CANADA Canada
Old 04-11-2014, 02:53 PM   #1
bhbnuckle
bhbnuckle's Avatar
Drives: 2013 Asphalt FR-S/2003 Honda Accord
18x8.75 +20 what do you guys think?
Hello..
What do you guys think of that setup with 1" eibach pro kit?
xxr 527 with 225/40/18 tires.
bhbnuckle is offline   Reply With Quote
Old 04-11-2014, 03:21 PM   #2
alanhung85
Drives: 2014 Subaru BRZ Sport-tech Pkg
Originally Posted by bhbnuckle View Post
Hello..
Absolutely no issue with rubbing. If you like the stretched tire look sure. I would personally go with 235 or 245 though.
alanhung85 is offline   Reply With Quote
Old 04-11-2014, 03:40 PM   #3
BRZZZZZZZZZZ
Car Nut
BRZZZZZZZZZZ's Avatar
Drives: BMW 335d, Toyota Echo RS, FRS
Sounds like it would rub with the right sized tire for that rim.
BRZZZZZZZZZZ is offline   Reply With Quote
Old 04-11-2014, 03:54 PM   #4
Moetivegt86
Moetivegt86's Avatar
Drives: FRS Argento 6mt
It's going to poke A LOT at that drop. Your going to need to go lower and camber more for that offset to look good.
Moetivegt86 is offline   Reply With Quote
Old 04-11-2014, 04:01 PM   #5
bhbnuckle
bhbnuckle's Avatar
guess better do +35 offset all around or 18x9.75 +20 rear and 18x8.75 +35 front.
Old 04-11-2014, 04:04 PM   #6
Moetivegt86
+35 all around looks good man, unless you get coils and lcas I wouldn't do anything under +30 offset
I've seen +20 in person it pokes a lot it looks bad without the proper suspension mods.
The Following User Says Thank You to Moetivegt86 For This Useful Post:
bhbnuckle (04-11-2014)
BC Coilover settings you guys guys ride on g0lden Suspension | Chassis | Brakes -- Sponsored by 949 Racing 26 04-06-2014 06:56 PM
What do you guys think of Enkei OR52 18x8.5 et45 bhbnuckle Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 04-02-2014 05:59 PM
Gauging interest Enkei RS05RR 18x9+40/18x8.5+50/18x8.5+42 THMotorsports.com Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 09-19-2013 04:33 PM
Wheel Directory: Blitz BRW Profile 08 18x8.0 +45 / 18x8.0 +38 quik1987 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 08-27-2012 03:34 PM
