Old 04-25-2014, 07:41 PM   #1
912matthews
912matthews's Avatar
Drives: 2013 Scion FR-S 10 Series A/T
Header Knock
He guys, currently running Motive Overpipe, HKS Front Pipe, and HKS Catted EL Headers..also on a Stage 2 Tune..after my header install I've had a knocking sound coming from the engine area..between 2-3K RPM but passed 3K it's not as noticeable unless I lay on the throttle. It's not a exhaust leak, I've had it checked for that, Any suggestions? It's really annoying and sad
-Wes Matthews
SouthEast86
Savannah86
912matthews is offline   Reply With Quote
Old 04-25-2014, 07:43 PM   #2
AdrianG
Generally Well Liked
Drives: '08 STi Hatch, '11 Outback 3.6R
Maybe your front pipe against the frame?
If the clearance is tight some different motor mounts might help reduce movement.
- AdrianG
AdrianG is offline   Reply With Quote
Old 04-26-2014, 02:29 AM   #3
lbroskee
lbroskee's Avatar
Drives: 2023 WRB BRZ (MT)
check ur overripe hitting the sway bar. i know mine did so i took it off, dented it, and problem solved
lbroskee is offline   Reply With Quote
Old 04-26-2014, 02:19 PM   #4
EZWood
BAMF
EZWood's Avatar
Header to belly pan. Check your clearance or look for rub spots
Does this sound like 'tip-in knock'? 1Cor10:23 Engine, Exhaust, Transmission 48 04-02-2016 01:06 AM
Knock Correction vs Knock Correction Learn values? swift996 Software Tuning 19 11-03-2015 10:09 PM
FR-S Rod knock pozer Issues | Warranty | Recalls / TSB 95 11-03-2015 09:39 AM
tip in knock with turbo jamesm Software Tuning 75 03-12-2014 12:29 AM
Would you rather buy knock off parts for your car? EJ20 Engine, Exhaust, Transmission 63 11-02-2011 06:17 PM
