Old 05-28-2014, 07:51 PM   #1
sprintamx
Rear end hop
Anyone experience the rear end skipping sideways over bumps under acceleration, or just a relatively "large" bump and moderate throttle? If so, any solutions other than struts and springs? I'm wondering whether stiffer bushings, mounts, LCAs, etc. will keep the rear planted.
Thanks.
sprintamx is offline   Reply With Quote
Old 05-28-2014, 07:54 PM   #2
ramiram1984
Drives: 2016 STi DGM
the miata was worse...had a 95.
-2014 SSM BRZ MT
ramiram1984 is offline   Reply With Quote
Old 05-28-2014, 08:25 PM   #3
MyEvilMonkeys
Drives: 2013 Scion FRS
The coilovers didn't seem to make that much of a difference. I feel the sub-frame bushings may have helped some. Any mods or completely stock?
FA500 Coils/Swift/Radial Upgd, Cusco R.LCA, SPC R.Toe Arms, TqSol. R.SubFrame Bushings, MTEC Shift Springs, Perrin Shift Bushing/Trans Mount, Greddy SP Exhaust & Intake, RPF1 18x9.5 +38, 255/35-18 SDrives, Raceseng Ashiko Knob/Lockout
MyEvilMonkeys is offline   Reply With Quote
Old 05-28-2014, 08:40 PM   #4
NLSP
NLSP's Avatar
Drives: 2014 Ultramarine FR-S
Subscribed.
I'm hoping Whiteline's rear sub-frame bushing inserts will help alleviate that.
NLSP is offline   Reply With Quote
Old 05-28-2014, 08:43 PM   #5
Nevermore
Wayward Member
Nevermore's Avatar
Drives: Hot Lava 86
A lot of the roads I commute on are in pretty rough shape, and it always seems to be in the turns. I hate that sensation of bouncing along around when I turn, makes the car feel unbalanced. It seems dangerous too. I'd love a solution for it.
Nevermore is offline   Reply With Quote
Old 05-28-2014, 11:25 PM   #6
Turdinator
Señor Member
Turdinator's Avatar
I suspect it is more due to the lack of rear suspension travel that people talk about. If you are willing to experiment you could trim you rear bumpstops down and see if that helps.
1974 TA22 Celica
2013 86 GT
Old 05-28-2014, 11:38 PM   #7
NissanGuy
NissanGuy's Avatar
Drives: Strangely.
I bet it's the ultra soft bushings deflecting violently. When I did the Whiteline subframe inserts it helped a bit.
I believe the rest of the skipping around comes from the differential bushings. I hope to do the whiteline diff insert bushings eventually.
NissanGuy is offline   Reply With Quote
The Following User Says Thank You to NissanGuy For This Useful Post:
gramicci101 (05-28-2014)
Old 05-28-2014, 11:48 PM   #8
gramicci101
Off Topic
The Whiteline diff carrier inserts make a huge difference. You can see how much they deflect in the video on FT-86SF's positive traction kit page. Even though the page is for different bushings. http://ft86speedfactory.com/whitelin...n-kit-287.html
They're an easy install, you just need to make sure the diff is supported when you pull the front two bolts.
The Following 2 Users Say Thank You to gramicci101 For This Useful Post:
Calum (05-31-2014), sprintamx (05-29-2014)
Old 05-29-2014, 12:06 AM   #9
radroach
Drives: car
I feel the car hop around when I go around corners, if my rear tires go over a bump in a corner it will sometimes want to slide out and TC will come on.
Old 05-29-2014, 12:21 AM   #10
NissanGuy
NissanGuy's Avatar
Drives: Strangely.
That video was what sold me the subframe bushing inserts. Subframes should NOT move around! I work on MINIs for a living, and none of the current cars even have subframe bushings. That's why they handle so well. That, and very nice shocks.
I wish I could find a similar video for the diff bushings, I absoluetly hate the jiggling feeling when going over bumps. Is it completely gone with the inserts installed?
Old 05-29-2014, 12:28 AM   #11
gramicci101
Off Topic
Honestly, that video sold me more on the diff carrier inserts than the subframe inserts. I couldn't really see the subframe flexing on its bushings, but the diff carrier was bouncing around like crazy.
The polyurethane itself is very slightly flexible, but not very compressible. There are the two big bushing inserts on the back of the carrier and two smaller sets of collars/inserts for the front of the diff. It's an easy install. Once they're all in, there's a noticeable difference. There's no *thunk* from the rear end when you shift hard and get on the gas. A lot of the slop in the drivetrain has been removed. It's definitely worth the money.
The Following User Says Thank You to gramicci101 For This Useful Post:
Old 05-29-2014, 11:43 AM   #12
sprintamx
I've installed full Ground Contorl Koni coilovers; 375 lb springs front, 350 lbs rear. Rear shocks are at their lowest/softest setting. I experienced rear hop on the stock suspension and tires, which I reduced a bit with moving to Michelin PSS2s (softer tire). I have had the Konis at a stiffer setting in the rear and still experienced the hop.
Old 05-29-2014, 11:49 AM   #13
sprintamx
When I installed the GC Konis I lowered the rear height 1 1/8 inch (sorry, no metric measurements) and the fronts 1 1/4. All the strut assemblies came with GC bump stops that I "believe" have a lower profile (are shorter) than stock. I would say that I maintained "adequate" travel with the setup, but maybe not?
I do plan on calling GC for some guidance, but I think we're starting to develop a little knowledge base that subframe and diff bushings/mounts are an integral part of this movement; which makes sense.
Old 05-29-2014, 11:53 AM   #14
sprintamx
This describes some of the particular effects I feel when the rear is "displaced": slop in the drivetrain. There's only so much I can ask shocks, springs and a sway to do if the diff isn't well isolated and/or the subframe has too much movement.
The Following User Says Thank You to sprintamx For This Useful Post:
gramicci101 (05-29-2014)
USDM - Rear foglight indicator in cluster? Trying to do a quality rear fog light inst nalc Cosmetic Modification (Interior/Exterior/Lighting) 8 12-10-2015 04:48 PM
whiteline adjustible rear end links driver01 Brakes, Suspension, Chassis 12 06-28-2014 09:13 AM
Free-Rear bumper cover (entire rear facia) replaced after slight rear-end collision n7011n Exterior Parts (Aero, Lighting, Etc.) 7 03-26-2014 04:46 AM
SPL Arms - Brand New! - Rear Lower Control Arm + Rear Toe Arm w/ Eccentric Lockout quiet-k Brakes, Suspension, Chassis 8 03-22-2014 10:17 PM
WTB: REAR window top Brake Light (just top half with leds) or full rear deck Kayzer Soze Exterior Parts (Aero, Lighting, Etc.) 1 08-31-2013 02:23 PM
