Old 04-23-2014, 10:12 AM   #1
snodgrass
Drives: 2014 BRZ Limited
Bluetooth connection "fixed" 2014 Limited
Hi
I just bought my BRZ about a month ago. Like many others, I was having trouble with my bluetooth connection randomly disconnecting and reconnecting. I played around with some settings and haven't had any trouble since then. The catch is that I have to manually connect my phone each time I get in the car and want to use bluetooth. But once it's connected, no problems. Been going strong for 2 weeks now.
I went to Setup > Bluetooth > Registered Devices > Selected my device on the list and selected Detail > For Connection Method, the default is From Head Unit, I changed it to From Device.
That's it as far as the head unit goes. Once it's set, it's set. Now when I get in the car, I have to manually connect to the car from my phone. Specifically, I'm using a Samsung Galaxy S4 on Verizon. I created a settings widget that links to Bluetooth settings on the phone and put it on my main screen. When I get in the car, all I do is click that widget, select the head unit on the list and I'm connected.
I'm sure your mileage may vary depending on what phone you may have but it's worth a try.
Sorry if someone else has figured this out and posted already. I looked all over the interwebs and didn't find anyone that had posted about this yet.
Good luck!
snodgrass is offline   Reply With Quote
The Following User Says Thank You to snodgrass For This Useful Post:
JS + BRZ (04-23-2014)
Old 04-23-2014, 10:15 AM   #2
fourvalleys
Howdy!
fourvalleys's Avatar
Drives: Party ST, Classic Mini
It's well documented, and it works for some. Unfortunately, it seems like not all.
http://www.ft86club.com/forums/showthread.php?t=58097
e: VVVVV
same here, my issue was fixed by updating my software. Works great.
fourvalleys is offline   Reply With Quote
Old 04-23-2014, 10:53 AM   #3
tahdizzle
So elite I'm 1338
Drives: WRB Subaru BRZ
Make sure you're running the current android version. I updated mine and I have no trouble connecting automatically.
Old 04-23-2014, 01:19 PM   #4
snodgrass
Ah! Clearly I need to learn to read beyond the general forum. :-)
Old 04-23-2014, 01:58 PM   #5
GreenMonster
Just doing research
GreenMonster's Avatar
Drives: 03 Acura CLS 6MT
Yeah, the tech topics have a lot of great info...
I've spent a lot of time in the Software, Electronics, and DYI subforums.
GreenMonster is offline   Reply With Quote
I've fixed my Bluetooth connection issue! Superhatch Issues | Warranty | Recalls / TSB 34 04-15-2015 02:15 AM
"This repair is not covered by Subaru's limited warranty" RE: 4th gear tranny grind DoomsdayJesus Issues | Warranty | Recalls / TSB 108 04-29-2014 01:15 AM
Fittedtho presents: "What the hell is wintermode?" Introduction to 2014 car meet YDNA Southern California 14 01-19-2014 03:58 AM
Have they fixed the "Torque Dip"? dammitcubs BRZ First-Gen (2012+) — General Topics 22 03-05-2013 06:50 PM
Bluetooth "action" button? tbertran Electronics | Audio | NAV | Infotainment 4 10-05-2012 02:26 PM
