Old 06-01-2014, 03:16 PM   #1
Harvey
Drives: Celica 5th Gen, Tiburon 04, GT86
TSC sport mode different injection tables ???
Hi, I've come accross a forum thread where a guy asserts that VSC sport mode (VSC, not AT) changes the ECU program and uses a more agressive injection/advance parameter table... he claims to have worked on this himself (don't know in what context). Others in the same thread confirm this and claim the torque dip is less noticable in VSC sport mode than in normal mode.
Any echo to this around here?
Harvey is offline   Reply With Quote
The Following User Says Thank You to Harvey For This Useful Post:
NWFRS (06-01-2014)
Old 06-01-2014, 03:41 PM   #2
Efferalgan
Drives: 2025 BRZ, ex-2012 GT86
No
Efferalgan is offline   Reply With Quote
The Following 2 Users Say Thank You to Efferalgan For This Useful Post:
FRSBRZGT86FAN (06-03-2014), strat61caster (06-01-2014)
Old 06-01-2014, 05:25 PM   #3
swpbrz
Drives: swp brz limited
If it does its very minute feeling. I sense a change between full tank and empty tank. If vsc does something to speed its negligible compared to how much the tank has in it
swpbrz is offline   Reply With Quote
Old 06-01-2014, 05:36 PM   #4
Jyn
Noob
Jyn's Avatar
Drives: FR-S Mammogram
That guy, like me after BBQ Thursdays, is full of shit.
Jyn is offline   Reply With Quote
The Following 3 Users Say Thank You to Jyn For This Useful Post:
Davey (06-02-2014), FRSBRZGT86FAN (06-03-2014), Pistol (06-02-2014)
Old 06-01-2014, 05:40 PM   #5
Sarlacc
/dev/null
Sarlacc's Avatar
Drives: Uphill
Originally Posted by Harvey View Post
Hi, I've come accross a forum thread where a guy ...
How about a link?
Old 06-01-2014, 06:09 PM   #6
billwot
Drives: '11 Cayman , '14 Camry, '11 Tacoma
billwot is offline   Reply With Quote
Old 06-01-2014, 06:58 PM   #7
diss7
Drives: AE86, 2x GT86, TE27
It probably feels faster, because the aids aren't cutting in as much.
diss7 is offline   Reply With Quote
Old 06-02-2014, 02:04 AM   #8
Harvey
Link: http://gt86france.forumpro.fr/t1619-...ls-changements
This post (14th of the page), sorry in French, but google should transate OK:
Je persiste et signe.. Il y a deux tables de réglages de l'avance (ça c'est sur j'ai participé aux paramétrages), deux tables sur les ouvertures injecteurs et angles de cames (Kevin m'en a parlè). Les deux tables de réglages d'avances sont différentes. Une plus agressive que l'autre. Mais, si ma mémoire est bonne, il n'y a pas grand chose. Sur ma titine, j'ai de meilleurs résultats en mode sport qu'en mode normal. C'est pas moi qui le dis, c'est torque pro.. C'est du au fait que nous avons optimisé les réglages...
Voir Kévin pour de plus amples renseignements...
Sarlacc (06-02-2014)
Old 06-02-2014, 02:24 AM   #9
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Think bout it, when you fully turn off the TC & VSC, does Sports Mode stay on?
Yeah~~~ wouldn't make sense for Toyota/Subaru to make Sports Mode better than normal mode, but when TC & VSC is off, Sports Mode won't turn on.
Old 06-02-2014, 02:25 AM   #10
Tromatic
"I persist and sign .. There are two tables of settings in advance (this is on I participated in settings), two tables on the injectors opening and cam angles (Kevin told me about it). The two tables are different settings advances. A more aggressive than the other. But, if my memory is correct, there is not much. My titin I better results than in normal mode sport mode. This is not me saying torque is pro .. This is due to the fact that we have optimized the settings ..."
Limited understanding here, but I have yet to see anyone in our Software Tuning forums mention anything about differing timings for VSC. Yelling "PPPPPPPOOOOOWOWWWWWWWEERRRRRRRRR" in your Clarkson voice probably gives you more power.
Tromatic is offline   Reply With Quote
Old 06-02-2014, 03:46 AM   #11
Harvey
Thanks for posting the translation, it's pretty understandable... about "torque pro" (wharever that is) he says "it's not me who says it's different, it's torque pro" (I assume he claims that he has some measures with "torque pro" that confirm his sayings).
Anyhow, I also doubt about this, although I've never used VSC Sport Mode or TRC Off myself... I find the back kicks around enough in standard mode!
Old 06-02-2014, 05:25 AM   #12
Sarlacc
/dev/null
Sarlacc's Avatar
Drives: Uphill
@Harvey thanks for the link! Interesting forum you have there :-)
Torque Pro is an Android app which connects to an OBDII Bluetooth dongle.
Very useful for a lot of things, proving unicorns exists is not one of them.
I would doubt a dyno-chart as proof of this claim until there was a second independent dyno chart posted.
Old 06-02-2014, 05:29 AM   #13
Guillaume
Guillaume's Avatar
Drives: Exige S 240
Salut Harvey, j'ai posé la même question par ici: http://www.ft86club.com/forums/showthread.php?t=24911
Still no definite answer, it seems.
Old 06-02-2014, 06:29 AM   #14
Harvey
Hum.... the last post is pretty assertive:
There are different drive by wire throttle maps for normal and sport mode. And yes, the throttle/engine mapping is different between the two from the factory.
Obviously being the last post doesn't mean it's true.
PS: Bonjour Guillaume... Belgique, France ?
Vsc sport mode and trac off RWD-boxer Engine, Exhaust, Transmission 94 02-25-2020 09:23 PM
AT Sport Mode - What does it do exactly? karbon BRZ First-Gen (2012+) — General Topics 49 09-02-2014 02:40 AM
DIY Auto VSC Sport and AT Sport Mode Seattle944t DIY (Do-It-Yourself) Guides 0 09-08-2013 05:02 PM
Cruise control with Sport or VSC Sport mode notout86 Scion FR-S / Toyota 86 GT86 General Forum 12 08-29-2013 06:50 PM
sport mode... pr086 Scion FR-S / Toyota 86 GT86 General Forum 6 06-01-2012 11:50 AM
