Old 05-19-2014, 11:03 PM   #1
meow_mix
Good kitty...
meow_mix's Avatar
Drives: Blür
Nur Spec Kit Install Information w/Diagrams
Toyota's Nur Spec kit doesn't come with any instructions, presumably because it is supposed to be installed at the factory... and in another country. So, I took it upon myself to find my own information along with some comments from my body shop...
The closest I could find was exploded diagrams of each part, inserted below:
Front Under Spoiler
Rear Under Spoiler
Side Skirts
Rear Deck Wing/Spoiler
The kit comes with the 2 side skirts, a 3-piece front lip, 3-piece rear lip, and 11 piece or so rear spoiler... and a bag of about 10,000 pieces of hardware. All the hardware bits are individually wrapped and have part numbers on them. The diagrams I found had different part numbers tied to them, but the bag's part numbers listed out to the side. I made a table that compares the two different part numbers which will allow you to match them easily. Below:
Rear Under Spoiler
SU003-03949 --- 76793C --- Bracket, Rear Spoiler No.2 RH
SU003-03950 --- 76794C --- Bracket, Rear Spoiler No.2 LH
SU003-03971 --- 76867 --- Retainer, Rear Spoiler Side RH
SU003-03972 --- 76868 --- Retainer, Rear Spoiler Side LH
SU003-03954 --- 76871B --- Cover, Rear Spoiler
SU003-04055 --- 76879B --- Clip, Rear Spoiler No.2
SU003-02963 --- 76889 --- Clip, Rear Spoiler No.2
SU003-02988 --- 76889D --- Clip, Rear Spoiler No.2
SU003-03955 --- 76897A --- Spoiler, Rear Side RH E8H Galaxy Blue Silica
SU003-03956 --- 76897A --- Spoiler, Rear Side RH 61K Dark Gray Metallic
SU003-03957 --- 76897A --- Spoiler, Rear Side RH H8R Metallic Orange
SU003-03959 --- 76897A --- Spoiler, Rear Side RH C7P Red Lightning
SU003-03960 --- 76897A --- Spoiler, Rear Side RH D6S Sterling Silver
SU003-03961 --- 76897A --- Spoiler, Rear Side RH D4S Crystal Black Silica
SU003-03962 --- 76897A --- Spoiler, Rear Side RH 37J Satin White Pearl
SU003-03963 --- 76898A --- Spoiler, Rear Side LH E8H Galaxy Blue Silica
SU003-03964 --- 76898A --- Spoiler, Rear Side LH 61K Dark Gray Metallic
SU003-03965 --- 76898A --- Spoiler, Rear Side LH H8R Metallic Orange
SU003-03967 --- 76898A --- Spoiler, Rear Side LH C7P Red Lightning
SU003-03968 --- 76898A --- Spoiler, Rear Side LH D6S Sterling Silver
SU003-03969 --- 76898A --- Spoiler, Rear Side LH D4S Crystal Black Silica
SU003-03970 --- 76898A --- Spoiler, Rear Side LH 37J Satin White Pearl
SU003-03952 --- 76973D --- Cover, Rear Under Side RH
SU003-03953 --- 76974D --- Cover, Rear Under Side LH
Rear Deck Spoiler
SU003-01986 --- 76085A --- Cap (For Rear Spoiler)
SU003-03382 --- 76791 --- Bracket, Rear Spoiler No.1 RH
SU003-03383 --- 76792B --- Bracket, Rear Spoiler No.1 LH
SU003-03368 --- 76871 --- Spoiler, Rear
SU003-03384 --- 76893A --- Cover, Rear Spoiler RH E8H Galaxy Blue Silica
SU003-03385 --- 76893A --- Cover, Rear Spoiler RH 61K Dark Gray Metallic
SU003-03386 --- 76893A --- Cover, Rear Spoiler RH H8R Metallic Orange
SU003-03387 --- 76893A --- Cover, Rear Spoiler RH C7P Red Lightning
SU003-03388 --- 76893A --- Cover, Rear Spoiler RH D6S Sterling Silver
SU003-03389 --- 76893A --- Cover, Rear Spoiler RH D4S Crystal Black Silica
SU003-03390 --- 76893A --- Cover, Rear Spoiler RH 37J Satin White Pearl
SU003-03391 --- 76894 --- Cover, Rear Spoiler LH E8H Galaxy Blue Silica
