Drives: 2014 FR-S
KW V3's VS MCA REDS?
I'm still trying to decide which coilovers to go with for my STX prep. I'm just trying to get a little more information. I'm leaning towards the KW V3's but only because it looks like a majority of the racers are using them. You cant always be faster if you car running the same parts as everyone else so I'm looking at other options. Can anyone give any input on MCA REDS? I'm slightly worried about support since they are based out of Australia.
So elite I'm 1338
Drives: WRB Subaru BRZ
No input on those, but KWs are probably the best bang for your buck in terms of a tested product and performance.
Im also in the same situation. V3s, b18s, and someone told me to get the Ohlins..... |
Drives: 2014 FR-S
Im looking at the pro's and con's and the MCA's at least come with camber plates. Where are the adjusters on the MCA's and how do you adjust the settings?
#5 | ||
Drives: blue sardine
MCAs are very highly regarded here but objectively I do not know where they stand as I have never seen any independent testing done on them. I have Reds fitted to my car and I'm happy with them but I can't compare them to anything else. If you did get them you would be up for freight in two directions if you ever needed work carried out on them as there is no support for them in the States. (I think you should get them so you can lend your car car to CSG Mike to get an appraisal.)
Captain Snooze sends his regards.
Conedancer
Drives: 2013 Subaru BRZ SWP
KW Var3 has a lifetime warranty vs. the reds 2 year warranty. That in itself is worth it. Plus the double adjust-ability of the KW's with both Rebound and Compression make for better way to dial in..which I guess the reds have also...Spring rates are relatively competitive out of the box on the KW's.. not sure on reds.. guess it depends on how serious your build is, Is it a national level build or something local.
![]() Bill
Join my BRZ/FRS FB Group ![]() Thanks to:Kartboy/Wheeldude/Nameless Performance /Gaurd Transmission LSD |
#7 | |
As I said in my post above the Reds have single adjustment that does compression and rebound simultaneously. Rates on the Reds are 6kg/mm front and rear.
Conedancer
it depends on how the reds are valved.. ..even tho they have dual adjust-ability... the valving could totally suck..the valving has to somewhat match the springrates.. but since there are no spring rates listed..its a crapshoot
![]() Bill
Conedancer
oh.. 6k and 6k.. that seems a bit 'lite' compared to most I know. most competitive spring rates are at least 7k at both ends..
#10 |
Drives: 2014 FR-S
National Level build Bill. Right now Im trying to catch up with Annies build. If I can get the build done in time I will be headed to Crows Landing, Packwood, and Lincoln.
I can get either set for the same price so it comes down to features. The Reds come with camber plates so that's a plus but having the adjuster on the bottom kinda sucks. I don't want to be laying in a puddle while I change the dampening. If I went with the V3's I would have to pick out camber plates(leaning towards RaceSeng). RaceComp Engineering and Ohlins are also options I've been looking into. Why is this so hard? |
| The Following User Says Thank You to BlueBlazeRacer For This Useful Post: | Scooby South (04-16-2014) |
#11 | |
Conedancer
chances are if they are 6k/6k.. they should be able to handle 7 or 8k springs.. Annie's build is fairly similar to most of ours already. She's on KW's.. with 7k springs at both ends. the raceeng plates are nice.. for sure..just not sure they are $400 nice.. Racecomp's Tarmac 2's is also a viable choice. they come with 400lb springs already. .. Is MCA willing to send you a shock dyno sheet?? We are all so close right now.. MCS, KW Var 3, RaceComp Tarmac2's...those are whats on most peoples right now.. there the occasional odd Feal singles out there.. Haven't seen any Ohlin's out in competition yet.. or the MCA's.. Hope you get what works well ![]() Bill
#12 |
Shouldve stuck to street class! (then you wouldnt have to race annie either).
#13 |
Drives: 2014 FR-S
Im not worried about Annie. I would ask for a co drive if I wasn't worried about beating her with her own car.
There should be around 4-5 BRZ/FR-S National STX cars coming out of the Washington/Oregon region. Each already having Co-drivers makes for 8-10 drivers to watch out for. |
#14 | |
Conedancer
![]() Bill
