Old 04-19-2014, 05:18 PM   #1
DIM
Fog Light help
Hello FT86Club
I recently installed OEM fog light's on to my FR-S. I used 2 install guides, one for the fog light stalk install and the other for the fog light install.
Fog light install - http://www.ft86club.com/forums/showthread.php?t=49723
Stalk - http://www.ft86club.com/forums/showthread.php?p=848423
How I spliced/tapped into the connectors - http://www.ft86club.com/forums/showp...06&postcount=3
Following both guides very carefully, the fog light's still won't turn on. The stalk works just fine; signal, low beams and high beams still work properly. But still no luck on the fog light or even indicator on the dash.
Here are a few pictures of the wires that I had to tap into.
Stalk installed.
Wires being tapped.
I also check the fuses, nothing was blown. I checked both fuses under the steering wheel and were not blown.
Any suggestions?
Thanks in advance.
DIM is offline   Reply With Quote
Old 04-19-2014, 10:17 PM   #2
speedrye
Drives: White
I assume you're trying to turn the fog lights on with the head lights on, right? Just making sure since they'll only come on with the headlights and I was taught to start with the simplest questions first when diagnosing.
If you're doing that, the problem is at the stalk since the indicator light won't even work (will only work with fog switch on and headlights on). The output from the stalk goes to the computer which controls the output to the indicator on the dash and also to the relay which controls the fog. If you're not getting the indicator, I doubt you're getting any signal to the computer so you definitely won't be getting power to the relay and fogs.
speedrye is offline   Reply With Quote
Old 04-21-2014, 09:54 AM   #3
DIM
@speedrye
Would the indicator still turn on even though the fog light's won't turn on? I also thought this way would work since I "basically" the same install noz did. ( http://www.ft86club.com/forums/showthread.php?t=49723 )
Old 04-24-2014, 10:16 PM   #4
DIM
ttt
Old 04-24-2014, 10:43 PM   #5
Zen86
Run, Reach, Fly
Zen86's Avatar
Drives: Monogram Firestorm
Seems like you wired the correct wires. Check your wire taps again. For both the lights and indicator to not come on might just be that there might be no connection between the stock wire and the taps. And as posted above make sure low beam is on. The indicator will only turn on if low beam is on
Zen86 is offline   Reply With Quote
Old 04-25-2014, 12:11 AM   #6
Vick_794
Drives: Frs
It's because those wire tappers u have are worthless. They sent those with my buddy club tails. They don't make a good connection.I ended up having to go old school and splice and tape them. I hooked up my diode dynamic fog light kit today. t-tapper connectors work so much better than those kind.
Vick_794 is offline   Reply With Quote
Old 04-25-2014, 12:13 AM   #7
Vick_794
Drives: Frs
The wires are so tiny they just slip Inbetween the part that is supposed to cut them.
Old 05-01-2014, 12:19 AM   #8
DIM
Do you really think the splice connectors are the problem?
Old 05-01-2014, 01:22 PM   #9
OURO3OROS
Drives: 2013 Asphalt FR-S
I think that's very possible. People go both ways on this, but I avoid splice connectors and prefer to solder, even though I'm an amateur, at best. Did you strip the wire before applying the splice connector or count on it to pierce the coating? They're supposed to, but don't always.
OURO3OROS is offline   Reply With Quote
Old 05-01-2014, 02:02 PM   #10
codesplice
Elite Recognized Geek
codesplice's Avatar
Drives: 2014 DGM BRZ Limited
On my last car, I used the taps for just about every aftermarket wiring connection without any major issues. On the BRZ, though, I didn't have much luck with taps when doing the boomerang DRL mod. I'll second @OURO3OROS's suggestion for solder + tape (or, better yet, heat shrink). Solder doesn't really leave any room for something to go amiss, and also means you won't have to worry about the connection rattling apart later on. Looks much cleaner, too.
This post is a work of fiction. Names, characters, places, and incidents either are the product of the poster's imagination or are used fictitiously, and any resemblance to actual persons, living or dead, business establishments, events, or locales is entirely coincidental.
G+
codesplice is offline   Reply With Quote
Old 05-01-2014, 03:19 PM   #11
alderaan34
alderaan34's Avatar
Are you in SATX? I might be able to help you out. I am stationed at Lackland.
alderaan34 is offline   Reply With Quote
Old 05-01-2014, 03:53 PM   #12
DIM
I did not strip the wire before adding the splice connector. So I might just repin the harness or solder them together.
I'm currently stationed at Dyess, but go to SA about once a month or so.
Zeta Performance - Lights (HID, LEDs, LED Taillights, LED Reverse Light, Trunk Light) ZetaPerformance Exterior Parts - Lighting 172 11-13-2015 10:25 AM
For Sale: Smoked/Red/Clear Reverse Light + Brake Light Bars Brand New! Vicious LED Exterior Parts (Aero, Lighting, Etc.) 9 08-25-2013 07:26 PM
**Valenti Japan LED Tail Light & Rear Bumper Reverse LED Light** nigel-jdmparts Exterior Parts - Lighting 13 04-30-2013 12:14 PM
Risk Racing Light Mine Professional Magneti - Magnetic mini light fixture! DjDATZ Off-Topic Lounge [WARNING: NO POLITICS] 0 06-28-2012 11:21 AM
