Old 05-03-2014, 01:54 AM   #1
cooldandani
Drives:
Springs
Hey guys quick question I'm going to go look at some used springs 1000 miles on them , whqt should I look for on the used springs???
Sent from my SAMSUNG-SM-T217A using Tapatalk
cooldandani is offline   Reply With Quote
Old 05-03-2014, 02:07 AM   #2
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
Nothing. Buy coilovers. You're going to blow your struts faster than you should.
Someone here just blew a strut while still under the 36mo/36k miles.
N1rve
The Following User Says Thank You to N1rve For This Useful Post:
Jyn (05-03-2014)
Old 05-03-2014, 02:10 AM   #3
fatoni
I don't have the answer but you probably shouldn't listen to that guy. Springs have a much deserved place in the aftermarket and just like coilovers, there are well executed and poorly executed examples
The Following User Says Thank You to fatoni For This Useful Post:
aristo (05-03-2014)
Old 05-03-2014, 02:12 AM   #4
jebuwh
Village Idiot
jebuwh's Avatar
Drives: '13 FR-S Ultramarine Manual
I'm really considering a swift spring/bilstein strut combo. For what I do I don't think I need more than that
jebuwh is offline   Reply With Quote
Old 05-03-2014, 02:17 AM   #5
husker741
He wasn't asking whether or not he should get springs or coilovers. Coilovers are not for everyone, and some springs perform better than some coilovers, especially if you are keeping the stock wheels and tires.
Also, link to the blown strut?
husker741 is offline   Reply With Quote
The Following User Says Thank You to husker741 For This Useful Post:
aristo (05-03-2014)
Old 05-03-2014, 02:30 AM   #6
jebuwh
Village Idiot
jebuwh's Avatar
As far as what to look for, paint quality, if they are beat to hell or not, ask lots of questions. You should be fine.
Old 05-03-2014, 02:36 AM   #7
N1rve
N1rve's Avatar
I don't think springs out perform coilovers in any instance.
http://www.ft86club.com/forums/showthread.php?t=27997
Anyone else blow them right after installation?
http://www.ft86club.com/forums/showthread.php?p=1658405
Hello, yes I am. I have the eibach pro kit installed. I've had it installed for well over 3 months and never had an issue.
N1rve
Old 05-03-2014, 06:07 AM   #8
krulux
Drives: 2013 Scion FRS
Depends on the springs. The springs the drops too far can cause premature wear. Not all springs are created equal. Not all coilovers are created equal.
For around $200 I picked up a set of the eibach pro kits. They offer about an inch drop and were designed to use the stock assembly. They are near perfect in my mind for the price.
Coilovers offer a slimmer profile than stock so you can usually run a wider more aggressive tire. Most coilovers also offer adjustibility and provide a better ride if the drop is significant as compared to stock.
To say that springs are a waste of money is inaccurate. Like most mods, it depends on the results you're looking for.
krulux is offline   Reply With Quote
Old 05-03-2014, 06:27 AM   #9
N1rve
N1rve's Avatar
They aren't a waste of money, they're a poor investment. Once those struts blow, you'll be paying money again for either new struts or coilovers. I would skip the springs and go straight to the coilovers to not pay twice.
Of course... Feel free to invest in whatever you like.
And yes, one of those threads I posted had a strut failure with eibach springs. So be wary yourself.
N1rve
Old 05-03-2014, 07:28 AM   #10
J_kennington
Drives: 2013 asphalt scion FRS
We've had someone blow a stock motor, should no one buy this car?
I'm sorry, but your reasoning is invalid.
OP about the only thing you can "test" would simply be, do they look good? Is all the paint scraped/rubbed off?
I personally am planning on eibach pros.
2013 raven frs(dd/grocery getter)
1990 mitsu eclipse gsx(street/strip car)
1995 gmc 1500 4x4(off road toy)
2005 Yamaha yz250f
J_kennington is offline   Reply With Quote
Old 05-03-2014, 07:28 AM   #11
jdubious
Drives: 13 Scion FR-S
Those threads cite improper installation as the cause of strut failure.
Sadly, the likelihood of improper installation on the coilovers is much higher than the springs. Its nearly impossible for the avg dude to get them dialed in right.
Sounds like someone has been off drinking the Kool aid.
jdubious is offline   Reply With Quote
Old 05-03-2014, 09:50 AM   #12
tennisfreak
Drives: 2018 BMW M240i
If your worried about a blown strut buy TRD, have Toyota install them.
Strut blows, your covered. The TRD springs are designed for the stock strut and have been discovered to be rebranded Eibach.
Old 05-03-2014, 10:36 AM   #13
fatoni
with this reasoning, nobody should be buying anything south of jrz or penske triples. $200 springs are a much better investment than coilovers costing 8 times more money. also, in the second thread you provided there is a person who blew the strut on stock springs even sooner. if that post is evidence of anything, its that you should upgrade shocks stat to preserve your shocks. i dont believe that at all but it goes to show that anecdotal evidence doesnt indicate let alone prove anything
Old 05-03-2014, 12:54 PM   #14
N1rve
N1rve's Avatar
No, the car is engineered to have this motor fitted to the chassis. The car is not engineered to be fitted with aftermarket springs. This causes extra wear and tear on the strut/shocks which will lead to premature failure.
As I said again... feel free to invest in whatever you want.
Link?
The OP must consider that a faulty install could also result in a blown strut/shock which means spending more money.
Koni yellow shocks are about 650 dollars for the entire set, add in 200 dollars for the springs = 850 dollars.
You can buy megan ez racing coilovers for 680 dollars on ft86speedfactory. Tien are only 830. You're saving 170 dollars or 20 dollars.
That 170 dollars is a significant amount of money for another mod.
Eibach Springs are 260 new.
N1rve
Swift Sport springs/or any springs.. regrets ? rikdrt1 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 04-21-2014 09:10 PM
All the different springs... Skurj Suspension | Chassis | Brakes -- Sponsored by 949 Racing 35 03-29-2013 06:49 AM
OEM BRZ springs? jm1681 Brakes, Suspension, Chassis 1 11-03-2012 08:14 AM
HELP:Q about springs Obja Suspension | Chassis | Brakes -- Sponsored by 949 Racing 18 10-08-2012 02:12 PM
STi Springs illmatic Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 08-14-2012 01:19 PM
