnqZVxl+ xDPsuZ5Jq9yW19JfHDotNnks0NdUMB4GqUFIayWS8gGpAJKxtA uOh0vAuyrUbSgcCzzKMn4WzLOhLh5qce7C/EynqVMuRcOwnAQhtyPBmjuDAjWJ0UDVOIf58CscefcOorYjag9 jWGysoZ6WSHx+0z1OvZnbYAP0+lVr3fR6bAPkf5dBdtMbBtlDC QrY4ykVxIY7dz40M7G***yOorsabs4ZqfwrNW6HY1QXDlbxNu8 xMwdOlpH0e1odNXrsS9VrkzOOS9wWinLX6UQ5TxLmWwfnReii2 +v5Z6sNW+72TTqdbWoRC75ygRj8XW/zz3OOYgT2vhenW6HQz1lyu3QoL+CfLmYz628WbG57Ha55U4LhC 0rq0y7OIZBjNsujkviU6RMngwzcTypporMJhO7eanqpVX6JGko vbTgSZnEp3CkMqEnZMeZ7sdjXHjebh+vTOnTIOubPoT4JuQr0y 6Obfs9TVPnHBr1q+UyO/TSCAKM+nAWQFqqTNZ8l77CmgdbIseKvF5R7rW58cHznrVafFgM X3nWvO1m8zCdesY3DhcxGmmaWlul3ek9GuSNJnv8PdKaR5OgrH niTThSmdI09SbjYXQ2TdNBGNpSkLXmeSHfDIcaahK5FFrzOMh0 1evR1nTabGbn5vFrJ5xwjDJBUS46nV/r9Y+7u1qBNS8L8jquXS2X7MlddDo/7u4gJ+WqVjQohfuetVo/7u7wsNleGrp6iPbP1Qq3g64gEa56vYfplBLuRaCoZ3Y7Gv1arz nDEFUApzlg6p1Nlj89ziC4HY1wVaNe1wwI8UqOVybMUEVjFOUX 2e/PDIjHx32S7OIYhvqiGRC4sGi6ufjHKZsBMZtMOKyCVrnNf7YFB Ivc/XhM5UhLlcBOr4ClrvY0ZeDgJ6W0pOEcBIU95+12SUYvVybnHEO 2RgnvtNVySfXFnLrs5VlrO8gq0y6OcQkMm3h2PIJzbhCGSP/cWePY06jXB2EoWRKv53hlSmGIq9drT1NVuZ9TbU+bzeyscbtdd ruaMi6KOGrdvJL5M/hMjyNS3iQ3IYQQ4rm8dkVX5xyaSBedzlWvBwOXmkJCCCFezBus NQ67H6bA3QyHWqVRCCHEa5AXDCGEENVCyiSEEKJaSJmEEEJUCy mTEEKIaiFlEkIIUS2kTEIIIaqFlEkIIUS1yFem+/EYy+VlNyzjfdXr2TWz0zS97Havej18Y4sTuN2ORlhK6yMeSAjx HFbLpVeW3wmsF/NOga+j6GE6fZhOS+qZfZIsHh8fptOfq1Xu0ewSAXDWkz1/MZ9/TKL9s+Qrk+ft227W6YO9xK7KmuslTGtDCFFBipbLe/PAsy4H3wr4s4YzjlqeO+kUztWCAKt0Nur1rGPPQRhmfaedt9tw pW2Xu4RnKTW135VCLxhwTcR1V/EXqwsfqUx4qVAyrkeu1ylEpfjqyuR5f78ZDnN9Pl12u/S3i4Wn0VDeJwl9KXjpMAhDnAOXodgJf0BqZL83B8aZ2PvJ7jyo TPYEuquQGyEhKoWnTLPJBEb4h+mUO+FKFGtjskeyi+Pb0Qg7b0 ej7LrPl93uWavVCAKMAnDN8ut+/6LTue73KSfOOXq4tvsvu93tZvPj7g5RytUDNHz5N3dl9DRNvZ1 0DL9PEvj5xPpqXvx5Sc14K1Ul9gG8XJnOWi0YdrGVK1P65OBOr leFqBRWmVA7bzcbGLLgQwB1PVyGwrMalOO02bQnZ8eQEDKcwtA JJ3zHbDeb83abvjoHYcj9gzBkpwf1DPxo49ZZycla4bKn5bqY8 q7K7hmEIVzSbDcb+E9YzOfwUXd06ooX8nJlyt1KlAkZ650MzUK Il8EaGb7HWO3C5LWL48V83ggC7odEpWlq/f7t4rjIJ5lnzaM8WOPeZbfLfpK1znlWlqw39/RJTe2erIO3rCHxGGXCeNLDdHrR6Szmc4xU7eIYncXb0UirV78f L1cmNIW4HVQmDj699SMIIV4Oa+TZZJI1hKyWy32SNOp1uHv+uV pxqBhWENj9fm+35YGnGXnw/u6TBB6uMeRD8fN8QB+pTJ4HUdzL9nWOUaY0TSHM9Fs9m0ycc/Dnu4tjDZy/Hx80zpSm6SAMaycnHIQUQlQB1shwymybmzCjpWnqnFstl3Qezf GeXRxzRtxFp5M1cx2pTAj5fjyeTSbWaneMMsEZNP+iq+f1ZqAi z7XmWfCYiLY1fubOAxSv54OUiaY8zWkRolLYPpM3lxpzcWG/4k6O69iKnmNRRYGnxcrkdWis0e8YZUJXj3/XUWSn6pFGvW6jd95uexMZSpTJThP3lMnrnIm34h2VKbtpTosQV YM1snOuUa//uLvD/sV83qjX8ZXIWatFsxVntdVOTjh/r2hGnFW7cmWCluyT5KLTeZYyoZOEmDjnLjodVk334zG/h70ZDvkUq+UyG9siZYL5zs5IxGyINE1Pm82sBIo34YOUCVaCt4 68EOK1eN2aRr2OMtuo11EdO+fsp/esjlfLJU+unZzkronAAPFpY5E1z4YPRUSUjlGm9ElpvOilfw9B eU+RjW2RMuHjXLvnZjjELHaNTbwfWjdPCPEX+PYod6fXRXDO8Q P8N7kpwtknyXP7IozJMXc5ftoCvnbKPp1n4RRvjpRJCCFEtZAy CSGEqBZSJiGEENVCyiSEEKJaSJmEEEJUCymTEEKIaiFlEkIIUS 2kTEIIIaqFlEkIIUS1OKBM+ySBQ8nrfv9hOrXfTs8mE2/Px1OFOLyM1XL5RWMuviW7OP61Xv/ebr31DuCc4td6XZJX90nCBfSQse2mtRLECyhTJrsa1Z+ltIKA6/Viz+f6zqpCHI5ktVxe9XpcgAtLeH2JmItvzyAMsVTdabNpF29F DXDebp+32yWOArwV8ODrFhsuzF1ST4gSCpUJuQ0elVbL5TqKUJ k2ggAZtwqqUIU4HIm3DK5dJUyITwTyQzU6bTaxUCnW8KaXh9lk Yj3bWjxl8hZdRc5XVhfPolCZoEPe4rvwG4bMSlWYTSZXvd6Puz