Old 05-27-2014, 01:57 AM   #1
ActionJackson
Drives: Miata
Compression and super chargers
With the high compression and the supercharger... Would lowering the compression do the same as it would with a turbo? More power etc etc....?
I figure maybe you don't have to do to full build if you out a less sporadic supercharger so you don't get the boost spikes you get with a turbo....
Correct me if I'm wrong. I'm a noob...,
I like the Vortex jackson racing one.. Have a Jackson racing supercharger on my little miata... Can't complain...
Thanks,
AJ
ActionJackson is offline   Reply With Quote
Old 05-27-2014, 02:43 AM   #2
sw20kosh
Drives: 2013 Black FR-S
Thanks,
AJ
Lowering the compression will allow you to run more boost on pump gas. This would allow you to run a larger blower that pumps out more boost.
With all the current offerings out there right now I wouldn't ever bother with the hassle of opening up this motor for changing out internals.
If you are ok with 250-275 whp on pump gas buy a centrifugal SC kit and get a good tune for it. If you want more power and can switch to E85/flex fuel go get a flex fuel kit. No need to lower compression.
You have to keep in mind lowering compression means you will be able to run more boost but you will make less power per pound of boost. If you do lower the compression, the net effect theoretically is you can make more power on pump gas but at much higher boost. You will also have to getter higher fuel flow to accommodate that increased boost.
compression+boost? subatoy Forced Induction 74 01-30-2015 04:32 PM
Lower Compression with Headgasket Team STILLEN Engine, Exhaust, Transmission 28 12-15-2013 05:26 PM
Low Compression - 10:1 // 9:1 1086 Engine, Exhaust, Transmission 12 12-13-2013 05:46 PM
FS: Odyssey OMAX Ultimizer Battery Chargers Pekingduck Mechanical Maintenance and Tools 0 09-15-2013 02:25 PM
Compression ratio 12.5:1. Bye-bye Super charger & Turbo build? fred_boosted Engine, Exhaust, Transmission 215 12-12-2011 07:23 PM
