Old 06-02-2014, 06:59 PM   #1
protpibe
protpibe's Avatar
Buddy Club front control arms
Is anyone here running the Buddy Club front control arms? I just ordered the rears and am considering doing the fronts. What benefit would there be?
From the product description, it sounds like they take an OEM control arm and press in their own ball joint and bushings. The ball joint apparently corrects suspension geometry on lowered cars. I'm currently running HKS coils with a 1 3/4" drop.
Anyone?
The Following User Says Thank You to protpibe For This Useful Post:
Strife26 (01-22-2019)
Old 06-17-2014, 06:44 PM   #2
protpibe
protpibe's Avatar
So I ordered the fronts and installed them this morning. The install was pretty easy, but it threw my alignment way out (no surprises there).
Just a heads up to anyone who is thinking of getting these front control arms, I feel like Buddy Club doesn't do that good of a job in letting you know what you're getting. They're pretty much OEM control arms that are powder coated white with Buddy Clubs own bushings and ball joints pressed in. It's still good value for the price that you pay, but don't expect any weight savings.
I'll post impressions when the car is done with it's alignment
edit: I should also mention that the included "instructions" are as JDM as you can get. Also known as completely useless and un-readable. One thing to note is that you can't re-use the factory clip from the OEM ball joint. You'll have to find and use your own cotter pin to lock down the castle nut.
The Following 6 Users Say Thank You to protpibe For This Useful Post:
brianbui23 (01-28-2022), enjoyminutemaid (06-17-2014), evolution_sfv (06-17-2014), RehabJeff86 (11-28-2014), stevo_12v (07-23-2014), Strife26 (01-22-2019)
Old 06-19-2014, 12:41 PM   #3
protpibe
protpibe's Avatar
Here's some pics for anyone that is interested. If you do the install yourself, make sure youre near a shop that does alignments. It's way out
I had the fronts installed and aligned before the rears so I drove it around for a day or two. I'm not sure if it's placebo effect or not but the front end feels a lot more compliant and settled. Grip through highway turnoffs and roundabouts feels like the car isn't trying as hard to maintain traction. I didn't notice any additional NVH from the stiffer bushings. I won't be putting it on the track or autocross for a couple of weeks so those impressions will have to wait
One thing I did notice while installing the rears is how beefy they are compared to stock. The stock rear arms feel very flimsy in comparison. Weight is similar I guess, but even if it added weight, it would be worth if for the additional rigidity imo. If you're installing these at home, I would suggest you try and match the stock arm length with the new ones prior to install. I didn't pay to much attention to that and as a result, my toe was WAY out. The drive to the shop to get it aligned was terrifying haha.
Sent from my HTC One using Tapatalk
The Following 4 Users Say Thank You to protpibe For This Useful Post:
*KID* (06-20-2014), JPxM0Dz (06-19-2014), RehabJeff86 (11-28-2014), Strife26 (01-22-2019)
Old 11-17-2014, 05:20 PM   #4
sanbaifo
Apex Premeditator
Drives: ZC6-C5AE-C7Z51-E36
Thanks for the info. Did you notice how much roll center correction the Buddy Club FLCA's have?
sanbaifo is offline   Reply With Quote
Old 11-18-2014, 03:20 PM   #5
SupraFly85
Looks great. How do you like the rear Lower Control Arms?
I have been shopping around for a pair and have narrowed it down to these, the Cusco, and the Stance (Prob. not Stance as I am strictly auto-x and hpde events but have not heard anything bad about them so still considering). I like the prices of these compared to the others but have not really seen many reviews around of them so Im curious what you think after a track day. They seem solid and I love that they match my Whiteout FRS.
GIS Application Developer / iOS & Android Developer/ Web Developer
2013 Scion FR-S Whiteout 6MT
SupraFly85 is offline   Reply With Quote
Old 11-28-2014, 01:30 PM   #6
protpibe
protpibe's Avatar
Sorry for the late reply, I just saw this now
The rear LCAS are fine. They will allow you to run 0 toe and about -1 to -1.5 without adding toe arms. The build quality is nice, and I like the white finish. There are also two shock mounts to chose from to help your suspension deal with larger than normal drops. Overall I'm satisfied.
I tracked them at Brainerd in Minnesota and also at the smaller 1.5 mile track here around Winnipeg. The larger range in camber/toe adjustment made a noticeable difference.
Old 11-28-2014, 01:34 PM   #7
protpibe
protpibe's Avatar
SupraFly85 (01-17-2015)
WTB: Front lower control arms 2superblus Want-To-Buy Requests 7 02-17-2016 02:15 PM
WTB: Front Lower Control Arms sw20kosh Want-To-Buy Requests 9 08-02-2015 04:24 PM
WTB: oem front control arms BRZTho Want-To-Buy Requests 0 04-21-2014 06:55 PM
Front lower control arms, which set would you want? Jeff@Racer X Fab Suspension | Chassis | Brakes -- Sponsored by 949 Racing 29 12-16-2013 07:05 AM
FRONT lower control arms. J-W Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 10-31-2013 10:24 AM
