Old 05-21-2014, 07:39 PM   #1
puma
crew chief
puma's Avatar
Drives: Race car FR-S
abs delete
I can't find anything on the forum, can't use 3 letter words, anyone knows if there is a topic somewhere about ABS delete?
Please don't tell me it is not worth it yadada, i just want info on it, mostly about wiring because i think the speedo will stop working and unsure about the rear brake light. I want to know the downside electrically.
thanks
puma is offline   Reply With Quote
Old 05-21-2014, 08:04 PM   #2
wparsons
wparsons's Avatar
If you totally disable it, you'll lose EBFD which will mean you'll probably want to plumb in a traditional proportioning valve (adjustable or not) to keep the front/rear bias how you want it.
You should be able to disable ABS without removing the wheel speed sensors/wiring, which means you should still have a speedo.
flickr
Old 05-21-2014, 08:10 PM   #3
puma
crew chief
puma's Avatar
yeah a proportionning valve will be installed.
Maybe i wasn't clear enough, i want to disable it but mostly, i want to take it all off, including the wiring. i want to take the whole module out. What i fear is that if i want to take the module off and leave the connector unplugged, i won't have any speedo because the speed sensor seems to send their signal to the abs module and from what i understand it sends the info to the ecu by CAN.
Old 05-21-2014, 09:45 PM   #4
diss7
Drives: AE86, 2x GT86, TE27
Just pull the fuse to the abs pump. That will prevent it from ever interferring, but retains speedo function because sensors are still in place.
That's what I've done.
diss7 is offline   Reply With Quote
The Following User Says Thank You to diss7 For This Useful Post:
CSG David (05-21-2014)
Old 05-21-2014, 09:55 PM   #5
puma
crew chief
puma's Avatar
yeah i guess there is no way around it, just wondering how chasebays was able to remove theirs physically.
Old 05-22-2014, 09:41 AM   #6
wparsons
wparsons's Avatar
Have you confirmed they have the stock speedo working off the stock wheel speed sensors?
In all honesty, how badly do you need a speedo in a race car? I never look at the speedo on the track, you need to be able to judge speed looking out the front, not looking down at the speedo.
flickr
Old 05-22-2014, 01:07 PM   #7
puma
crew chief
puma's Avatar
i will be making more test eventually, my concern is does the ecu uses the speed for something?
In fact, i don't need it that much because i will have a AIM dash and it can provide speed based on the gps. But, it does log the 4 sensors which tells you if you have a wheel that locks up and if so, which one. This is more important than speed itself.
Old 05-22-2014, 02:47 PM   #8
wparsons
wparsons's Avatar
If you're removing ABS and TC/VSC, the ECU doesn't use speed for anything at all except calculating which gear you're in, which only gets used on the cluster.
The ECU won't be logging if/when you locked up a wheel, or which one you locked up.
flickr
Old 05-22-2014, 05:37 PM   #9
Shim
Dismember
Shim's Avatar
Drives: FR-S & JSW
@diss7 started a thread about pulling the ABS fuse a few months ago, but it turned nasty instead of helpful. http://www.ft86club.com/forums/showthread.php?t=54687
The fault lies not in our cars, dear Brutus, but in ourselves.
Shim is offline   Reply With Quote
Old 05-22-2014, 07:33 PM   #10
wparsons
wparsons's Avatar
What's your end goal with removing everything ABS related? It sounds like you're doing it "because racecar", and not with a specific goal in mind?
flickr
Old 05-22-2014, 07:46 PM   #11
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
because racecar is the specific goal in mind lol
Old 05-22-2014, 07:59 PM   #12
puma
crew chief
puma's Avatar
yes, we are building a race car, we want to make a new braking system to have an adustable brake proportionning valve and i am trying to save as much weight as i can.
I plugged my AIM in the obd2 today and unplugged the abs and i am losing all 4 speed sensors (which i can log with my AIM, not log with the stock ECU obviously) So i guess i am stuck with using as least the abs electronics to log my speed sensors. (I beleive i had a couple of sensors that stopped working also, can't remember which one though.)
There are 4 screws on the ABS that seem to scream my name to remove the electronic from the mechanical part of the abs but i am afraid to mess something up...
Old 05-23-2014, 04:25 AM   #13
diss7
If you're building a race car, speedo doesnt matter.. ?
The last thing I do at the track is look at what speed I'm doing...
Old 05-23-2014, 07:58 AM   #14
puma
crew chief
puma's Avatar
i know, i don't mind about speed i am afraid the ECU might use the speed for some other correction factor.
Although i do need a speedo because i got to have the 50km/h pit lane speed but i can get that wih my electronic dash.
Please delete diss7 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 12-27-2013 10:16 PM
WTB: Berks dual tip muffler delete and cat delete pipe Black86 Want-To-Buy Requests 0 09-27-2013 09:31 PM
WTB Berk Dual Exit Muffler Delete or Works AB Delete Admired Want-To-Buy Requests 2 09-10-2013 04:20 PM
delete please xjohnx Mid-Atlantic 0 02-06-2013 09:17 PM