vbbV8tl9f9PlbkXTw+Yud2s3mYTuGtGUe9Q9vNZh1F1/3+db9vXXI55xaPj94labEyOeceplPc/XY0shGD5QER5i2wEwIM06W9i3Pu52qF0K77/Z+rlRdnPA5alNvN5nY0wsk/7u646v5Vr1c7OYHP0H2SeNY8Rvh2NGL4qTH6IZG9ZxHi9Xhume h+CT7VqCjOOVvW1lGEfL54fCxXJhyV4Vo8i3xlQi6snZyUeGzE CXCNTFsf8jHcMKNTDzFDdx6tp0YQWAuhdZwB1yzcUNfD54rdf9 3v2zhklQk2hPN2m/08VOjbzca7O+UkG7Hb0ciGhsfBkv7QZnaD+CDwWoaduAppYpff R4StNW8Xx96t+YD0FmqPqvkp3hBkfpR0ZEUWSToiAo16HYfQzb oZDuE5AvkT52SV6WY4PG+3P+ZZxLchX5loyitp6dDWlxolQ1WL 6psuIFFBp8ZvE3TCGrj+iFa9jkNwzU4n0LUnr4POOWvyzlUmWC FYgy/m88tuF+dDJv//QlivQzn4vDgNhxAy/DTDhVpunJEI6yjaJ8nNcGit6jZ6njXPKpO1xXsPyJ6rc845Z+M vxFthHapd9Xrc6ZlMqDqUKO63ynTWasFmwBaVOvriuRxQppIs5 akCciet0s6539vt4vERVixkXK925l2yh2BJwF9Ux7ejEab6IEA IVVGfCbrSCAIYx6CR0JjayQlnDaHDR59mtmUHjWHx2yfJ7+32Y TpFYbPK5LUr8Vw/V6sfd3fHKBNFnT0hdLwg+TiN0fBiJcTrQX6bTSbbzQbOAGEtKF Imzzk6Q+A5N8MhyhRM/ZfdLgenhTiSwnEm24cgqBlzVcHWoejlWHvac5UJh+jXMrvZQ1l l2ifJ/XiMzgcfhLfztnUU2dsBxAdOwyiu5+227cxlffuulkvY5TCMDE0 tVyabCNln95SJsTr0WoU4Fs9nK2SGTtbtmRSw2t9OrsvHmdI0b dTrmp4nnkWhMkGEzlotNo44HJJrSWMdiq7JabOJCw/Kz0FlKplgnatM6K6ht0cLGwxingYQa3IEUKDZZILeGx8HFvYiZ YIUUc6PUSY+BRuVuCNKspRJvDfn7bbNUZywUDQDAgXcm+5Urkz n7Taas0IcSaEy7ZMENrGzVut2NLodjSBLNHkVKRNyNr6K2CfJ7 Wj0SmVCCbnodH5vt7+3W9jTbJ2eO87UCALYyhABGMegN7ej0e/t9td63QgCDCAxJji0eHykWvDuzrldHGeteVaZOD8Ckwlt9HAy5 +ZZZUKs8ICIFQ9JmcR7czMcInvjL/r6ae6s8afR1stu97rfx2/nHKziOC2rTChBGhwVz6LsS9tdHKPVb21ozMFFypQ+DenzktrTO MrLlCk15kFsuVMMLN43wpxY4U2T436OM3kGQFwCvak9GfQgMNk 4p3+PJDfq9eyEC0bYKpNzDuLEC9nrkjKJ9waFohEEV73eWat12 myyP4RydNHpoEHGbLmL4/N2GzMdGkEAswQOedNQa2b+rRDHc3jdvHUUwajlCQDGSKytb7vZ 0CSFL5NY7+PMfZLAGoBz0FlBsLmHvO+QMCBkh1K9OFgQIIaXvE O7OEZQvJBCiPuuo8iGiZ2r5XIXxyVxZuC4KfpYNsK8lofsXbKx yqYq7qjBZPHm5Ga/9KncYeqpdwnLODI2w+H0h5LiKUQ5WtE1TTNdNCGEEJ+IlClNpU xCCFElpExCCCGqhZRJCCFEtZAyCSGEqBZSJiGEENVCyiSEEKJa SJmEEEJUCymTEEKIalGoTLs4xjp13D4yWp8OHv9Zqy3ALy3Wj/CSrsiZyD5JFo+PD9Pp4vHxXVd2gBcPuxXdjlGi95A3B2n7rKUB mKRFh6rvAQirc1V5+TgsTZLdiZQ/8n1hSYjcQOwKL7kB7uL4098j4va5cXgrvvQCHAe8rXvbw3T6kZ H7RLwF644Bi/sVuds4a7W8dZK8xQBrJyc/7u5KwofLds8vyZHYBf24XXQ6tiJwztGn1JFRehl2zUA81EEXCV lfId6hN/xK+n48fnE6l3PabNLvcwXJOmSiV5eacQxdgnMOKyl7gTA7XfV6 WKXMrhVLGvX6pyxJvloumQOzPj6+Lrlrin4VDigTVg6eTSZccv Q9SmwFea4ywUdAo15PTTV62e1iY8lk2aZUwGU11sS0i9Vmec1y rrydFyXr0o2v2IvSmy/HuVouZ5MJ7ptdFTeXEmXaJ8lsMnnDbPmCRsmR4GGzNfLngl4CG iX2RUBm6Ev6Zji0bmI8dnH8c7WyfgAAXhzXmTxtNpHDB2F40en YEOAX6lP6TFaS7RqAX53vrEy2fNLREfeso8izRG03m4fplNUET mDqrJZL+3cXx7jcZsfZZIKeGa7NRgz7YW5i8xNXMRq4Edxw4GS 4pXiYTm1XnVfh/F/rdfbxvTjzKq/li4YhinG2GuWq7XBlTU9RtpKCs4Da395C7U3hwPCq17PJggT30 jD38myUsPa5F2dbxdNzR26YSBmbbov5/GE6terLlwJTJ9KNbwcdpppxDmIfygbF6PE98qZ4xYg2LsSit14 IAJnn52qVmpzmJRR8OiCdvbfPp+BNGR/vRs65X+s14snngmejovT8LHZxjMbKabPpucG0uREdnaKa7n48Z ovHnjMIQ9sNWkcR3hQCt+bim+Ew6x46TVNUQcznXungC/WWYLaJny0vNv8gEzIH8nxG1caEb5l1V4nF257DpaW5yu3P1Yqu Bhhbm9o22vYvWnW5CcKgkCD/ijLB+oS8u08SFGDP7IOGD9tW8BkB30jpk9MKvF3r96F2crJ4fL Tn0NLlxYoNea/JX8tzyWE9xqI1V3tywmTvZR8E1gb7+PTPhEvwgNYvu00cKE1uA 98KD4olvd2QkrWZPSNbmqbW2e5By1tWmZiYeFmIv/dcdmF1b79NT6aPdXmMioxSh3RD1cO341mM8ezeQ+Fl5b5HtL6t NQ+Ped3v2xA4tGNvZ92GlaQzAmQGpt9IOiGjscvmq10c20xl7W AljY9Px7PmwSGTPaF2RIfPqw2R/hi8tDUvnMvY0Br1em4/FW/hvN2+H49Pm03q+j5JLjodu5/+oi46HXTOztttZBhccj8ew7suf2DnabPZqNcvu10slI7z11Fk+ 