Old 05-20-2014, 11:10 AM   #1
scionfrs2014
Drives: Scion FRS
Question - two white plastic screws under shifter trim ring
Hi, I am curious for a silly question. Under the (manual) shifter trim ring, there are two white plastic screws. Does anyone know what these for? Thanks a lot.
scionfrs2014 is offline   Reply With Quote
Old 05-20-2014, 01:47 PM   #2
FRSupra
FRSupra's Avatar
If you're referring to the silver balloon shaped trim, those are tapping screws underneath, that hold the console assembly in place.
There are two located above the top of the balloon that go in towards the dash at an angle, and two located where the balloon starts to narrow that go directly downward.
Part No: SU003-00064
There are also two more screws located under the cup holder cushion that also secures the console box in place.
I hope this helps.
FRSupra is offline   Reply With Quote
Old 05-20-2014, 02:45 PM   #3
scionfrs2014
Drives: Scion FRS
I believe the Part # is SU003-00896, a white plastic cap.
Old 05-20-2014, 03:13 PM   #4
FRSupra
FRSupra's Avatar
Now that we are talking about a cap, rather than a screw than yes that is the correct part no.
There are two of them like you said, one diagonal from the one shown in the picture.
The part is called a clamp, it looks like it holds the shift level seat (the black tray directly underneath the clamp), to the dust boot plate. There are two vertical pegs that come up off the dust boot plate.
So, the dust boot plate is held in place by screws that go into the body. Coming off that plate are two pegs which those white caps or "clamps" connect to, that hold the shift lever seat in place. (connected to the dust boot plate).
Products for plastic trim subiestyle Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 4 03-15-2014 05:12 PM
Missing plastic screws??? ciotime Cosmetic Modification (Interior/Exterior/Lighting) 9 07-04-2013 02:54 AM
Cleaning the black plastic trim radroach BRZ First-Gen (2012+) — General Topics 14 05-28-2013 10:17 PM
How do you dress the plastic trim (BRZ) radroach Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 10 03-13-2013 11:42 AM
