Old 04-17-2014, 02:16 PM   #1
swift996
swift996's Avatar
Swift's at it again - Wilwood 14" 6-Pot BBK for WRX - Fit to BRZ
You may have seen my initial Wilwood BBK job here:
http://www.ft86club.com/forums/showthread.php?t=32594
Where I fitted a 4-Pot Wilwood kit to the BRZ. It has worked great, absolute great bang for the buck. Probably the best idea for autocross and great for street/HPDE use.
Anyways, I found a steal on a set of gently used Wilwood brakes for the 08+ WRX. I should have time to try the install next weekend. I'm running 18s and it appears everything will bolt right up. More to follow...
6-Piston Calipers
355mm x 32mm rotors
Details from the Wilwood Site: (unfortunately they are the narrow-lites which is a smaller pad area versus the other kit)
http://www.wilwood.com/BrakeKits/Bra...%2c+except+STI
Fitted on 2011 WRX:
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
The Following User Says Thank You to swift996 For This Useful Post:
Scooby South (05-02-2014)
Old 04-17-2014, 02:34 PM   #2
Kami Speed
Kami Speed's Avatar
Drives: Scion FR-S
Send a message via AIM to Kami Speed
Beautiful! Just fits inside of those wheels. mmmmmm
Kami Speed is offline   Reply With Quote
Old 04-17-2014, 02:44 PM   #3
ModBargains
ModBargains's Avatar
Drives: FRS, M3
Looks great!
ModBargains is offline   Reply With Quote
Old 04-17-2014, 02:46 PM   #4
swift996
swift996's Avatar
I initially thought I bought the regular BBK 14" which has a 34% larger pad area (relative to the narrow-lite), which is why I got so excited. Turns out this is the same caliper Wilwood uses on the BRZ kit but with a 14" rotor instead of the 12.9" and 32mm width versus 28mm.
Old 04-17-2014, 02:59 PM   #5
CSG David
CSG David's Avatar
Finally! That's going to be a better kit than the original one.
Old 04-17-2014, 03:20 PM   #6
swift996
swift996's Avatar
It uses the exact same bracket as the BRZ kit, it's going to come down to will it clear my wheel! Stay tuned!
Old 04-17-2014, 05:23 PM   #7
OrbitalEllipses
Drives: Attitude
On today's episode of "Will it clear?!"...
Old 04-22-2014, 11:03 AM   #8
swift996
swift996's Avatar
Question for those who have done similar conversions. Instead of swapping the bleeder screws can I just swap the calipers? For example use the driver's side on the passenger side? That would keep the outer caliper and bleeder screw in the same position.
Old 04-22-2014, 11:45 AM   #9
Racecomp Engineering
Not if the pistons are differentially bored.
- Andy
The Following User Says Thank You to Racecomp Engineering For This Useful Post:
swift996 (04-22-2014)
Old 04-22-2014, 01:45 PM   #10
swift996
swift996's Avatar
Yup, given the orientation of the pistons, it looks like I will need to swap the bleeder screw. What's the process, just unscrew both and swap? I assume both inner and outer?
Old 04-22-2014, 01:46 PM   #11
OrbitalEllipses
Drives: Attitude
- Andy
They are.
Old 04-22-2014, 02:31 PM   #12
They are.
I had a feeling.
- andy
Old 04-28-2014, 10:56 AM   #13
swift996
swift996's Avatar
I plan to test fit this evening. Sorry for the dirty pics, I didn't have time to clean them up:
Old 04-28-2014, 10:23 PM   #14
swift996
swift996's Avatar
....and they clear! Now to find time to install them:
Wilwood BBK for WRX - Fit to BRZ swift996 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 136 05-03-2019 07:41 PM
Swift coilover springs 7" 8k and 7k Proof Brakes, Suspension, Chassis 2 12-02-2013 01:59 PM
wilwood and te37? ft86me Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 11-19-2013 05:26 AM
Wilwood BBK Slartibartfast Suspension | Chassis | Brakes -- Sponsored by 949 Racing 59 01-08-2013 10:12 PM