4jIwKhtIKI3w+F5u11k5MQtBmE4CMNGvX7WauHpZpPJ/XhMryLIKvYprF8ehmb/oojhAa19GAniPfi3VSZ40oMzPRRCZCYcvRkOnXPrKELrG6mA3x gIZclM/66bWODRSEF/Aq/E1jteTv1jMXvKLlYMDirTzXCIhgaiZ93ynrfb+ySBy5nakxhTm fgUzJS55dO2FnOViTu3m82RJiwPz5pHGUDkkYZFFUeuMlEsU/NCj4kJ3VnhL9INPhFqT30Cji4gTMTWOuq1DhWZFPiLN0LflfDO wFyx3WxswyWrTLWn0T7bMMKh02YTPSqqVPbpbJuM+orCj+aUHU rMLQK4L94FEpn1KdPqmHT+YLLK5GXRXH+1HvbpkHqoRtEns/X4zXBIyUdvMrf/YVsGth+ASt/GjTnNupHD22RQbKYgr2af1GqA9ZTG2OJdW2tNthOMx2E6IA9Qm RpBwHJ62e3ap7vsdmFWKVcma3tkbYZ0ZsRQRqqZ047heTMg8Mp ZWXupgJyB0ruYz9m9gOrgHNRNf4ru4yNkDw1YvLlaxsxlQfm/6vU8+9VBZfKiitxQ+7tNjQhbF++IklUjRCDb5rWO1V+vTLs4vu r1uOFJPWWyepn+7QYeY/jYkOC5ykTx4PMenInA6NWeegneFD6kD53cs5Fr06dEmShFvBGE xEtS5sA0T5kYmk0T3JT5qmTgyrMW4C+bMp4TZF6F54XBB1LEaZ Bo0uEl2tCqxvHKBEMoDZv2HFsMkUq2urzsdj3zAw6hmZ8bq1qm E8bGKIzz2H7c3aHN6tUeVoHILo5R52Sf1GrA/XhM2aBKDcLwut/nfeG62ksEdPK8p2DS8VDWQMqeWbky2fzDl1L728T1za15nAEBN +o4lC2WaBTg7bI6gAYgrRfzuW0tZjXPU4uiBF1HkXU7y87vQWX Kjap3FQtS+nf1hEcYhCEqHdtSI1Yncms9yoBzzmtH2zS/6vVstG0Mc5WJ12YjX3tqTKQFyoSdsNjgZXmD0vskgbxlG7PrKL L+jmkFZbsEzWQ23HijtFSZitQim6THKJM9hJtS86y2Zd+CTWe8 uEEYIhvYYbmsO2Ma+rKbVeVq+njNKpOXRWlw4zwaWMDsObVMn8 k+LBLTBohK9rTZLGqMZpUJAy25iZw939bp6yi66vVguENGzT64 PR/lHZPpraf5opdblJJ4QCoTLRPZeYCcMFKuTPZ2Vpm8Fs93VqbcI lTeZ+JROC9P07RRr0NOWDeV2DTKlYkRoETl6hn/ZvtMduSgdlyfKX1q8qNdnNvgtU+UrUadcxh4QIKwXNnSaKWLAz x25On4PpP1K2r7W16U0Jb3ZkDYlLfSlQuGdtHRQcQQDdpFbb+Z BfKgMtm2AiYgvD621KEAACAASURBVF6ZUBMxDra/6OG9eoyIIM+UvGKaBFCdeRrvBV7N+sKrT9F+sifYwlKE93Te6J HtJ6VPnRIKwDEB1oxxpagCydVCVvrYb+v6ImVK0/S02cSccpt7DzYsPFFHlUhl4uV4cCvtR/aZipTpH+ozFb0DjkL9MbIHgc21nN3AGaI1M+SQPtUgaIzvkwQ9 a1xeokwcdqYFgGGi7sAUANbCtka7HY3+jDMFQe3vcSZ81rOLY4 wZeuNMuDUHNoqqadsk501h7vhxd8fxcD4XA/xxd/drvYYtolY60sPhfUwvhEzyuXCLg+NMiNLtaITbNep1ahseoREE jFLtaRaAFxrqrOt+375u3JrtEj4s/3ozEawyXXQ6+PQSD3XR6WDwDA/1JsrEEH7c3T1Mp5y5UPQqmc6pmXfDyWNevvKKwJ8xv8dHnNkIA ra4rVWzanjK5H11hJd+cO6G93Q3wyELbJqml92uNXOharYDTgc DZIYchCGGZHgjBDIIQzsbAlkozagF3mn2wT1JWMznV70ehie5x 36UhmEnL84IhE1Yb5zJFqjTZpPlCNN/kD4IgWUTGTs3QahMXlLjkmrmtGN4oTJxyJ2bHaJggxQFlSPt1p bidYpZI5coU2qmk0FFGvW61yfATpZ/1iDWBsiykXvIm5uHM9nLKVIO26HJtefY0VT7LHYbhGFJyUd7iv Wpc87GvFZgZrTR87bTZtP70jZrqcgdeeKtz1ot9gUZczZE8PeP 4JnSmztbpPY0N897qKKJ+M9VphTfjdbrfBdFysTsyqO8u/c9ppd5eCPOyOfGV1900yqQtUGh/XTd72O64zHDkF7hxTSWs1brdjS66HRYYAmKasnAW5EyYebUWav 14+7Ohoz9jSC46vUaQcAZECjCV70ezrezVJAZMKDrKROu8qazX 3a7jSC4HY2QLLmRp3kc8+XO2+1cZUJWueh0bkejs1bLpg+ewsY 2N0GoTEyQ29EICvc9lQmfQ5Y8GMZLvCEoHsJ+Tmf03oe9xezvz ySxp+QrAVx1Px4v5nN7GjrduJbfclpr3mI+vx+P7b1YIeL8xXz O6jX7+Di56LMha8Ph8/LpipJxF8d4lvKkJuso8lKSaVh++XazOTJK9sySb6Qw952hWUFF CExn72/695e29o7WMumlSTYL8a/90ta7V+5HuIgq3ldRDzibzrW/bafl+Sp9Kh3MkAy2vAHxuaAgeDv5lo9cVylbeFlReAUWIKlLGm RegDZX2CrIngNDDs60SsOcxv66l0thwvFqqtVymX32bBbNsovj xXyOWuW83WYW9S7ZJwnTx/s4CZXDarm0sfIe1pZlm9S4/F3XPHtXvvmKrtm2tqW8f0YwoSjbdPJA6+/rZoXvDb+028XxPknQ2j04Sx6TJPH2bX+iPF8VUTJOKd4K1Mv8O wjD536e8XqQbSgzyC2fviTg10LKdFiZaI4rz1uwCRwcHRWfhWc +tV+9FMH841k+X6BMmHJS3rgRrwcDP7ej0cN0ipl4nyIJ5+021 pXAELKqhefyzZWpaBUDsC1ec8GCPv4xt+NcOFFNMFvhWa8p9+2 X56tccIm61B8A7WOenfmDgUVxMZ+rTngB31yZhBBCfDmkTEIII aqFlEkIIUS1kDIJIYSoFlImIYQQ1ULKJIQQolocVqZdHP9ar3+ t11997uMujn9vt5q2K8RBnHNYydDbv08S6xVaiHeiTJm4yCk3+ go6CD1qvyZyXGr6NYEQzyOc9QovxL/MOoqw/iEWasNOen21DMKwyJGSEG9IoTLRSwK+ludan3ad3RLeZLX/2d9+H16JVSZvrU8h/lmwhCBW9NluNvRbgbWr7ZlYSP6gw3UhXk+hMv1Z1dus7cEVlOm H6fd2y6P8ix/obMHzrD0Ew6DtS203G2sfwF98MA/vGPD4buUQJoXcqxjVX+u1Z7ujMu2TBJ4o4XyB5+Cqn6uV1y9E/OG8Fbe2we6TBPc6MsWFqBSzvx2wcqE5rDRoywLW38oaQrCQyj5 Jfq5WLAgoTV5RQmGxRcwzDxZZEcW/RqEyeav3A+s7wOt28K/nA4J7sCD8Qb8AXMvOBuJ1v+jtm2uZ869zDot1cnuYTnEVlclzC YGljj275UWnw0Wp6V2pEQR0qo0w6WaJq4W+8n0I8cGslktrCDl vt7nQrWfQG4RhkUNnlAu6bbsZDukvlIUF7kXgULT25FMDZZm1g efASfyz5CsTq36vquV+Li+fVSZ0d+j+hC5PkCnXUcTaHI2vImX abjbI7jfDYXZ1O+vWBTkeZQaqgzXnF/M5OnlYxP6vPtNTIcFSZnTBjqYfArdXwdk2Y05XK7hqHUUIoREE b/ZmhPgo7sdjuLC76HTsQrfWoAdTXu7QLFa8xVXWJz1CRqHwLrd+/GaTSSMIUAytK0vxL5OvTNb9jN1Pj6UlyoS/ud7hmOdsz6NImdLScSbr0Bau6pDpIUUUVEpOWjrOBE9OiN4+Sd BJgoZ56WBjjnvBlEcDpmZViK8FrAKnzebNcHjebjeCgHnYGvRg L8m1s9lCui1wao4GKy9B+eVfOJqxtxb/OPnKRAXyXGZZjXmuMtn+hPU9+jJl+uP5LQgYVZQZL7Ttk4P2tF SZnHPwKVl7cniBM7PODmyUrPXP2gaPSHYhqoI33Q49GP49bTYx 5WEQhkXurI5RJvy+7vfhuZWuZgGKszfhQvzLFI4zwRxHH/UAvRP4mOHoEQ4d02diOKjfkdE9s+GRysQYohND87fXxUGj72Cf Cc+FIbF9kvBMyl5Jbw/dR26yRYivBd11A8/N3f14jDLeqNeL3Noeo0z4Qbe2nlNzqGOjXtfEPwEKlQl1OsTp9 3b7a73mzAJkUOoNMjG6554yeWci2znn0DtBz90e4k2tMnnqSGC pq/09nwL3Zf6G5GCsNatMZ60WNMzGltPlcSYOXXQ6v9brH3d3tmOE Q7z1/Xh81etJmcTX4rLbtUUMxYp/Oae8yDN9epwyoSzzEvt3tVxieAm31jQikZZ/aev5AMVme/SwetWeZjdkeyG1v2frNep1WsxoQPDugjCRs632ZD+N4iCQ7SRx avtZqwWBOW+3rfygCHEqB/ZAVs9araterxEEtObZABE3PJd3iPc66L1biKqBsnA7Gv1crdD2 8joup80mZqUWhXCMMqHR+ePu7udqdTsasZjvk6QRBLwjBpw0a1 wcWJ0IE+TwpS3myNmjuzi+H48vu9378dg5hx845JybTSY3w+H9 eGx7V/fj8SAMF/M5M59zbjGfX3a7gzDcbjYI0E5h8PZYEDfvS3XcGhG2ZQzh2NFd nAbHl/g9CMPVcrlaLi+7XV6Lwdt1FOE0W3R5oQ1ZiK/FPklQOrJlPE1TFM+SrozN/Ls4tifjL36jWKFk7ZNkEIZoFFrNgy1dRUl8xIqu2XGmLwRmkEO KOG1PBgchhHg/pEwHgBHc2huzi4kJIYR4Qz5CmWANe6uFWT8e2Btnkwk+HP7s6A ghxDdH/pmEEEJUCymTEEKIaiFlEkIIUS2kTEIIIaqFlEkIIUS1kDIJIYS oFlImIcT7sk8SLTgknkWhMtlV5t4Dz8m63f9Zn+WWL20uxHdlu 9lgxcirXu/nasX99A5z1mrdjkZUF2958iL2SXI7GvET9bNWa/H4yKNY1uvNn0V8Dz5NmYrkBwttfUqWlTKJfxC0BbFiHpY2preL 83b7tNlcR9E6ihr1+lWvh/3HKBOWaoUb632S7OIY5YtLqEiZRAnPVqYSLw/PcgDx3I4R/KC/JhrOuSKTAvbnKtMujksCLDpUtFSEbBqiagzCkO7N0qdVktOn1c G9VcORsY9RpkEY0gU7sWFSmY4sR7mnOee0LMu35Chlwu+b4ZA+ LK56PetaYjGfww0EFrpHCNZxbWqc9dFeZ30dEWvNw+/zdpuuoS46ne1mA7/miIaNbW40EA5jftHpMCs75656Pe5HgxHxcc7xprWTk0YQwBDBp 8DJOMTSu08SBgjPAiyZq+WScZMbJ1EdztttWwYpGJ5HpTRNa0/eyKwy3QyHjXrdkwe43Mx1A3jebmNxcToEoK0PgaCIsbw0gmAdR fY0lJ1dHLMesH40xPfgGcoEcWKNjKzAQ/fj8WwysZ6NipRpnyQ4VHvyaG7vm1UmKgFXVrXCwKJSFI0/vt7rdSy536jX4aM9fXINhZJJh1K4Codg4qCbKCwAWHvyLzWbTO CVil6isTA5lvfHIbRG0VQ8bTbpC8o6tBaiIsCrJ8uvZ22jhlGZ cmUpzXhpsnjKB+MefOigsLCiQCG1HtGccyhE6ZMbXJyzWi5rxv G0+AY8Q5nY5WetnZruFA79kYEgSIuVCX+LrHm5ymStbfD1nv6d ZRENmrChBIgGTqPp3HaMbOBpxrXgdrPBIboZxLq0NeN/3cYWxYPRg6cZPC9UigUYCSgnNKJS7JPkotNhdZ9VJgoSftwMh6 fNZq4xzXPZbrHKxMKCvyiwuJYy47nT5eWDMDxrtayxUaby78Qz lIn9dys52eEoVvdvpUy8xAvQDgshGraNxmh4PizY6/IC9wJ0zi0eH6/7fVoMPGXybpT+3Qb0yEagpqkWokrAEj4IQ9bvWWVif+Wy24Xr5 0YQ5PZUSvpMHMfywqfxkG5wGZR3Gv5iqhQsFrej0dd1ZSByeS9 lSguE5F2ViR0jmLkRCJTpZjicTSbcVsslekI0xHkB0haHmUXHK 5N10MmZ8TVjaeSmsiQqAoxyLD6gfJwJ1rbzdptjvR6Nej3XQXu jXkfr7ZXKBJxzHIXy4i++NG+jTMyd1qKF0y46HRyCVc1TpmwH/DXKdN3v4xBGhhANa/RDDK96PQySQbSgELCwe4Y+XHKkMtGEiIfCmYgDJ2jYOEiZRBWA