Old 04-25-2014, 09:56 AM   #1
TStafford
TStafford's Avatar
Drives: 2015 FR-S Ultramarine Metallic
New Owner performance upgrades
Can we start a sticky for new owner performance upgrades that would cover these details.
General cost
Difficulty installing
Benefit vs. risk
Some of the upgrades I am considering:
Crank Pulley
Air Box or better air flow - na
Catback Exhaust
Bigger Wheels / Tires
Bigger Sway bars
Springs / Coilovers
Struct Brace
Crossmember-Mount Insert Bushings
TStafford is offline   Reply With Quote
Old 04-25-2014, 10:07 AM   #2
Freetime
Freetime's Avatar
Drives: Raven Manual FRS
you want a single sticky thread to encompass the amount of information in 90% of the threads on the forum? We have whole sections dedicated to parts of what you want to know. Literally thousands of threads. Start reading.
Freetime is offline   Reply With Quote
The Following 3 Users Say Thank You to Freetime For This Useful Post:
JohnJuan (04-25-2014), MokSpeed (04-25-2014), travelmonkey (04-25-2014)
Old 04-25-2014, 10:47 AM   #3
Adam Anthony
Drives: 2013 Scion FR-S Base Firestorm
I think that's his point. Why scroll through thousands of threads if one post could have the majority of the information new owners are seeking? More efficient I would imagine than trying to locate the information in literally "thousands of threads" don't ya think?
Adam Anthony is offline   Reply With Quote
Old 04-25-2014, 10:56 AM   #4
JohnJuan
JohnJuan's Avatar
Drives: 2013 FR-S, Hot Lava; 2012 Z1000 CBO
General cost
Benefit vs. risk
Crank Pulley
$100-200. Easy-moderate, but pay attention to the DIY guides. If you don't do it right, it can leak oil, and mess up the pulley's drive system. Benefit: engine revs slightly more quickly.
High-flow filter. Approx. $40-60, 10-20 min. Easy. No risk.
Catback Exhaust
$500 for cheap. Probably $800+ for " good" Most are $900-1200. Sounds nice. Minimal power gain No risk.
$800+ Difficulty varies. Grippier, no risks come to mind. Could get stolen, I guess?
Bigger Sway bars
$200 for 1 to $800 for 2. Mild difficulty. Reduces body roll. Might make the wheel that didn't hit a bump feel the bump if the bar is too stiff.
Springs / Coilovers
$800-3000+. Moderate difficulty. Cheap coils or spring/bad adjustment can mess up the ride quality.
Struct Brace
$100-500. Easy. Stiffens the chassis. Slight risk of shearing off the mounting studs. Don't use anti-seize on the threads, and you should be fine.
$50-ish. Moderate Difficulty. DIY GUIDE Makes the tail end more predictable. Low risk unless you botch the install.
That should cover it? Most of the links are stickies in the tech subforums.
Obligatory: The search function is your friend.
JohnJuan is offline   Reply With Quote
The Following 5 Users Say Thank You to JohnJuan For This Useful Post:
Ammunition (04-27-2014), humfrz (04-25-2014), jeepmor (04-27-2014), LXXXV1 (04-25-2014), Wolfking (04-26-2014)
Old 04-25-2014, 11:02 AM   #5
charged86
charged86's Avatar
how about a TUNE first or wheels and springs.
INSTAGRAM @Rcf_700 www.youtube.com/boostindub
Old 04-25-2014, 01:59 PM   #6
Freetime
Freetime's Avatar
There are "thousands of threads" because there isn't any agreed upon answers. It's subjective. That's the point of the forum - for discussion. If it was just answers, it would be a Wiki.
Old 04-25-2014, 02:48 PM   #7
f0rge
head of infinite swagger
Drives: 2013 FR-S 6MT
It's impossible for us to recommend anything unless you tell us your goals.
Are you after looks or speed or handling?
100% street car? Auto-x or track days? How many? What's your skill level/experience?
2019 Golf R 6MT - current daily...I need another coupe
2008 Civic Si - winter beater
2000 Silverstone M5 6MT - SOLD
2013 Ultramarine FR-S 6MT - Car Journal - SOLD
2004 AlpineWhite M3 6MT - SOLD
f0rge is offline   Reply With Quote
The Following 2 Users Say Thank You to f0rge For This Useful Post:
humfrz (04-25-2014), Model Citizen (04-26-2014)
Old 04-25-2014, 04:11 PM   #8
J_kennington
Drives: 2013 asphalt scion FRS
Don't we have vendors with websites that have every part listed with prices? How could we know what a parts price will be in 6 months?
I understand your concept, but it's just not feasible.
