Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
Drives: 2013 Whiteout FRS
Extreme drop
Fixing to order a set of bc extreme drop coilovers.Plan on maxing them out on drop. What else are you aggressive wheel guys using? Lca or better to go with uca? And what else would u guys recommend? Spring rates?
Drives: none
I'm on stock wheels. LCAs are a most. I need them bad, but I'm waiting til I buy new wheels to get them. I chose 8k spring rates. While I am what some people claim as slammed, but only dropped 2 1/4". I'll raise it up an inch whenever I get wheels. I have pics if you want, just ask
Yes, post pic if u could.
Drives: Argento FRS
It depends on what you want to achieve.
Extreme Drops are great. I'd highly suggest getting them with Swifts, they greatly improve ride quality. Anything around 10k is a pretty good spring rate. In general, all of the coilovers around the $1k price range are pretty much the same. They will all most likely have clunking from the sway bar end links, and dampen pretty much the same. Extreme Drops will go the lowest out of the bunch though. If you want to fit aggressive wheels, I'd suggest UCA's first, if you want to remove camber, LCA's would be a good choice.
ig: @potatoglasses // @toastedbiscuits |
The Following User Says Thank You to moomoopanda For This Useful Post: | TTGT (05-13-2014) |
Scrape Master
Drives: Goal: Oldest FRS State Side
I would suggest PBM LCA, they have massive camber adjust ability and at a great price. The shop that did my alignment was surprised how much camber I can get out of them.
Drives: none
I looked at them, they're the same price as SPC. But their site says out of stock. Where did you get them?
Scrape Master
only place is their site, SPC maxes out a -2 camber while PBM LCA can go far more, so far im at -3.
The Following User Says Thank You to WolfsFang For This Useful Post: | dbrandt01 (05-08-2014) |
Best price Bc extreme drop coilovers? | TTGT | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 2 | 05-01-2014 11:42 AM |
bc coilovers extreme drop | mrharry | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 7 | 03-17-2014 06:00 PM |
Bc extreme drop kit | Cu0ngsayz | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 10 | 02-03-2014 10:06 PM |
BC Racing Extreme Drop Coilovers | 636 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 60 | 10-16-2013 11:42 AM |
WTB: BC Br Extreme drop | WolfsFang | NY / NJ / CT / PA | 4 | 06-29-2013 04:19 PM |