VS1bEpGfaZHLnZuH5l3u7IP78bgRBJ5BD7Z0dLNeqUw3w6G1h2 MyxUueX1SSt1EmdD44Lc3mWojTRacDGWAmw9+zVssbbnmNMuFe jAZCttHAoUa9zrJRe5osx8l7***Ru+73H6ZTHipXJkYDXyxiZh HiwKuuej2YB8/b7Ve8NSHejEa9/uPu7vd2y41yct5uX3Q6v9brX+v1RafDomfn5mF8KHc+93m73Qi Ch+n093b7c7XCZFeW91cqE5Tv52qFwDGF7y3TRXwqhcp0Px5fd rvIRvZ3mqar5RKz41Iz9YDz3GwDajGf0yyGHGYnKcAm4CmT/dIWv3mJvS//2rl59+Mxekjn7bYNdhfHgzBs1OuNen0QhrYdZyfRLeZzBrjdbL CfE+owNJX9ENj7ywC9R7NxuBkONVorKgIysN1YxJxzGBbCTmba +/HY5m2UndzAWRxYCfDQarm0g7IozulTqef+XRx7p3nf6mKTLH0z XrtuXnac6VOoSDSEEEK8HimTEEKIavFaZVotl1WYZlaRaAghhH g98oIhhBCiWkiZhBBCVAspkxBCiGohZRJCCFEtpExCCCGqhZRJ CCFEtZAyCSGEqBYHlGkxn1tvsPDregy7OP693b5yDZ59kvzebn OX2ceiqJ/i4uiy273q9eTjWXwztptN1ofLarm8HY1uR6Ofq5V38o+7u+t+f/H4WFLMd3FM39CNILBentM0vex2VY5ELmXKRA/HdrsdjY4JN+sw6QXYNVuPP/TecHXXj7+1EO+Ec86u2QrgHQNOW+i9In1ahhyeZbDqa6444TS4 koFv6NNm86LTYVtT5UgUUahMXId7MZ/vk2SfJHQ6fowevLcyfSJSJvGd2MUxl+f3llK1To8gMxCV83abL ifgnDO7oqtzrhEEnmcKuEun0xyVI1FEoTKdNpu1v/3gpU/uVeBtDxmazSj+xQ/4gLjodLgHfvOw/7rfZy8exjHegrayy24XhkT41/B6/daadz8e4/cfJxdBsFouV8sl7kWXzLnRsKbCxXwOFxUXnY63TDj2I2SrTLZU N4Lgx90dGo+I0mI+Z5R+3N3ZAHmV92j34zGe+qrX0/LJ4gNwzsG9C73NglzPgciTnqJ4F4LVctmo17N9KZQglDs4xWAZ eZhOcQ7WMkdtUzs5+XF3xyKDMojTtpsNxxqu+32t3/+dyFcm6yvP7qefoX2SeM6T+BeiAv9G5+32/XiMQ3DPDHcSNeNhL9fdEVxmQB1Pm82sPTrrnKkRBJfdLpbcx70 YQiMIGENGg2ciQBQD+LzAIQS+TxLIGBwB0Hf7drNBq7D25KzWX kV/UeftNr0AoFTTX9TNcAh7Kd3b4Co4v0HMJU7iw8g6TPK8iKF0WB eCuReCXLlKn+oWqAtK3GI+h62PigVv7jfDIfefNpur5RIjYbUn j6OwNG43m3UUnbfbgzB8u8QQn0y+MlGBss2Q2t8+9LLKhL/WmsfQqHPWx2uRMqVHjzMhNHTv6GcdWZ8SSym1hQqasVoucRr8z zIQiJbnrhA2DcRwnySzyYR2DJQZ61CRPU4oEGLr+djFIRTObHp aZ/BCvCtZZfKkBW0mz7Nf7plpqZPZmvEcbUv3ebuNphiamPZ82mZQ VFH6bNMNGva8BxYVJl+Z2K73+kzcv4vjFygTw0F1jzbOWykTT/Ni7klpNhqzyYSO0q96PWy26+bFwYa/T5LF4+OPuzvPUp/rBdh6y82a13EOTJc2DrkvSIg356AynbfbVCZrBs9VpkEY5vaZ0 Oxjq9QWBLrK9bxxZgsgrkKr7qLTuR2Nfq3XL3poUVEKx5lQgXq qgNqzUa+nGSl6gTLhZK9z9vHKdD8eQ5lgrLDbPklKlIk6PQjD2 WSCcnJQmXIl36ZJNg5F70iINySrTLR1g9rTfCgvA8NE74W2mM9 psbdgnAl2i1cqU5qmuzhezOeUqBc9t6giB+bmNYKAmWAdRRhWQ S7xKnpkuHJlYiVrK26vC/IByuRFYzGfQ2Os6Wwxn2M8FjfiHA1rzYP5jnaGrDUvV5lwiKO4 NPQhAW3pmk0mHBMW4r3xlMlOxkufyiYUpVGv2ylCGE72QtsnCc aB7E7n3FWvx7u8Rpn2SWJLB2KrmX7fhkJlcs5x6L4RBNCk2snJ ebuNdhBV5KrXux2NMGLvKdNZq8UZEPj7MJ3yyztkelx41mrdjk acaWOVCUa2gzMgjlcmGw1OH8Lwz1Wv9zCdwpIGKzkf87rff5hO mQ7bzQZxuOh0fq3XPHRQmTgR48fd3Y+7O8SBk3F5I8QhW+CFeC eyRrnTZhNz3pxz1/0+B2Jnk8lZq4VMixkKuR/MorH1MJ3i6Hazueh0GvU6T36lMtVOTvjtP4qYpud9G8q+tHXOe R/b3gyH9t1zCnWjXveseavlklpFSeAXUeftNnPnLo5xJipi29lyz nGSm9caerEyXXa7udFwztmpd/ZJd3FMkea1mJvH6MESyE5PiTKlabqOIj6ynXZoE9x+2CjEB5BV Jpvzs4WFOb9kKRab1b3cnr7ammcDP202NZH1O3F43Tx+7vDie2 QHeD4FTzuFEB8DJkxpxFQcz0es6CplEkIIcTwfoUz49vbTJQHR kIlMCCEqjrxgCCGEqBZSJiGEENVCyiSEEKJaSJmEEEJUCymTEE KIaiFlEkIIUS2kTEIIIarFAWXabja3oxGcMtyORl99wcTVcvkw nepbdCGy7JOkZJ2hNE13cfwwnT5Mp+X1ADxlHLzdOooQWkl5hH NqxA0n2w0LHTnn5DPw+1GmTFway27Wa3gJdvm7F1Oy1vjLeJNY CfEtKfKoBOhMAIXodjTKPW272XiecHO5GQ7hdfq83W4EQe6CsK lZQA8LuJy329hDd9V01CS3gd+MQmWiuwf4PN5uNliNu3acC/BqKpMQwmOfJD/u7i46nZK1u/4s7P1U+1sfSx6X3W55xwuXc43/NE0HYVjU6fGUydYnzrnTZhMXYlXoA88pvhSFyoQ1hr0cA3GCH6 