Old 05-15-2014, 10:39 PM   #1
TomT2411
TomT2411's Avatar
Drives: Bagged FRS
Borla UEL Header - CEL FIX
I got a question how does this header work and do I lose power with this one?
I just was about to buy the Regular Borla UEL Header, but I just seen the CEL Fix one and right now I don't have money for a tune to get my CEL off. I don't mind if the light is on or is that bad to leave it on? Sorry if this is confusing.
Check out my Instagram!
http://instagram.com/tomturrisi
Bagged FRS
TomT2411 is offline   Reply With Quote
Old 05-15-2014, 10:42 PM   #2
fantah
fantah's Avatar
Drives: 2013 BRZ Premium Black
With CEL on the car will run richer (Waste more gas) Shouldn't affect the power though.
fantah is offline   Reply With Quote
The Following User Says Thank You to fantah For This Useful Post:
TomT2411 (05-24-2014)
Old 05-24-2014, 10:02 PM   #3
TomT2411
TomT2411's Avatar
Drives: Bagged FRS
Anyone else has an opinion on this?
Bagged FRS
Old 05-24-2014, 10:51 PM   #4
Malt
Drives: 2015 WRX
You should run a tune with any catless header. Running one without a tune will certainly cause a CEL, not to mention that the car may actually end up running worse. Personally (disclaimer, I'm biased), I'd avoid the borla and get Vishnu's OFH. The OFH is cheaper when purchased with the OFT (which, fills the need for a tune) and arguably better made. You can get a tune and header from vishnu for $1015 and have most of the potential power available in NA form.
http://www.openflashtablet.com/products/OFH/index.html
I ran a borla UEL on my car for several months and fought exhaust leak issues the whole time. Just put the OFH on my car and the borla is going back for warranty replacement.
As for not having the money for a tune and a header. Just save your money up until you can afford both or just get a tune instead of the header.
Malt is offline   Reply With Quote
FS: Borla UEL header chimmy Engine, Exhaust, Bolt-Ons 13 05-11-2014 06:10 PM
Top Gear Solutions| HKS Header |Borla EL & UEL Headers| Agency Power Header| + MORE! TopGearSolutions Engine, Exhaust, Bolt-Ons 82 04-14-2014 08:16 PM
Is this the Borla UEL or EL header? MountainManFR-S Engine, Exhaust, Transmission 10 01-23-2014 07:23 PM
FS: NEW Borla UEL Header Cjymiller Engine, Exhaust, Bolt-Ons 10 10-13-2013 10:04 AM
FS: Used Borla EL header FT-86 SpeedFactory Engine, Exhaust, Bolt-Ons 3 10-07-2013 02:11 PM
