Drives: 2010 WRX (sold) 2013 brz
Stock belt ok with 3.125 pulley?
I'm running the factory vortech belt with the 3.125 pulley. I have another belt that was recommended for that pulley size but the shop that installed the pulley and tuned the car did not find it necessary to switch the belt.
Thupercharged
The belt size should be slightly smaller, vortech recommends 060966. Belt size with stock pulley is 060970.
FYI goodyear does have a gatorback belt that is the correct size as well, I have heard good things from people running gatorback belts in a supercharger application (less breakage etc.) For the 3.125" pulley the 4060967 is closest to the spec'd K060966 that I've found
2013 FRS
Vortech V3 11psi Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300 2019 Series.Grey STI - Stage1+ SF |
#3 | |
Thupercharged
It isn't the proper length.... the danger would be the belt failing prematurely or slipping/coming off. Not sure where the stroke on your tensioner is with the stock pulley belt on a 3.125" pulley, but I would just change it so you don't have to worry about the belt failing at an inopportune time
2013 FRS
NASA SpecE30 Racer
I am sure the shop that installed your kit did tons of engineering work to come to the conclusion that the factory belt would work better than the proper provided belt.
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
Drives: 2016 Subaru WRX
I would swap the belt for the correct size. I have had to help another forum member pull the knot it caused out on the side of the road. Not so fun when the engine is hot and you have no tools around.
-2016 Subaru WRX
-2013 Scion FR-S: Wastegated Vortech V3'd, E85 SOLD |
Drives: 2013 FR-S Argento
Sorry to revive this thread- considering a 3.125 pulley on a Vortech V3, running 93 octane. Anything else I need other than a smaller belt? Idler pulley change? Or does it work fine with the stock Vortech idler? Thanks
Sent from my SM-G965U using Tapatalk |
Ok nvm on the above, bought the 3.125 pulley and belt, using the same idler, but another question:
On the V3 unit I currently have, to get to the pulley bolt and swap the pulley I have to pull this grey cap off. Says that I'll void the warranty or whatever, that's fine, but I'm having trouble just prying it off with a screwdriver. Any tricks to getting this thing off, or do I just have to go a bit more caveman on it? Already have mangled this thin metal lip surrounding the plastic cap, and just don't want to do something I'll regret later. Thanks in advance |
| Tags |
| vortech, vortech supercharger |
| Vortech 2.87 pulley belt size? | draggin_az | Forced Induction | 0 | 03-31-2014 08:02 PM |
| Anyone know the belt number for the 3.125 pulley vortech? | cjsporl1996 | Forced Induction | 2 | 03-27-2014 12:21 AM |
| Stock belt pattern? | Sniper2606 | Engine, Exhaust, Transmission | 8 | 03-23-2014 06:34 PM |
| Anyone know what belt size to use for a 3.125 pulley on the Vortech System? | tg_1981 | Forced Induction | 17 | 08-16-2013 09:50 AM |
| accessory belt pensioner pulley | 7thgear | Issues | Warranty | Recalls / TSB | 4 | 09-24-2012 10:19 PM |