NdHF/1elzsh3/xAy4hLjod7oGDPhgGF4+PzJeX3S69H/EvVhKCUwy4ec0Wg10cw9IIM6ONzD5JaIS87vcppffjMYPija77 fQQiK5/4B9knCXxUZpcQ42peWQ/rNeNjjMDPmeeKIruWq7dI2D5J7Crm8BB91euto6hEmRAOK6jzd vugIoovRL4ywSNyNitY53tFPm0hKnAnAZdiOASZOW+3cYgu8rz FXnlfdthPm01v8fwUfsmCAEdPm03rGwmH4EWCTiWoRnyo2pPrK RoqredAIf41sl4wbJmyVUGuTqRpupjPs72u7LATrl3M52gRsuH onDtrtaAxq+UShr4iZUK/jXtQ2F/z+KJS5CsTFchr/ljFeoG3dVgD0A1nm6tImdJSax4khy0mdOZw99VyCSdMNib4m1U m7Kff9CJ7txDfnqwy5eKcu+h0cs8chGF2xeRcZbrodAZhuJjPM ZgNcZpNJtbKBxOiVSZvux2NePJiPlfL8jtxQJmyPZXXKBPDgeS gjfMyZYKx0XqCt3d3zv3ebh+m09vRCAFaH4NWmWhnyO0jCvHvc IwyraOoEQSDMMz1HkvXf2mabjeb39vt7+32djRaPD7iN4qbN6A 1m0waQZBmHAammXGmxXyOmme72cA3KQcCsvZG8aUpHGdCTe2Zb unENs1I0QuUCSe/TJnszJz0b2XaxTGNezfDIc4sUqbc+wrxD1KuTHC43qjXSyZAWW XKdnFYDL1CTVE5qExe8UR1BLWTMn0zCpUJ5rKzVst2rjFWhL4O sgIaO2mm15KrTOygIHB0/K0keONbJcoE8x0ty9aah1uz/FjH51ImIYooVybM8M7tKtlzsqU1a83D8DP/oupI0/RmOPQschhjTguUCRciSlCpsscTX4pCZXLOYapCIwiu+/3rfh8dERqCadn7cXf3c7WCaHnKdN3vr5ZLKtNFp/Nztfpxd2eFCn0aHLru97PKdNZqZT/Hs2FedDqIqlUmXPJztSq35jFAKZP4x8kq02wygdVku9nYEaDjQ 0jzlGm1XPIbJoxa2cYuv5i0lpWsMq2jyA53HTlIJr4KZV/aYpad7YxfdrtWITjzDXY/q0y0+112u1QR73ycyQ+ncLIdQNrFMSQnVzPwiRVMdrbHZgdL8T Uf+2dSJiGKKJmbB5HwtmxhwUyibLDZMzHxgVZ3ah4+dcKh83Yb n9amBTMgbHVkJz2Jb8DhdfMwYTT7UQLYxXHRIVyIEygD+Os1vn hmbgRwd28nljbhfgghjXuM88FWnhDiDTlvt4/5Ej9NU+dcUQndxfGzZsliFEDfI34nPmJF1+wMiNeDTlIjCBaPj 4vHRzS+1OMR4nNZR9HHr2I3m0z0MdM346sqU5qm6yiC6Y82w7c NXwjxAj64MOL7SFlHvhnygiGEEKJaSJmEEEJUCymTEEKIaiFlE kIIUS2kTEIIIaqFlEkIIUS1kDIJIYSoFoXKtFouH6ZTbr/Wa++rbJzwid9df1gEnHNXvd7NcDibTOwd90mCxMnuecFdtpuNT fCH6fT3dvvKmHsR9mI4CMPrfv+VtxDfg10cw1FF0QnwLGM37Ec xTM0ie89lnyReyPSXkQXONbIrRDAQuxNRQp5/5SdWzrmDy1IgDbOnZeOMKGGpmpdVF9+eQmXyVszj4q3WS/rnLrvwYRHAomGL+Rwf9nJ5Lq4NyOVY7BqUL7uLt521Wq9xZphd 38x+9Yy1y+SjWmBBS7iivuh0clXBrm9pP5xHMUwzXpeOJzfnZ9 cs3ycJ1m7GHW9HIx5azOe4+2mzaYuMXbcz12XBsyJZ7iLkqtfD yug2bkVx5gK1ePbXROy7ckCZsKz9zXDI1Ra4CkjuCngfyYdFAK uh75MEVTkXX+ECtVzS3/rPfS7Io6fN5mwyuR+P2TJoBMGL+4XlyoT1N+n2XvyboIHFlb9P m83c5YVmk0nufqz7nKbpOoreZIkgrO2SLdc3wyEjgKyLFiGcHr CBNQhDnrZaLu/HY+fczXD44v7cw3R61euV6242bih0RXFGlLDi6Hm7/YKIfXsOKJNtaKBhwkxsjWmwGjnnFo+PV73e4vERnd/b0eh2NPq5WtmQ11H04+7O20+702I+v+r1rA3KOfdztbodja77f bvfs+Y55x6mU5xj15REyLs4RtyOCdmCqhy5h4v14RAUy1buNn3 ILo6tiQ/996x6Zftbdo127+TFfM7HxIPjGb3TypUpTVOs66ylMP9lZpOJb Z1g/f7saYMwzO12rJZL5M/78Thb+2Pl5aK/WXZxfNps5toJGvW6zcnn7Tbi4/kMnE0mp80m47yOInRcspl8MZ/bimIxn2fjD91Fb6xImSCNNnwucl0U532SYIX17WYj5x25PEOZ0 qe6GLVq1qPERafDzjhaGdm+uXWEgUvQOMqG0AgCHMKN2FNmH8J GgH5suXEEhaEdH7LFOoanY8N9kiA7siuJTFY7OWnU614IaIciE ZxziEl2PeZcSyD9N3ono52LB8GFuS0vxI2+rn9vt4vHx6wpRga 9fxnr+mifJI0gKPIiPZtM0IxbPD7ay1GacpcY3ydJo15nddwIg nKLQq7vwSzof7Cf16jXIXiwqtGGwRNy2162swjvGyWW8xJrHh0 YLh4fH6ZTryHuxZkuUhGlfZJoxb9cnqdM5b6OUH2za4UsCAsYG mX0ooSXAUe0OA2XDMIQnS205W3guGQxn192u6hJbQTsCBCVAKc dDBmPZkO2IJJMB1blyNY0u62jyGqYBzIlBds69CS5ykQTfPZ8R AwBNur13LJnpdrbcALezitN8OKrg2zgNek80IZbzOezyQTDUUc GjlK/i+Pzdrt8GXLIQ3lNvVous4XIjoE9yzo9CMOLTme72TSCoLx9Vq JM6HRedDrn7fbNcJhNnNw4i3JeokxF/mE93+q4xP5FDwCms4fp9HY0Yl1c+3sqgb0RPYndjkawE9pz0GT zqm8rEgdDPmu1vJBL0oEh41koSJSoovxNjSkyKz9XmSjAteKRL d4RFgk6ZmSAJWoq/hFQrcO/H7QhW4E651bLJQuIHTI5BijfwRXBT5vNg3U3rrWMNgAAC6BJRE FU5rMh36KswV4yCMPtZrOOotNm83hxQiFqBMHBIlCuTLaKQDfR