Drives: has four wheels
Can these wheels fit
I'm thinking about buying a set of work xt7 18x8.5 32 offset or 25 offset
Drives: 2018 Golf R
From what Ive seen a +25 is definitely a no go, unless you want a lot of poke.
The +32 is pushing it. IIRC RavSpec said a 17x8 +35 has mild poke in the front. What you want pokes 9.35mm further out.
Parting out HERE
Drives: Rx7
Yeah 18x8.5 +32 poke for sure.
Drives: 86 GTS (PW) Manual
sorry to hijack but how much poke FRONT and/or REAR would there be with 17x9 +35 on 225/45 tyres?
much appreciated! |
Klaatu barada nikto
Drives: Raven FR-S MT
Easiest calculator I've found it here...
http://www.rimsntires.com/specs.jsp Plug in the stock size on the left, 215/45 on 17x7 +48 offset. Then put in what ever size you are considering. It will do all the calculating for you. I'm doing 225/40 on 18x8 +42 for example
I vow to do no harm. 2013 Raven FR-S Manual "Lenore" 1985 Silver RX-7 GSL-SE (Gone and missed) |
Drives: 91 Turbo Mr2
Here is one that I have used before. Like above, you just fill in info and press calculate. Oh yeah remember to select all boxes after you fill in the specified fields. Gives you before and after pics.
http://mr2.gordaen.com/wt_calc.php |
Drives: '13 Subaru BRZ (white)
will mine fit?
I was thinking about getting four OZ ultraleggera's which are 17X8 48mm offset and I'm pretty sure there's no problem with that. My question is about what size tires to get. I've read that 235 is too much for the front, so can I just get 215's on the front and 235's in the back with the same wheel on each though? TireRack is recommending me to get 235's for those wheel so my question is basically if you can run different size tires on the same size wheel and if it will have an effect on handling.
Sorry never had the money to upgrade my wheels before so I feel somewhat clueless... |
Drives: Firestorm FR-S
I think with that offset 235s should work just fine.
#10 |
Drives: Rx7
| Which 18" wheels will weigh the same or less than the stock wheels? | mickey177 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 32 | 05-16-2013 04:07 PM |
| TRD wheels? | Exhaust | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 11 | 05-15-2012 05:59 PM |
| O.Z. Wheels | Zaku | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 25 | 02-28-2012 04:21 AM |
| has anyone else seen this wheels | supramaster12 | Scion FR-S / Toyota 86 GT86 General Forum | 11 | 02-09-2012 09:40 PM |
| OEM wheels I haven't seen elsewhere | bambbrose | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 13 | 12-14-2011 07:08 PM |
