Northern California NorCal
Old 05-20-2014, 12:18 AM   #1
SLEEPER WRX
Mfg Recall #WQC39
Welp . . .
I know - if I want to play, I have to pay!!!
WQC39 is mandatory proof of correction required from the dealership
I've been able to totally avoid the dealership so far
My car is modified, not as much as some others, but . . .
So, I've got until August to come up with a plan
Anybody have any ideas?
SLEEPER WRX is offline   Reply With Quote
Old 05-20-2014, 12:21 AM   #2
RC51ed
RC51ed's Avatar
Drives: 2013 Scion FRS
What is the mandatory recall?
RC51ed is offline   Reply With Quote
Old 05-20-2014, 12:28 AM   #3
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
http://www.ft86club.com/forums/showthread.php?t=23502
Originally Posted by humfrz
I'm old and lazy
Old 05-20-2014, 12:29 AM   #4
SLEEPER WRX
Must go to dealership
Must have ECU flashed for whatever their reason is
I read it's coolant temp related - Capitol Subaru says it's emissions related
You get a proof of correction certificate that then allows DMV registration to happen
Old 05-20-2014, 01:05 AM   #5
RehabJeff86
RehabJeff86's Avatar
Drives: 2013 WhiteOut FR-S
Is this only for BRZ?? I hvnt heard anythingn like this from Toyota??
2013 Scion FR-S whiteout
2012 Porsche Panamera S carbon grey
2008 Range Rover Sport SS black - sold
2004 BMW M3 alpine wies - sold
RehabJeff86 is offline   Reply With Quote
Old 05-20-2014, 01:09 AM   #6
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Scions is just a TSB, not a recall. Both are simply ecu flashes I believe.
Old 05-20-2014, 01:13 AM   #7
RehabJeff86
I see, wonder its the same that DMV will require a tsb certificate to renew registration?
Old 05-20-2014, 08:03 PM   #8
SLEEPER WRX
So, here's what I get to do;
- reflash ECU back to stock
- take car to dealership and have them do their WQC39 thing
- reflash ECU back to stage 2
I guess not so bad - first world problems
Old 05-20-2014, 10:38 PM   #9
Clipdat
Proud of BOXER
Clipdat's Avatar
You forgot a fourth item: Do not physically let your car out of your sight when you take it in - insist that you get to watch the service from start to finish.
I can only imagine the field day the techs will have with your car when you bring it in. They will probably be fighting and arguing who gets to "road test" it after the ECU update - best to shoot that down before it starts.
I'm old and lazy
Old 05-20-2014, 11:10 PM   #10
finch1750
finch1750's Avatar
No idea. They did mine when I took it to get a tail light replaced so I couldnt tell you if it holds up reg.
Old 05-20-2014, 11:41 PM   #11
HapaHaole
Drives: Grocery cart
That's only if it's an emission failure tsb, and based on what I found out it is, there is a correction notice you should receive from the dealer upon completion.
SOLD: 2014 BRZ Limited WRB 6 Speed.
HapaHaole is offline   Reply With Quote
Old 05-20-2014, 11:43 PM   #12
ZionsWrath
Thanks
ZionsWrath's Avatar
I guess I coincidentally didn't get hassled because I avoid dealership.
But I really needed the GPS fix and tail lights replaced so they updated it when I took it for those things.
If you can't go back to stock fuk it just take the car in. If you have a tune bring your tune device when you pick it up and reflash before you drive off.
Old 05-20-2014, 11:50 PM   #13
HapaHaole
Here is a copy from Subaru,
APPLICABILITY: SUBJECT:
IMPORTANT - All Service Personnel Should Read and Initial in the boxes provided, right.
SERVICE PROGRAM BULLETIN
2011-12MY All Models 2013MY BRZ
Engine Control Module (ECM) Reprogramming
NUMBER: WQC-39 DATE: October 2012
REVISED: 11/30/2012
This Campaign only applies to vehicles with motor vehicle registration in the States of California, Connecticut, Maine, Maryland, Massachusetts, New Jersey, New York, Oregon, Pennsylvania, Rhode Island, Vermont and Washington.
INTRODUCTION
Subaru of America, Inc. has determined that vehicles affected by this Service Program require ECM reprogramming.
A modification to the Engine Control Module software has been developed to correct a deficiency in the OBDII system thermostat monitoring logic. This software change will not adversely affect fuel economy or performance.
AFFECTED VEHICLES
• 2011-2012MYAllModels • 2013MYBRZ
Affected vehicles are identified in the VIN range chart below. NOTE: Not all vehicles in the VIN ranges are affected. Prior to performing repairs, confirm coverage by using the Vehicle Coverage Inquiry function at Subarunet.com.
BRZ VIN Range : D*600007 ~ D*603007
Old 05-20-2014, 11:52 PM   #14
ZionsWrath
Thanks
ZionsWrath's Avatar
That says all 2011 and 2012 subarus and first 3000 vin BRZs?
Damn if thats true lol, what exactly is wrong with the "thermostat monitoring logic"?
TSB / Recall Sigh-on-Rice Issues | Warranty | Recalls / TSB 390 09-11-2023 12:24 PM
Recall # WQC39 - ECM Reprogramming for Coolant Thermostat WRXcellent Issues | Warranty | Recalls / TSB 190 03-10-2013 03:18 PM
Recall I think so!!!! RWD-boxer Issues | Warranty | Recalls / TSB 16 10-07-2012 10:39 AM
FRS recall? totally Issues | Warranty | Recalls / TSB 8 08-30-2012 12:01 AM
Recall! already earthsscum BRZ First-Gen (2012+) — General Topics 1 06-07-2012 07:00 PM