SU003-03392 --- 76895 --- Cover, Rear Spoiler LH 61K Dark Gray Metallic
SU003-03393 --- 76896 --- Cover, Rear Spoiler LH H8R Metallic Orange
SU003-03394 --- 76897 --- Cover, Rear Spoiler LH C7P Red Lightning
SU003-03395 --- 76898 --- Cover, Rear Spoiler LH D6S Sterling Silver
SU003-03396 --- 76899 --- Cover, Rear Spoiler LH D4S Crystal Black Silica
SU003-03397 --- 76900 --- Cover, Rear Spoiler LH 37J Satin White Pearl
Front Under Spoiler
SU003-02984 --- 71196A --- Clip
SU003-04184 --- 76841A --- Cover, Front Spoiler RH E8H Galaxy Blue Silica
SU003-04185 --- 76841A --- Cover, Front Spoiler RH 61K Dark Gray Metallic
SU003-04186 --- 76841A --- Cover, Front Spoiler RH H8R Metallic Orange
SU003-04188 --- 76841A --- Cover, Front Spoiler RH C7P Red Lightning
SU003-04189 --- 76841A --- Cover, Front Spoiler RH D6S Sterling Silver
SU003-04190 --- 76841A --- Cover, Front Spoiler RH D4S Crystal Black Silica
SU003-04191 --- 76841A --- Cover, Front Spoiler RH 37J Satin White Pearl
SU003-04192 --- 76852A --- Cover, Front Spoiler LH E8H Galaxy Blue Silica
SU003-04193 --- 76852A --- Cover, Front Spoiler LH 61K Dark Gray Metallic
SU003-04194 --- 76852A --- Cover, Front Spoiler LH H8R Metallic Orange
SU003-04196 --- 76852A --- Cover, Front Spoiler LH C7P Red Lightning
SU003-04197 --- 76852A --- Cover, Front Spoiler LH D6S Sterling Silver
SU003-04198 --- 76852A --- Cover, Front Spoiler LH D4S Crystal Black Silica
SU003-04199 --- 76852A --- Cover, Front Spoiler LH 37J Satin White Pearl
SU003-04176 --- 76853B --- Cover, Front Spoiler Center E8H Galaxy Blue Silica
SU003-04177 --- 76853B --- Cover, Front Spoiler Center 61K Dark Gray Metallic
SU003-04178 --- 76853B --- Cover, Front Spoiler Center H8R Metallic Orange
SU003-04180 --- 76853B --- Cover, Front Spoiler Center C7P Red Lightning
SU003-04181 --- 76853B --- Cover, Front Spoiler Center D6S Sterling Silver
SU003-04182 --- 76853B --- Cover, Front Spoiler Center D4S Crystal Black Silica
SU003-04183 --- 76853B --- Cover, Front Spoiler Center 37J Satin White Pearl
SU003-04200 --- 76857 --- Retainer, Front Spoiler Side RH
SU003-04201 --- 76858 --- Retainer, Front Spoiler Side LH
SU003-02964 --- 76917D --- Clip
SU003-02989 --- 76917E --- Clip
Side Rocker
SU003-04231 --- 75850A --- Moulding Assy, Body Rocker Panel RH
SU003-04232 --- 75860A --- Moulding Assy, Body Rocker Panel LH
SU003-02964 --- 75867A --- Clip, Rocker Panel Moulding
SU003-02978 --- 75867C --- Clip, Rocker Panel Moulding
SU003-02989 --- 75868B --- Clip, Rocker Panel Moulding No.2
SU003-02990 --- 76923B --- Retainer, Side Mudguard
There is also the part numbers for the larger pieces should anyone need them for anything...
The guy at my body shop (miracle worker) is pretty cynical and says every other body shop sucks ass, lol. So, he thinks other shops will cut corners with certain things like mounting the spoiler properly/straight, drilling the sideskirt holes (he thinks most won't and will just double-sided tape them), and drilling the front/rear bumper holes which are required if you use the supplied brackets. THIS IS ALL POSSIBLE. He did it, I've seen it, it can be done. Just FYI too, every rear bumper (FR-S and BRZ) and FR-S like front bumper comes with circles imprinted on the inside of the bumper which is exactly where the drilling is required to mount the brackets for this kit.