FslsnMVB3tKad1CZcuf7wVRlQ/DuvovjQRjSuW0jCHAaI5D1ssG5Oi8LuSQdcK+LTgdJQSMe7ZAl s11rf0+X8Cix5hUVCXSbapmRLeI9e5p5O7jpxzvUEdXhstvN9j 8Ompg4ZHIMCLNcMJAzjx/yvB+PUXUMwtC29mBmP37KLgrRQUU8qEw25nYWhhdnjlKLcp6hT Gy/Z4d5jlQmb5oyvpBArVqkH/Ycen9HFsn2mViccCPbZ3pWyOXpQE1leeAeDr16cHgJKpjb2CyZ AZHbJaLVtKTMH6lMsub9y3hDO7kKsVou7Szt9GnY6ZjwMbx0Px 7n9sYIJgAXHUUvzcYKRkXEP+sk/sj+3GI+xzDYQTErUSakmG0dXna7N8NhNs7okh4TMXFAmc5arat e76rXY5/AmyH9LGXC77NW69d6vU8SWPOQv4v0Ay2gs1YLL9jO27YR4OcCu zj+tV5bF7cvCNlCY52XMtmkKGl5oV2GcayamYKRvVEjCJDgnEK SO4MWpR3PBQNdbjVxUJnsUJ/4N7kZDjkRCX9Ze/LjWc98h2x8ZP/msttFscJVRQKAQRpvp/0QtVGvUx2dc2etFoKdTSaNIKAwoMV2TNzsjIxBGOaWSpJVJvtl 8WmzybghrXDIi/NFpyP7xJE840tbzrGxJzxLmdK/W/q22i3Sj9R80MpoIBfaCOCzAHsaa9sXhGzhrA3uYd/R+8C2qKX2Z6750yQFzlzwTsv93vBmOMwtLXhYCCGnV2TL/EFlQjhyB/wvw7GWq17vrNWyE51tzkf+ZJvpyPES9GyYh0sEILeFZD9EXUdR o15HW7kRBBy1cs6hULMBfWTcMP5qE6FkSZSsMtnEwdQqxK1mBm 6L4iwOUqhM+I7VbrknIKFxAjOKPd/7m6bpPkkwccDKgA2BgdtVf1bL5WwyWUeRd45909vNBt8oeN8WP DdkD5jg+JdPxPOze7IJxYctOhnDpHYrik82BO8WRc+e/v060GuUeUGkaYoheq8UeJlqF8fZ8nUwWHsysl/Rh4O5tgFbdTjnUHXkVkf4IOnIuCEm9o64V1Gh2yeJV768xMEkk cV87sWtJM6iBK3oehhOw/vsiLwx6DJqkEkIUTWkTIdB3yJrf/vqnDabBz8fEUKIj0fKJIQQolpImYQQQlQLKZMQQohqIWUSQghR LaRMQgghqoWUSQghRLWQMgkhhKgWUiYhhBDVQsokhBCiWkiZhB BCVAspkxBCiGohZRJCCFEtpExCCCGqhZRJCCFEtZAyCSGEqBZS JiGEENVCyiSEEKJaSJmEEEJUi3xluh+Pr3o9bdq0adOm7T22XR w/W5kuu93ayYk2bdq0adP2Htt2s3m2MgkhhBCfhZRJCCFEtZAyCS GEqBZSJiGEENVCyiSEEKJaSJmEEEJUCymTEEKIaiFlEkIIUS2k TEIIIaqFlEkIIUS1kDIJIYSoFlImIYQQ1eKAMu2T5KrXux+Pue ey293F8TqKBmH4HhFaRxFut0+S637/qtfjnmNwznEJW0T1PSLpkRvD+/F4HUVHhrCL432SeDu3m41z7rmR2cXxVa/3ggvfitVyyTeIh0KUXhbayxLhre4uhPgUDijTIAxPm82LTgd/d3FcOznZJ8n9eHzZ7b5HhPZJAjm5GQ4HYYj65XiBmU0mjFj5Wr ZvyP14fDMcejufVaWeNpuejCGpX1ApL+bzRr3+3KveEErCZbc7 m0zSv1/Ks3hxIti728aKEOJLUKZM282mUa+vlsvayQn2rJbL02YzNcUeO Od+3N3B6wb0YDaZzCYTdHoWj484bRfHt6PRVa/3MJ1izz5JsOd2NEIFdDMcbjeb+/G4EQRnrdY6im6Gw9Vyifh4Aa6jCDfF5bPJ5KzVOmu1ZpPJarmE WjBu1/0+asztZnMzHC7mc3vf2WSCoLIKgZvejkbp3z0S3uK83b4ZDu3j 8zTn3OLxEXdn/YhbY49z7qrXq52cXHQ6PGG1XF50OrWTE4TPB2e62ZR/mE5t+DfDId7OVa+3mM9xGp8OIezieBCGSD2mAN/OOorY3bRRtfflCTfDIXtIeGQcGoRhIwguOp3tZjMIw5vhEIHjV TJkm+AME5dvNxskgtfjuex2kSCMVfYV27vfj8de/mEyZjOkEKIKlCnTabM5m0ycc/SlcT8ew4hXOzmxNfhsMjltNrebDbQB156329vNZh1FtZOTXRyj/btaLrebzXm7vVounXONIFjM59gDqcPJuGodRbj7Ooogk+soWkd Ro17fxTH3bDcbxHAXx4jzPknQ5XLOnbVaULub4RCdv9lkwpjgx 2I+Z/wbQWAToVGvzyaT7WZz2myulsvVcskeCW6BOKMmhaCmpuNy2e3y 7kiZQRgiZXAv59xiPkf82TnYJwkuRFKgfYA4UGyADR81+Hm7jR 4YHhPPizviRtkUWMzn+yThu4B3LgSO5+JrJYjwPklqJyfoD90M hzfDIfZ4D8XMwHDux2PsQbsH3WI2gNDHwkv0TLKI8P14jHgifz aCAIkwCEO8Ynt3m0nwgEjGXRzbhKVkCiE+nUJlQr35a73+vd2i FkvT9LLbRZH2bCyr5bIRBD/u7tiGtY6hUIMMwvCs1XqYTtHGH4ShNfKgbkL1kT5111Jjz7G9N I7KbDebh+n0x90d9Az3RRzO2+3FfA7JwVUMHLU5diKeEELG33L ebl/1ej9XKzyvNWPiFogqUwP1LEQLd/xxd/cwnd6ORrWTk//rP/6DMXTOoepczOdZYxfEGz84iDUIQ3sm6lbcGqGlptHA53XO/VqvH6bT634fqYpODCMMGePAIZQMKW8jb0fCED08JlQEJ7BXvVo uz9ttvFlmBh5lIiCodRQt5nOcn5oeudc1T9PUvlAczX3F3t2p9 Db/QMaQIc9arXcaNxVCvIB8ZUIL2vofROWIKob1i2UXx/fjMXsYbP+maYruCKoGWPlgbcutd1DzUrRsXeaNG5232wiBnQN0 L3AU588mE9ZH6yhCUGhEp0/Vlhd/r1PinENU0Rmyoxe4hdUVNvzRBURXko+cTRkwCMPsBAoqgX1w9i y95LJvgRdCYPAqkfLoguCNQPbYxbHvAvFBT8JG3rZFLrtdJNc6 