Team Legacy
Drives: LS swapped FRS, 5 speed
Looking for help with vac lines on turbo
Hey everybody, I've spent the winter preparing my car for racing this season. I've got everything setup except my vac lines.
I am being told about 5 different things from 5 different people so I am completely confused. If anybody could help me sort this out that would be awesome. Il start by listing my build, it's a fa20club turbo kit, I am using a garrett gt3071r, also using a turbosmart 50mm blow off valve and a turbosmart race port external wastegate. I am also running AEM water/meth which runs off of a boost pressure source. I also have tapped a vaccume box into my brake booster line so I can source multiple things to it and keep it clean. From what I've been reading this is how I am supposed to be setting up my vac lines, but I have been told too many different things now and I don't know what to believe. What I've read: Blow off valve - total of 2 ports, both top. Block 1 of those 2 ports and insert nipple in the other. Run a vac line from that nipple to 1 of the ports on my vaccume box. External wastegate - total of 4 ports, 2 top and 2 bottom. Block 1 top and 1 bottom, insert 1 nipple into top and 1 nipple into bottom. Leave top nipple vent to atmosphere, run vac line from bottom nipple to vaccume box. Insert manual boost controller in the center of this line. (Biggest confusion of them all, I was under the impression that I MUST drill and tap my compressor housing on turbo, insert barb fitting and run the vac line to that instead of the vaccume box but everyone's telling me something different). AEM water/meth boost source - (another bunch of confusion) Run the vac line from the AEM water/meth controller to the vaccume box. If anybody has input on all of this that would be extremely helpful. I want to make sure I ask questions and do everything properly as this is my first turbo build on an n/a car. Thanks very much.
Team Legacy @timeattackrob @team_legacycc |
#2 | |
I Love custom Turbo kits
Drives: Limited BRZ
BOV correct, cap 1 port, insert nipple into other one and rout to vacuum block. External WG everything seems correct, and while you can run the vacuum source to the block, I recommend drilling the turbo. It's better the fastest/closest source of vacuum then having to run a line all the way back there.
#3 | |
NASA SpecE30 Racer
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
#4 | |
Team Legacy
#5 | |
Team Legacy
Thanks a lot for the input as well! I appreciate it greatly!
NASA SpecE30 Racer
The AEM kit boost source is probably the least important and it will be fine coming from the vacuum manifold.
- King Tut
Team Legacy
Perfect that about solves everything then!
Thanks again guys!
Drives: '13 Turbo BRZ (AT) & '13 FRS
Have you contacted your tuner yet? They may prefer a different boost control strategy, or location of the boost source.
-Ty |
Team Legacy
Hey, yes I ran the manual boost controller by my tuner and he seemed perfectly okay with it. Eventually il be going to electronic, just need it going for the first couple races this season. Thanks!
#10 |
Drives: 2013 Black FR-S
| FS: OEM AC Condenser and lines | MicheleAbbate | Engine, Exhaust, Bolt-Ons | 7 | 09-26-2014 02:16 PM |
| Brake lines | rev3la7ion | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 6 | 04-14-2014 10:24 AM |
| Help: Routing Oil Lines | sw20kosh | Forced Induction | 5 | 04-09-2014 11:25 PM |
| Turbo coolant lines GTX2867. Can I use the throttle body coolant lines? | mike the snake | Forced Induction | 8 | 04-01-2014 05:56 PM |
| Lovely Lines | ImAwesome | BRZ Photos, Videos, Wallpapers, Gallery Forum | 12 | 09-21-2013 12:39 PM |
