Old 04-14-2014, 02:08 AM   #1
subiestyle
subiestyle's Avatar
Drives: 2014 Monogram FR-S White MT
Keep air recycle off
What determines if the air recycle button is off or on?
Sometimes when I turn it off and start my car, the button will be on. Other times it will be off.
I want it to be always off to get fresh air inside.
subiestyle is offline   Reply With Quote
Old 04-14-2014, 08:53 AM   #2
Eurasianman
Chief
Eurasianman's Avatar
Drives: 2013 DGM BRZ Premium 6MT
Seeing as you have the Monogram series, I take it you have the auto climate control. I believe the recycle air will automatically kick on if it is hot inside the vehicle and you have the temperature set to relatively cool/cold. So, for the first few minutes, it will use 'MAX A/C', which means fresh air + recycled air, until the inside of the car has come closer to the temperature you have set.
I know my father's car, that has auto climate control, kicks into full gear during the summer when he has the temperature set to 70 F. But after a few minutes, the AC system quiets down and I believe it will continue to recycle air unless he changes the setting after the interior has cooled down.
Eurasianman is offline   Reply With Quote
Old 04-14-2014, 09:00 AM   #3
aeon
Drives: Toyota Corolla e11 pre Facelift
In Germany wehre Auto climate control comes standart the dealer can reprogramm it so it never turns into recycle mode automatically.
It s what I let them change on my gt86 because I really disliked that .
There are several different other settings the dealer can reprogramm/set to different stuff
Gesendet von meinem HTC One mit Tapatalk
aeon is offline   Reply With Quote
Old 04-14-2014, 01:46 PM   #4
bdbx18
Drives: Present MDX, Civic Hybrid, BRZ
I know it's programmable on the Bimmers I used to have. I don't know about the GT86.
Current: 07 MDX, 06 Civic Hybrid, 13 BRZL
Past: 03 M3 SMG, 99 540i, 01 X5 4.4, 01 X5 3.0, 03 MDX, 92 NSX, 89 Maxima, 86 Integra, 88 Odyssey, 88 Legend, Supra, MR2T, Pathfinder, MirageT, Accord
bdbx18 is offline   Reply With Quote
Old 04-14-2014, 03:34 PM   #5
HapaHaole
Drives: Grocery cart
I wouldn't disable it, image driving towards vallejo and going by the chevron refinery, I always do re-rirculation there since it smells!
SOLD: 2014 BRZ Limited WRB 6 Speed.
HapaHaole is offline   Reply With Quote