ii46HaYzlft+PMZDQfVxlRVs+6S0+HEPXlD2paNnht+4u1Vr9m jt3bGHrSv7CDZDHj9dRQjx3uQrEyY+2L8wqqBCoU0PoF5DtYUR F0gFByoQ1CAMvaGa+/H4ut9Pn+pTVE+oH/mD90IHJX0ylP0/v3/zFqybqGes+xbzOcw7zjlUoFAU1N1sWaPVn/5d8eEE3JRXXXa7qMJuhkPcAn1BDClddDq4nF0x2OtwPrubjDZO hk3Jpr+tuyH23Gl7dQwfRkvoPV8cBIYWPJ6Tmi4L1RrGQFrhVs ul7ZAhHBtD2C3vx2M80WmziTNtdweX2J4xlBVyyGEqjlxCSxCB fZLgeb3pD1lNhYXQJkLu3dn1hHo559ggYIbk6xZCfC45ysRhG+ 7hsATr8Ww9ha4VrECoc8/bbe5Jn8ZOaicnrIj3SYJzuIdT1PiD94LRDJUgAmRogzBEKxvNc 2gAogrVxGmohmgnTM2cOi/+fC4MXNnLceZps4mREkQVvQeMNsGqxiqVIVO8s3sgcva++yRp1 OuIp33wbLsez85OrZ0liPP3SYJHQBezdnLyH//jf9gRHQg/rFuNeh2RgU5no+plCfbq2N9idwfhYDIFe4TMV5AfhIxAsAcRgF ZhgMrOM/RaFTzNe8W5d7fJWJL9ZNMTogq8y5e2uXXov4MdMvkSoOcB7bHD NkII8Sm8vTLZhu0/CCabfTlhxkDaVa/HQTghhPgstDrRG8PvTL8cmBv52bEQQggpkxBCiIohZRJCCFEtp ExCCCGqhZRJCCFEtZAyCSGEqBZSJiGEENVCyiSEEKJa/H9e/Gq0VkcvUQAAAABJRU5ErkJggg==[/IMG] |
Drives: 2014 BRZ MT (Sold); 2006 V70R
By high level, I was referring to speaker level... you said you were using the wiring from the factory amp? AFAIK, the factory amp does not have RCAs. I'm also not sure about the signal coming form the HU to factory amp. It sounds likely that you're using speaker level input into your equipment, causing it to trip. I'm no expert on the BRZ/FRZ audio system though, but I thought the lines coming out of the HU were all speaker level outputs?
Are you using an line converter? or did you merely splice in a RCA cable into stock wiring? |
Drives: 2013 Subaru BRZ Limited in WRB
There is NO low level output from the factory head unit in a BRZ.
That amp is taking a high level, amplified, signal from the head unit. You will need to do the same with a LOC before feeding your xover.
| The Following User Says Thank You to rmjjensen For This Useful Post: | B-R-Z (06-05-2014) |
That's what I thought...
Just place a LC2i between your factory wiring and your xover and you should be golden. |
I love peanut butter
Drives: 2013 SWP BRZ Limited
Thanks. I assumed a manufacturer would use low level inputs.
I have a MTX re-q laying around that i will use between high output and xover. My original plan was convenient to get only highs out of my door speakers while utilizing the factory amp but this is no longer possible since the signal and amp take high level. I have a small ppi amp 50x2 i believe that i will use for door speakers...or just not use the door speakers at all, I feel like their primary purpose is to work as subwoofers anyway. I need to rewire my install now. Last edited by B-R-Z; 06-05-2014 at 09:06 AM. |
| [For Sale] Factory GTS Navi Head Unit | FactOrFiction | Australia Classifieds | 1 | 07-08-2014 08:58 AM |
| Sub install with 2014 factory head unit | vinceqt | Electronics | Audio | NAV | Infotainment | 23 | 05-21-2014 03:54 PM |
| Will the factory head unit fit other cars? | Anthony | Electronics | Audio | NAV | Infotainment | 21 | 03-10-2014 08:10 AM |
| [For Sale] Factory GTS Navi Head Unit | DanVIIIVI | Australia Classifieds | 6 | 04-20-2013 05:32 AM |
| Factory head unit wiring help please. | jabbajaw99 | Electronics | Audio | NAV | Infotainment | 2 | 03-24-2013 06:09 PM |