2013 raven frs(dd/grocery getter)
1990 mitsu eclipse gsx(street/strip car)
1995 gmc 1500 4x4(off road toy)
2005 Yamaha yz250f
J_kennington is offline   Reply With Quote
Old 04-25-2014, 04:52 PM   #9
TStafford
TStafford's Avatar
What he listed is great. It gives a new user some options to research. I have been looking at this stuff since I got my car and I have learned much. Sometimes it helps to read the quick version so you can dig deeper and see what you want. I am going for handling.
The DIY and debates are great but it also helps to know you might not need coilovers for everyday aggresive driving.
Old 04-26-2014, 07:56 AM   #10
Demandred7
Demandred7's Avatar
Drives: 2018 Camry XSE V6
You might want to consider a strut tower brace. I personally went with Grimmspeed. There is an immediately noticeable improvement in the handling.
Demandred7 is offline   Reply With Quote
The Following User Says Thank You to Demandred7 For This Useful Post:
Old 04-26-2014, 08:32 AM   #11
Model Citizen
Lacking brains
Drives: frz
x1000
A shitty question gets shitty answers
Model Citizen is offline   Reply With Quote
The Following User Says Thank You to Model Citizen For This Useful Post:
Lonewolf (04-26-2014)
Old 04-27-2014, 01:52 AM   #12
jeepmor
Drives: 84 CJ7, 08 Duramax, 2014 FRS
I'm a new owner also and see where the OP is coming from.
My goals would be, at this moment, as follows
Protection - rally armors, tint, front wrap, weather techs. Still working here. Weathertech and rally armors in.
Power - drop in air filter, not much else yet. Easy 4-5ish gain. That's a lawnmower helping you along, not trivial for $50. The rest comes later in form of exhaust and other bolt on stuff. Intake tube and other drop/bolt in parts.
Handling - Once I understand the car more, I'm moving to stiffer bushings. Not sure just where yet, but I'm starting with shifter and trans mount bushings. Halfway there already with Perrin shift bushing in hand. Deciding on trans mount bushing, probably a slip in like Whiteline. After 3150 miles, there are areas I'd like to take some squishiness out of, some I'd leave. Shifter tail good place to start as it feels kindy sloppy under hard driving. Strut braces next.
NVH - I'm a commuter in this car on already rough paved roads. I don't want a racecar, too bumpy. This directly competes with ultimate handling of the car however. Finding the right suspension parts will be key here. I don't want to add weight, but I can see some dynamat doing this car a lot of good already to reduce NVH. But that's not the point of this platform, handling is.
Convenience - A euro center console armrest would be nice. Fog lights would be helpful, I'm in the PNW, I see a lot of fog.
And lastly, I'm a long term car guy. I have an 84CJ7 that is pretty setup for wheeling that I've had for 20 years. This car is my new jeep and will eventually replace it. Jeep is in the garage, my FR-S resides in the weather, PNW weather at that. I like this car, but I don't see myself going crazy with it just yet. But I have looked, it'd be pretty easy to just turn this into a racecar with what is already available, after only two years. I suspect I have to thank Subaru for this as I'm guessing there is a lot of cross-over.
Thanks to John Juan for providing actual data to help someone paint the picture.
jeepmor is offline   Reply With Quote
Old 04-27-2014, 10:05 AM   #13
tennisfreak
Drives: 2018 BMW M240i
If I could start from scratch first thing I would do is forced induction.
Outside of winter time the car just feels so slow and lethargic. Driving down highway last night a freaking douche Accord was driving 55 in fast last (65 speed limit) and when I tried to get around they floored it. I felt embarrassed that even downshifted and revved up past 5k my car could not keep up with an Accord. My wife was with me and she said "at least it sounds fast", LOL.
You could do headers+full exhaust+tune and get ~40hp but by the time you do all of that you could easily be in $3000.
I wish I had just gone with stg 1 turbo and then upgraded other things from there.
No Convertible or Performance Upgrades jpit BRZ First-Gen (2012+) — General Topics 4 08-02-2013 11:03 PM
Performance upgrades, still on Warranty Matt_RSA AFRICA 21 03-20-2013 08:03 AM
How can you lease and do performance upgrades? McDeLtA_T Scion FR-S / Toyota 86 GT86 General Forum 26 02-02-2013 11:34 PM
Considering Driving School Over Performance Upgrades GhostofAkina Scion FR-S / Toyota 86 GT86 General Forum 28 11-02-2012 02:20 AM
Clutchmasters and ATS performance clutch upgrades! at Vivid Racing vividracing Engine, Exhaust, Bolt-Ons 2 10-12-2012 05:53 PM
