Northwest AK, ID, OR, WA
Old 04-10-2014, 01:58 PM   #1
Colpup
Drives: Toyota 4runner Sport Edition
Nameless op/dp install at Ishii
Have any of you guys had the nameless 2.5 dp/op installed by Ishii? I just spent an insane amount of time researching what exhaust to run and now when I call Ishii to have it installed they say fitment on that pipe is too tight and they warn against me installing it. They say they won't warranty the install and that it will likely cause heat issues where it is so close to the cylinder head. At this point I'm thinking about just having them install the nameless axleback and selling the op/dp bc they have me scared. Anybody have any experience with this?
Colpup is offline   Reply With Quote
Old 04-10-2014, 02:04 PM   #2
Chen
Regional Moderator
Chen's Avatar
Drives: 00-AP1 20-A90 06-Z33 07-FA5 93-NA1
Doesn't @NickFRS have nameless these installed on his car?
Chen is offline   Reply With Quote
Old 04-10-2014, 02:12 PM   #3
thehapaone
Wasian Ninja
thehapaone's Avatar
Drives: 2013 Crystal Black Silica BRZ-L
I am running the Nameless pipe with no issues but I know people that have had issues. As with any somewhat mass produced item there is some degree of error allowed in the bends and welds if you got a "bad" one then it may come close on either side of there the OP is
check out my build thread here
Previous Cars: 1970 Chevelle 350 (crashed still have in CA), 2000 Honda Accord Coupe (sold)
thehapaone is offline   Reply With Quote
Old 04-10-2014, 02:19 PM   #4
Colpup
So you think I should just ignore their concerns and just have them install it?
Old 04-10-2014, 02:30 PM   #5
thehapaone
Wasian Ninja
thehapaone's Avatar
Did they even test fit it? if they test fitted it and said it was too close then I could understand but it sounds like they just instantly wrote it off maybe find a better shop to the the install if they won't even try to check the fitment
Old 04-10-2014, 02:33 PM   #6
stockysnail
Just the tip
stockysnail's Avatar
Drives: 2013 Lightning Red Subaru BRZ Mt Lt
I know at least 6 people in my area that have them without any issues. I've had mine for a year and everything is great. The trick to installing it is to raise the engine up a little as it won't go in otherwise because of the flange (I think that's what it's called). Like the post above said however, not every single item that someone produces will be perfect so there's bound to be a defect here and there. If there is just call them up and ask if you can drive down to La Center to have them get it on.
stockysnail is offline   Reply With Quote
Old 04-10-2014, 02:36 PM   #7
stockysnail
Just the tip
Best option in my opinion would be to call Nameless up and schedule a time for them to put it on for you. Odds are they wouldn't charge you if they are able to do it. That way if there is a fitment issue they can just grab another one and put it on.
Old 04-10-2014, 02:50 PM   #8
HATED1
HATED1's Avatar
Drives: 86
I'm happy that the shop was pretty up front and blunt.
HATED1 is offline   Reply With Quote
Old 04-10-2014, 02:53 PM   #9
thehapaone
Wasian Ninja
thehapaone's Avatar
Granted this could be good but one bad install doesn't mean every piece from that company is now crap if they actually did test fit it and find that it was too close I understand their stance but it doesn't seem like that was the case thats like me counting out eating bacon cause one time bacon made me sick
Old 04-10-2014, 03:21 PM   #10
Colpup
Thanks for all the replies. Just to clarify, I just received my nameless axleback and op/dp 2.5" today and they both look like beautiful quality made pieces. I called ishii today to set up an install. Their receptionist said they don't recommend that pipe bc it has clearance issues near the cylinder head. They said they would still install it if I elected to but they would not be able to warranty it. I scheduled an appointment for next Wednesday, if I'm not happy with fitment I'll just have them take it off. This just has me sort of worried because I spent lots of time researching both nameless and ishii and they are both extremely reputable shops, I figured it would be a more seamless install.
Old 04-10-2014, 04:12 PM   #11
Tainen
Drives: First SWP BRZ-L
Strange. My OP/FP fits perfectly... love it.
First white BRZ in the country
Limited SWP BRZ, 35% tint, clear bra, Nameless Performance downpipe, axelback, headers
Tainen is offline   Reply With Quote
Old 04-10-2014, 05:18 PM   #12
ilpad
ilpad's Avatar
Drives: 2013 - Scion FR-S in White"red"out.
I would call Jason over at nameless if u do end up having a problem. Nameless is a great company that stands by their products and I really doubt that they would not go above and beyond to take care of u. Being that theyre local u could just run over and see them if needed.
ilpad is offline   Reply With Quote
Old 04-10-2014, 05:47 PM   #13
Colpup
This is my last resort. I'm hoping I don't have to go this route, it's a pretty long drive and I have an extremely tight work schedule.
Old 04-10-2014, 07:50 PM   #14
Imrac
Drives: 13 SWP BRZ Prem
I had fitment issues with my over and front pipe.
Those of you that don't have issues, do you have the older style from nameless that is transmission specific or the newer version that works with auto and manaual trans?
JDL UEL Headers, Nameless Res&Cat Over&Front, Invidia Q300 Catback, AVO Dry Panel Filter, Custom ECUTek Tune by DriftOffice
191WHP/151 ft-lb on 92
Imrac is offline   Reply With Quote
Nameless axle back - Install and initial impression. Mikem53 Engine, Exhaust, Transmission 18 10-21-2015 09:13 PM
Ishii Motors, VTR, or ? Yamaha_R6 Northwest 24 01-29-2014 06:13 PM
Anyone in SD have a nameless exhaust? Or want to help install mine? :) gonzo Southern California 0 09-26-2012 02:06 PM
HKS Special @ Ishii Motors BRZranger Northwest 1 08-31-2012 03:23 PM
Ishii Motor Industries Demo FR-S Ishii Motors Member's Car Journals 51 06-13-2012 08:51 PM
