Old 04-09-2014, 07:48 PM   #1
Acree
Acree's Avatar
Drives: 13 CSB BRZ Ltd
Are there any aftermarket headlights for the BRZ?
Just as the title states, I need to find some aftermarket headlights that have the exact same lens shape as the stock headlights.
2011 BMW M3 (No torque dip)
2013 Subaru BRZ - SOLD - Build Thread
Acree is offline   Reply With Quote
Old 04-09-2014, 07:59 PM   #2
w.k.s.
Drives: 14 SWP BRZ, 07 SWP STI, 05 LGT
All Headlights that fit the FRS/86 fit the BRZ. The only difference is the piece of weather stripping on the BRZ light that covers up the pointed tip of the light.
w.k.s. is offline   Reply With Quote
Old 04-09-2014, 08:01 PM   #3
Acree
Acree's Avatar
Guess I need to be a little more specific. Original post updated.
Old 04-10-2014, 10:29 AM   #4
Mooseknuckle44
Mooseknuckle44's Avatar
Do the current aftermarket lights not match up exactly? Or they have different curviture or something? I figured they would all be exactly the same?
Mooseknuckle44 is offline   Reply With Quote
Old 04-10-2014, 10:32 AM   #5
AdamBomb518
Stealth ***e
AdamBomb518's Avatar
Are you replacing your current ones? Just curious as to one would want to get rid of the factory HID's? I could see on the FRS but I'm really curious as to why on the BRZ.
*Intrigued* =)
AdamBomb518 is offline   Reply With Quote
The Following User Says Thank You to AdamBomb518 For This Useful Post:
woode (04-10-2014)
Old 04-10-2014, 10:34 AM   #6
Mooseknuckle44
*Intrigued* =)
If you haven't already, you should check out his build thread. Dude's a wizard with lighting and he's probably got something nasty up his sleeves.
Old 04-10-2014, 10:42 AM   #7
mikeTee
Yup.
mikeTee's Avatar
Drives: MT Subaru BRZ '13
I'd be more concerned about how the BRZ headlamps incorporate the turn signal versus most aftermarket 86/FRS direct replacement head lamps but I'm sure you already thought about that.
mikeTee is offline   Reply With Quote
Old 04-10-2014, 01:41 PM   #8
w.k.s.
hmm that's a bit tougher. If it's just the lens you are concerned about try theretrofitsource.
Old 04-10-2014, 01:48 PM   #9
woode
Boosted Member
woode's Avatar
Drives: 2013 Subaru BRZ
Send a message via MSN to woode
I can't imagine a better combination than stock BR-Z headlights w/ Tom's taillights.. which you already have.
IDK why anyone would want to swap out the BRZ headlights.
2013 Subaru BRZ LTD 6MT DGM
2014 Subaru XV Crosstrek Hybrid TRG PG
2011 Honda CBR1000RR
2010 Subaru Impreza WRX PRM SSM
woode is offline   Reply With Quote
Old 04-10-2014, 01:56 PM   #10
w.k.s.
I don't think he's switching out lights. I think he's looking for lenses to experiment with.
Old 04-10-2014, 02:01 PM   #11
wrohdejr
Drives: 2013 subaru limited wrb brz
I swapped my brz headlights for the spyder headlights. I also had to make sure i received the brz version not the frs because of the 8 pin plug vs the 6 pin on the frs. With the spyder version i retained the hid from the oem headlights. With the Spyder's you keep all the hid and use it on the new housing.
Portland 86ers
wrohdejr is offline   Reply With Quote
Old 04-10-2014, 02:08 PM   #12
woode
Boosted Member
woode's Avatar
See, IMO that looks 1000x worse than the stock headlights. The clean parking light lines and the solid turn signals of the OEM to aftermarket cheapy looking led strip style lights..
But, I guess if somebody just wants to change the headlights just to say that they changed the headlights..
Reminds me of when those dumb Altezza tail lights were popular with the ricers.
The Following 3 Users Say Thank You to woode For This Useful Post:
chadstyle (04-14-2014), Sniper2606 (04-10-2014), sshole (04-10-2014)
Old 04-10-2014, 03:29 PM   #13
Acree
Acree's Avatar
I need to replace just the lens on my stock headlights. I don't want to pay $1400 for a pair of OEM headlights.
The Following User Says Thank You to Acree For This Useful Post:
woode (04-10-2014)
Old 04-10-2014, 03:35 PM   #14
86SPEED
86SPEED's Avatar
Drives: The silvertrooper 10 series
you can scratch winjet covers off. they are extremely close but not exact.. i was going to switch for the oem cover on my winjet. but i saw someone posting up the oem frs lights for 150, and i know they will fit right on the brz and gt86 housings
86SPEED is offline   Reply With Quote
New Aftermarket Headlights mezdup Cosmetic Modification (Interior/Exterior/Lighting) 63 08-07-2015 04:33 PM
So someone is making aftermarket oem usdm headlights jadewbj Cosmetic Modification (Interior/Exterior/Lighting) 4 10-10-2013 02:58 PM
Any Aftermarket Headlights? blugbox Cosmetic Modification (Interior/Exterior/Lighting) 6 07-02-2013 06:05 PM
where's the aftermarket headlights? abutterman Cosmetic Modification (Interior/Exterior/Lighting) 22 03-23-2013 10:09 PM
