Old 04-24-2014, 09:54 PM   #1
wparsons
wparsons's Avatar
Patching screw hole - Dunlop ZII's
Since things seem to come in threes, I figured I was due for another one (first was a snapped wheel stud, second was rusted solid swaybar endlinks that had to be cut off the struts), and picked up a screw in my summer tires the other day.
I've never had to patch an extreme summer tire before, any concerns against it?
Anyone from the Toronto area have any recommendations for shops to do the repair in either Whitby or Yonge/Eglinton area?
flickr
Old 04-25-2014, 10:29 AM   #2
Wepeel
Drives: '13 BRZ Ltd
I've plugged them before and autox'd on it. As long as it's in the tread and not the sidewall it should be fine. I did it with those kits you can get from wherever (plug from outside, don't need to remove wheel) - ream hole, shove the plug material in, cut off leftover gunk. No issues and held pressure as good as normal - not sure if racing orgs have any guidance about this though.
Edit: not specifically Z2's but other extreme performance tires.
Wepeel is offline   Reply With Quote
Old 04-25-2014, 10:38 AM   #3
wparsons
wparsons's Avatar
Tire shop had no issues patching it, proper plug from the inside. It's in one of the center grooves, so not even in a useful tread block. They said there should be no issues with tracking it at all.
flickr
Old 04-25-2014, 11:07 PM   #4
zimzum
Drives: h22 hatch
i would spend the extra 5 bucks and have a proper patch job from the inside done. takes an extra couple of min but its worth the piece of mind.
zimzum is offline   Reply With Quote
Old 04-25-2014, 11:54 PM   #5
White64Goat
Using a reaming tool from the outside should only be used as an emergency fix as it damages the steel belts. In the old days before steel belts it wasn't as critical. Steel belted tires should be patched from the inside when possible.
Old 04-26-2014, 12:13 AM   #6
dradernh
Drives: Used to Drive:Grand-Am GS #54 E36M3
My club's tech sheet has this to say about tires:
Tires: No cracks, blisters, or cord evident. NO PLUGS! Front tires must be the same size. Rear tires must be the same size. Tread depth must be adequate for wet driving.
I've never asked why plugs aren't allowed. Thinking about it, maybe the concern is that the plug could give up and allow a rapid drop in tire pressure.
dradernh is offline   Reply With Quote
I got a hole in my tire -_- JLMtm Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 19 02-17-2014 03:10 PM
Drill a hole in the taillights? dem00n Issues | Warranty | Recalls / TSB 50 01-24-2014 12:58 PM
HOLE in my exhaust!!? Jolaessss Engine, Exhaust, Transmission 8 10-13-2013 11:23 PM
San Diego SCCA Solo 2 - lot patching party whataboutbob Southern California 0 01-03-2013 11:32 PM
Torque hole discussion jeebus Engine, Exhaust, Transmission 19 08-28-2012 07:51 PM
