Drives: 2013 Subaru BRZ
Reverse Lockout Collar Roll Pin - Dimensions?
While installing a Perrin reverse lockout collar, I managed to mangle the stock roll pin to the point where it only worked when it was about halfway in.
I managed to find a temporary replacement at a auto parts store, but it's a little smaller in diameter than factory--the pin stays in place, but it's relatively easy to push out with a 3/32" punch. A 3/32" roll pin looks substantially larger than factory, but the other sizes I tried seemed too small. One might think the size is metric, but it looks to be exactly 1" in length. In any case... for those who can't replace the roll pin with something that's threaded, any ideas as to the size of this piece? I've found a few sets online, but they seem to start around $40, when I just need one pin. |
Drives: 14 FRS Whiteout
don't know where to get them. but a tip for you when you attempt to install the reverse lockout again. put the car in reverse when you install it. the pin stay where it is and doesn't drop down.
| The Following User Says Thank You to nyfries For This Useful Post: | unsurety (06-03-2014) |
Ha, thanks. I actually had it in reverse when putting the new collar on, but I think I messed the original pin up when removing it.
aeiou
Drives: WRB BRZ
Yeah... installing it was an unexpected PITA. I also tried finding the part # in the Toyota catalog but had trouble finding just the pin... it may not be available separately from the lever assembly. Any other dealership parts guys wanna help? heh.
The pin came out easily, but what I had trouble with most was getting the shift boot over the lockout collar! I also gouged my new lockout trying to put the pin back in, but I used a rag and took it slower to guide it in the next go 'round. |
| The Following User Says Thank You to unsurety For This Useful Post: | elbles (06-04-2014) |
Yeah, I have the JPM Alcantara shift boot, and that was a bitch to get back over the collar too.
I can't say I'm horribly surprised that Subaru or Toyota can't sell just the pin (tried finding it on SubaruOnlineParts.com too, and couldn't), but it is a tad surprising that it doesn't seem to be a standard, easy-to-find size. |
Drives: Toyota 86
I had a look at mine and it looks like the rear pin of a Glock 21 Gen 4 (longer pin for attaching a backstrap) will fit. I'm just not sure if it's long enough
Drives: N/A
Resurrecting this thread, did anyone ever find it? Mine is mangled pretty bad after getting it out and really don’t want to deal with the pain of getting it out again
| FS: Beatrush Reverse Lockout | TONY_BRZ | Interior Parts (Incl. Lighting) | 10 | 05-15-2015 11:04 AM |
| Reverse lockout? | MrMarinakos | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 04-28-2014 08:47 PM |
| Beatrush Reverse Lockout - NEW red | jack43 | Interior Parts (Incl. Lighting) | 6 | 03-22-2014 02:10 AM |
| WTB: OEM reverse lockout lever | geshin | Interior Parts (Incl. Lighting) | 1 | 02-24-2014 08:56 AM |
| Reverse lockout vibration | SubaSteve | Issues | Warranty | Recalls / TSB | 4 | 03-23-2013 01:26 PM |
