CANADA Canada
Old 04-20-2014, 08:06 PM   #1
wparsons
wparsons's Avatar
GTA - source for OEM parts
Looking for new front endlinks, hoping to get them tomorrow. Anyone know of a place that will have them in stock?
The closer to Yonge and Eglinton the better!
I'd also consider certain aftermarket ones if the price is right, I don't need adjustability, just need ones that are effed and seized.
flickr
Old 04-20-2014, 09:47 PM   #2
that_guy
Dances with Cones
that_guy's Avatar
Drives: 2013 Scion FR-S Raven
Dealer. You'll have them next day.
2013 Scion FR-S - Raven
2011 Scion tC - Cement - SOLD
that_guy is offline   Reply With Quote
Old 04-20-2014, 10:08 PM   #3
drewbot
( ͡° ͜ʖ ͡°)
drewbot's Avatar
Drives: '13 Whiteout FR-S A/T
Dealer fo sho.
Personally I go to Budds Subaru but that may be far for you. The parts guy at Budds is extremely fast and helpful.
drewbot is offline   Reply With Quote
Old 04-21-2014, 09:50 AM   #4
krayzie
Drive From Home
krayzie's Avatar
Drives: BRZ STI Performance
If they are stocked at the local warehouse then you'll have them next day or two from the dealer. Otherwise like me when I buy various size nuts and bolts for suspension work, it usually takes 2 weeks shipped from Subaru Japan.
You can try the Toyota dealer as well but I find their prices are much higher for the same parts.
krayzie is offline   Reply With Quote
Old 04-21-2014, 04:07 PM   #5
aruxe
you can let me know what parts you looking for
I work at Subaru of Maple as Sales rep
aruxe is offline   Reply With Quote
Old 04-21-2014, 04:51 PM   #6
wparsons
wparsons's Avatar
Front swaybar endlinks (both sides) with nuts (all 4), and one wheel stud (front if it matters).
I don't have the part number for the end links to cross reference against WRX parts or I would be looking at more places online. No one seems to show any useful parts for these cars yet.
flickr
Old 04-22-2014, 11:08 AM   #7
wparsons
wparsons's Avatar
Found everything in stock at C and C Subaru, which is right along my drive home anyway, picking it up tonight. Subaru is a bit cheaper on everything than Toyota, $28 vs $35 each for the end links and a couple dollars less on the stud too.
flickr
Old 04-22-2014, 11:20 AM   #8
AdrianG
Generally Well Liked
Drives: '08 STi Hatch, '11 Outback 3.6R
Good to hear. They are a good dealership to deal with for parts and sales.
AdrianG is offline   Reply With Quote
Old 04-22-2014, 12:10 PM   #9
wparsons
wparsons's Avatar
I got there after parts closed last night, but the sales guy nearby was super helpful even though he knew I clearly wasn't there to buy a new car.
flickr
Old 05-17-2014, 11:09 AM   #10
Khyron686
Drives: 2011 Outlander XLS, 2013 FR-S Blue
Mine are seized too - how did you get them off? I'm looking at cutting with a dremel..
Khyron686 is offline   Reply With Quote
Old 05-17-2014, 12:30 PM   #11
wparsons
wparsons's Avatar
You can try heating them up to try loosening up the rust, but I ended up having to sawzall mine off. I don't think you'll get a dremel into the right place to cut them, the discs are too small.
If you can, try really soaking them in penetrating oil a few times before resorting to cutting. The trouble is that you need to get them partially loosened or cutting is a HUGE pain in the ass. Might help to clean up the threads with a wire brush too. I could get mine partially loose, but not all the way off. By the time I thought about trying a wire brush I had already damaged the end link too much anyway, so I was already ready to replace them.
flickr
Old 05-17-2014, 07:25 PM   #12
Jereina
Drives: Scion FR-S
Heat works best
You'll also need a pair of vise grips
You'll feel a disc like projection between the nut and the link itself. Put that vise grip on it so it prevents it from spinning while you're trying to loosen the nut.
I was able to zap one side out with just the vise grips.
Other side I had to heat it up a bit before it would come out.
Jereina is offline   Reply With Quote
Source for TRD Parts injuryexpert Cosmetic Modification (Interior/Exterior/Lighting) 3 12-16-2013 06:44 AM
Anyone know a good source for TRD parts? FRiSson Scion FR-S / Toyota 86 GT86 General Forum 7 04-09-2013 04:29 PM
Source for wrecked/parted out FRS/BRZ parts? Acree Scion FR-S / Toyota 86 GT86 General Forum 5 02-25-2013 03:58 PM
HID source in GTA wbradley CANADA 2 08-12-2012 10:09 AM
FT-86 SpeedFactory - Exclusive Source for FR-S / BRZ / GT-86 Parts! FT-86 SpeedFactory Announcements, Contests, Giveaways 10 08-02-2012 12:50 PM
