Old 04-22-2014, 07:42 PM   #1
EggsAreGood
EggsAreGood's Avatar
Drives:
Sportlines + stock LCA. How will it look?
I will be driving my DD with stock rear LCAs for around 2 weeks with the sportlines. I understand I will get a negative camber around -2.0 but I wont be able to get proper rear lcas for around 2 weeks from now. How will it look? Bad? good? or hardly noticable?
Sent from my SM-G900P using Tapatalk
EggsAreGood is offline   Reply With Quote
Old 04-22-2014, 08:04 PM   #2
wparsons
wparsons's Avatar
It'll be noticeable, but not terrible by any means.
flickr
Old 04-22-2014, 08:25 PM   #3
mashal
DADA
mashal's Avatar
Drives: 2013
Post a picture, I may be running the same
mashal is offline   Reply With Quote
Old 04-22-2014, 08:49 PM   #4
8R6
8R6's Avatar
Drives: FRS
youll be fine for 2wks
8R6 is offline   Reply With Quote
Old 04-22-2014, 08:57 PM   #5
EggsAreGood
Drives:
I would also like to see a pic if possible but since its only temporary for me I'll just go for it and provide the pic by end of this week Thanks guys.
Old 04-22-2014, 09:31 PM   #6
MyEvilMonkeys
Drives: 2013 Scion FRS
FRS @ Mt Shasta View Point by MyEvilMonkeys, on Flickr
Been running this for about 8000 miles with no negative impact to the tires and really isn't that noticeable. Two weeks won't hurt anything.
MyEvilMonkeys is offline   Reply With Quote
Old 04-22-2014, 09:32 PM   #7
mashal
DADA
mashal's Avatar
Drives: 2013
That's springs only?
Old 04-22-2014, 09:38 PM   #8
MyEvilMonkeys
2013 Scion FRS by MyEvilMonkeys, on Flickr
Found a better side profile.
Old 04-22-2014, 09:40 PM   #9
MyEvilMonkeys
Yep, sportline on stock shocks. No camber correction.
Old 04-22-2014, 09:40 PM   #10
bfrank1972
Drives: 2013 FR-S Argento
Won't be bad at all - if anything leave it and add some negative camber to the front (camber bolts), a bit of an aggressive look. Just make sure to get it aligned though, your toe can change and that will increase your tire wear quite a bit.
bfrank1972 is offline   Reply With Quote
Old 04-22-2014, 09:41 PM   #11
mashal
DADA
mashal's Avatar
Drives: 2013
I have read several people have blown their stock shocks, I'm guessing its too Much stress? But here you are at 8000miles no issues ?
Old 04-22-2014, 09:45 PM   #12
EggsAreGood
Drives:
That doesnt look bad at all. Ill be good for 2 weeks. Who knows I might keep it like that.
Old 04-22-2014, 09:50 PM   #13
BlueDubbinTDI
BlueDubbinTDI's Avatar
Drives: 2013 FR-S, 2012 MCS
Rear needs a spacer badly
Old 04-22-2014, 10:01 PM   #14
MyEvilMonkeys
My shocks hadn't blown, but the lack of shock travel certainly is evident on rougher roads. My new FA500s are certainly smoother.
Put them new Sportlines on sevi21 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 24 05-17-2014 07:07 PM
19' on eibach sportlines? Robert95g Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 01-27-2014 01:02 AM
Sportlines on stock shocks <4k miles stefmiesterb Brakes, Suspension, Chassis 2 11-18-2013 10:52 AM
FS: SoFla only Eibach sportlines and OEM stock shocks wrussi Brakes, Suspension, Chassis 7 08-01-2013 01:39 PM
FS: Stock Struts w/Eibach Sportlines OmarGC Brakes, Suspension, Chassis 4 06-09-2013 05:52 PM