Hope this helps for anyone who is considering this kit, has this kit, or is trying desperately to mount this kit. I'll gladly answer any questions anyone has and can ask my mechanic anything I'm not sure of. Enjoy!
P.S. Pics coming soon I hope...
meow_mix is offline   Reply With Quote
The Following 7 Users Say Thank You to meow_mix For This Useful Post:
Choco (03-31-2015), EndlessAzure (02-16-2022), flippy (05-20-2014), Guillaume (05-20-2014), HATED1 (03-12-2015), Kristian (12-02-2016), OMEN (02-26-2018)
Old 05-20-2014, 05:35 AM   #2
Tuan
Tuan's Avatar
Drives: Whiteout FRS
Send a message via AIM to Tuan
Thanks for this! I've been eyeing the Nurspec Kit for quite a while!
Tuan is offline   Reply With Quote
Old 05-20-2014, 07:56 AM   #3
Mad1723
Mad1723's Avatar
Drives: Asphalt FR-S
Great info! That Nur Spec wing is tempting as all hell. Hopefully, we will get it here eventually Otherwise, price is a bit steep for just the wing
Mad1723 is offline   Reply With Quote
The Following User Says Thank You to Mad1723 For This Useful Post:
Choco (03-31-2015)
Old 03-12-2015, 03:59 PM   #4
hmong337
Emperor JDM
hmong337's Avatar
Drives: '91 MR2 Gen3 3SGTE, '13 FRS
Subbed. Eventually wanna get this kit.
hmong337 is offline   Reply With Quote
Old 10-13-2015, 02:44 PM   #5
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
so the front bumper doesn't use any sort of tape, just drilling?
MS, CSCS, TSAC-F, CPT
Old 10-13-2015, 06:15 PM   #6
GremlinGSP
I've got my nur-spec front sitting in the office. It has tape already pre-applied. Just have to pull the tab to remove the backing.
GremlinGSP is offline   Reply With Quote
The Following User Says Thank You to GremlinGSP For This Useful Post:
weederr33 (10-13-2015)
Old 10-13-2015, 06:39 PM   #7
weederr33
weederr33's Avatar
Nice, thanks for the info. Tape and rivets I assume are all that's needed?
Old 10-14-2015, 04:20 PM   #8
Noz
Drives: Ultramarine Blue FR-S
There's a bigillion parts/bolts/clips that comes with this kit and it can get kinda confusing to install. Especially because they want you to drill into your panels for the sides and rears. I didn't want to drill, so I had my guy add double sided and an extra 75867A bolt on the rear side.
Noz is offline   Reply With Quote
The Following User Says Thank You to Noz For This Useful Post:
weederr33 (10-14-2015)
Old 10-14-2015, 04:40 PM   #9
weederr33
weederr33's Avatar
Did you guys use a particular type of tape? I've seen all sorts of 3M mounting tape, with varying thicknesses, and widths. The kind I have is similar to what comes on the kit (I have the TRD for now... keeping the side skirts but replacing the front), but wasn't sure if there is a difference.
Old 04-23-2018, 02:11 AM   #10
hayase
Drives: 86
Sorry for bumping really old thread but I have question regarding Rear Wing Aeropackage (it's called Nur Spec Wing ?)
I lost some plastic cover but it seems it doesn't have part numbers on it
here's the picture showing the plastic cover missing :
hayase is offline   Reply With Quote
Old 02-16-2022, 05:50 PM   #11
DCdesign2000
DCdesign2000's Avatar
Drives: Civic Hyb, RS6, BRZ SeriesBlue
Any luck?
DCdesign2000 is offline   Reply With Quote
Kenwood DDX630WBT Toyota-spec head unit w/ nav install in US GSX-R35 Electronics | Audio | NAV | Infotainment 17 05-26-2015 04:37 PM
Buddy Club Racing Spec coilovers, anyone install them yet? Mark Slide Squad Suspension | Chassis | Brakes -- Sponsored by 949 Racing 20 06-28-2013 03:17 AM
wiring diagrams? ElectronSpeed Engine, Exhaust, Transmission 4 02-07-2013 10:48 PM
wiring diagrams? xpicer Engine, Exhaust, Transmission 4 08-13-2012 08:16 PM
