Old 05-27-2014, 01:06 PM   #1
Gt86_nick
Drives: Scion FRS asphalt
Calling all stance guys!
I tried to avoid stance as long as possible but I've finally given in. I'd really like to get my setup correct the first time. I have a set of bbs rs' on the way and also some bc coilovers. Me knowing little to nothing about stance would like to know what else I would or if coilovers would be enough or if lca's camber bolts and top hats are all a necessity? I'd like to run a little bit of camber in the back nothing insane and maybe a little in the front. Also any recommendations on tire size that'd give me a decent stretch on a 17x8 wheel? Any added information by you guys would also be appreciated. Thanks!
Gt86_nick is offline   Reply With Quote
Old 05-27-2014, 01:41 PM   #2
WhiteFRS69
WhiteFRS69's Avatar
Drives: 2014 Scion FRS
this is a site to use for reference as far as tire stretch goes
http://tyrestretch.com/
The Following User Says Thank You to WhiteFRS69 For This Useful Post:
Gt86_nick (05-27-2014)
Old 05-27-2014, 01:58 PM   #3
xxscaxx
Drives: 2013 SWP BRZ
need more info on wheel specs...but 17x8? those are tiny.. lol unless you have some ridiculous offset on them.
top hats no - coils will have camber plates up front already. LCA's or camber bolts will all depend on how low you go and if you want to increase/decrease camber from that point.
also depending on the offset you probably won't have to stretch the tire...only stretch them if you have to for fitment issues.
xxscaxx is offline   Reply With Quote
The Following User Says Thank You to xxscaxx For This Useful Post:
Old 05-27-2014, 02:05 PM   #4
s2d4
s2d4's Avatar
195 or lower.
The Following User Says Thank You to s2d4 For This Useful Post:
Old 05-27-2014, 02:22 PM   #5
Gt86_nick
They're 17x8 +20
As far as a drop goes. I'm planning on dropping it enough to leave very little wheel gap(2.5-2.75in)
Old 05-27-2014, 02:35 PM   #6
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
17x8 +20 with a 215 width tire will be fine. A little bit of stretch but nothing retarded. Drop the car, roll fenders, and add some LCAs for rear camber adjustment and maybe some small spacers (5-10mm) and you'll be set.
TylerLieberman is offline   Reply With Quote
The Following User Says Thank You to TylerLieberman For This Useful Post:
Old 05-27-2014, 02:47 PM   #7
s2d4
s2d4's Avatar
215mm is about 8.4 inches
Sent from my Galaxy Nexus using Tapatalk
Old 05-27-2014, 02:52 PM   #8
CSG David
CSG David's Avatar
Anything is possible. Ask Kevin Garnett.
[ame="https://www.youtube.com/watch?v=xvRAK1aQce4"]How To Stretch A 155/60/15 On A 15X9 XXR - YouTube[/ame]
The Following 5 Users Say Thank You to CSG David For This Useful Post:
Dr Evil (05-27-2014), drewbot (05-27-2014), fatoni (05-28-2014), Gt86_nick (05-27-2014), Sportsguy83 (05-28-2014)
Old 05-28-2014, 02:07 PM   #9
ML
ML's Avatar
Drives: 13 White MT FR-S
screw that, I have 235s on my 7in rims.
Old 05-28-2014, 03:12 PM   #10
CSG David
CSG David's Avatar
According to the stance community, this is blasphemy...LOOL.
Old 05-28-2014, 05:33 PM   #11
speargunsandracecars
Drives: 2014 BRZ
That video is the most idiotic thing I've seen in a while.
speargunsandracecars is offline   Reply With Quote
Old 05-29-2014, 02:14 AM   #12
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
Who ever drives on that needs to rot in car hell.
Old 06-02-2014, 11:50 PM   #13
jflogerzi
jflogerzi's Avatar
wow is all I can say. I got 225 on a 7.5 inch rim
Stance Coilover AT CLEARANCE PRICING! Also Stance LCA!!! THMotorsports.com Brakes, Suspension, Chassis 201 10-02-2015 06:32 PM
BC Coilover settings you guys guys ride on g0lden Suspension | Chassis | Brakes -- Sponsored by 949 Racing 26 04-06-2014 06:56 PM
