Old 04-16-2014, 01:21 PM   #1
kelee
Drives: RX350
Factory Alignment FRS vs BRZ
Does anybody have the factory alignment specs for the FRS vs the BRZ?
I'm wondering if you can align a BRZ to act more like an FRS from the factory (on stock suspension).
kelee is offline   Reply With Quote
Old 04-16-2014, 01:32 PM   #2
celica73
Drives: '13 BRZ / '11 Outback / '06 Tundra
The difference isn't alignment, it's spring rates. FRS are softer in front and firmer in rear, that combination makes the FRS more prone to oversteer.
Add some toe-out to the rear of the BRZ and you will get to a similar place (front and rear toe are the only factory adjustments on the car).
celica73 is offline   Reply With Quote
Old 04-16-2014, 01:37 PM   #3
vroom4
or just bump the rear tire pressure up about 5 pounds.
vroom4 is offline   Reply With Quote
Old 04-16-2014, 03:05 PM   #4
wparsons
wparsons's Avatar
IIRC, BRZ's run more rear toe in (FRS might be 0?). That said, that's only part of the equation and you'll need different springs or other changes to change the balance.
flickr
Will the BRZ/GT86/86 Factory Spoiler fit in the Factory FR-S Spoiler mounting holes? jbsali Cosmetic Modification (Interior/Exterior/Lighting) 1 02-13-2014 08:45 PM
Alignment in GTA? f0rge CANADA 13 09-06-2013 12:17 PM
Big O For Alignment? djliquidsteele Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 02-19-2013 05:21 PM
Anyone do their own alignment? TemeCal Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 11-09-2012 11:36 PM
Swap: factory 16s for factory 17s Sydney MZ21 Australia Classifieds 10 07-29-2012 10:46 PM
