Drives: 2016 STi DGM
AVO inserts/bushings
Hello,
Went to the local Drift-Office meet and purchased the AVO trans crossmember insert, and rear diff tramp bushings. Installed them over the weekend These two items, combined with perrin motor mounts, t-support for trans, rear shifter bushing, perrin steering rack lockdowns, added A LOT of NVH. Note: If you have aftermarket t-support (perrin), you need to cut out larger diameter hole on the trans crossmember insert, for the t-support to fit. Install is easy, but if you have a fatter rear sway bar, you will not get to the bolts that hold that diff in place. So, lower the sway bar by unbolting the way bar brackets (holds the sway bar and sway bar bushings) on both ends. Also helps if you have a support on the diff.
-2014 SSM BRZ MT
Is the added NVH worth the benefits?
I want to say that the car has this "solid connected" feel to it...
before adding those 2 products, there was def. NVH, but with those 2 avo parts, it increased it by alot. I now feel like every rpm (dunno if that makes sense).
-2014 SSM BRZ MT
Driveway labs.
Drives: '13 BRZ Limited, 6sp, SWP
This is good to know since I am putting in my diff bushings tomorrow. Thanks Sam!
-'13 Subaru BRZ Limited, SWP. (Mods: Driveway Labs full aero, MCA, etc)
-'06 Mitsubishi Eclipse 3.8L, UV blue. (Mods: turbocharged, full suspension, too much to list) -'13 Town and Country Limited (Mods: too many kids) |
| The Following User Says Thank You to Wonderbar For This Useful Post: | ramiram1984 (06-03-2014) |
Just a dude
Drives: Scion FR-S 2013
Take out the Perrin T it will dramatically reduce all NVH. I experimented a ton with such bushings etc, the #1 NVH maker is the Perrin T. Install stock T and you'll be amazed and still have a connected feel.
| FS: BRZ Fender Inserts SWP | Vides990 | Exterior Parts (Aero, Lighting, Etc.) | 12 | 03-22-2014 11:38 AM |
| Swap My FR-S Fender Inserts for Your BRZ Inserts (White, Central Jersey) | Figo | NY / NJ / CT / PA | 1 | 03-06-2014 11:26 AM |
| Koni inserts..... | StormTrooper | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 9 | 02-24-2014 04:45 PM |
| Fender Inserts | mjsivee | Want-To-Buy Requests | 0 | 11-15-2013 12:12 AM |
| Cross member bushings vs. Inserts | wootwoot | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 9 | 11-22-2012 02:40 PM |
